Question about Polaroid FLM-3232 Television
Polaroid 3232 I have the polaroid 3232 for about a year and have it connected to a directv receiver. Now, when I press the remote, the input changes and I get a light blue screen with a clear banner for channel and no picture. None. And I have to use the directv remote to turn the tv on and the polaroid remote to turn the tv off. Anyone else have a jumping input and constantly have to reset it manually to get a picture?
  • Anonymous Mar 19, 2014
    DP 42849. I pressed Directv remote for Directv and tv to go on. Directv box turned on, tv turned on, but then turned off. TV repeatedly turns on and off, whether directv box is on. Screen stays black, not on long enough to get to blue screen..thank you
    Sergeant:
    Champion:
  • 362 Answers
I have found others that they did this same symptom when the ir board went out its only 9.95 plus installation.
Posted on Dec 31, 2007
Could you please tell me how to reset my tv? I have a blue screen
What should I do if my TV screen turned black, blue, or gray? print.png Print try this.
Proceed with the troubleshooting steps below only if you're seeing:
  • Black, blue, or gray screen
  • "No Signal" message without the DIRECTV logo
Note: If your TV screen appears "frozen" or you're seeing wavy lines or overlapping images, try this.
Solution 1: Check that your TV is set on the right input
[img border="0" alt="Image" src="https://cdns.directv.com/cms2/global/icons/sm_cl_blu__number1_icon.png">Turn your TV and receiver off and back on.
[img border="0" alt="Image" src="https://cdns.directv.com/cms2/global/icons/sm_cl_blu__number2_icon.png">Using your DIRECTV remote control, press the TV Input button to cycle through TV inputs (Component, HDMI, etc) until you see a picture. If nothing happens when you press the button, try programming your DIRECTV remote to control your TV Input and try again.
Note: You can also try changing the TV Input using your TV remote.
[img border="0" alt="Image" src="http://www.directv.com/cms2/global/icons/sm_cl_blu__number3_icon.png">If you're still having issues, check the cable used to connect your receiver to your TV.
Still not seeing a clear picture?
Continue to Solution 2.
[img border="0" alt="Image" src="https://cdns.directv.com/cms2/support/answer_center/tech_faq_images/img_screen_off_4.jpg">
Solution 2: Reset Your Receiver
[img border="0" alt="Image" src="https://cdns.directv.com/cms2/global/icons/sm_cl_blu__number1_icon.png">On some DIRECTV receivers there is a red reset button located inside the access card door on the front panel. Press it, then wait for your receiver to reboot.
Note: If you cannot locate the red reset button or your receiver does not have one, unplug the receiver's power cord from the electrical outlet, wait 15 seconds, and plug it back in. Then press the Power button on the front panel of your receiver and wait for your receiver to reboot.
could-please-tell-me-reset-tv-blue-i0x50p0fk40mg1d0uyxi2cma-5-0.jpg could-please-tell-me-reset-tv-blue-i0x50p0fk40mg1d0uyxi2cma-5-1.gif
May 12, 2014 | Vizio L37 Television
Why can't I find the codes for DirectTV remote?
The DirectTV remote should have the option to
scan for the code check the instructions for
the automatic scan method most likely you
turn on the tv, dvd/vcr keep pressing button
until channel changes or set turns off which
ever button you use if you dont have the
instructions try this address
http://www.satex.com/directv/remote_codes.html
Nov 22, 2007 | Polaroid FLM-3232 Television
My Polaroid FLM-3232 does not display over air HDTV channels
There is no such thing as a 'digital antenna;' any antenna with sufficient gain and bandwidth will receive whatever signals there are available.
You may have to change the input source via your set's menu so it is looking at the antenna input; it may be set to cable currently.
Feb 03, 2010 | Polaroid FLM-3232 Television
Universal remote code for a Polaroid LCD TV
I may be able to help with your Universal remote and your Polaroid LCD HDTV.
You can find some Polaroid HDTV Remote Codes here.
I hope that helps.
______________________________________
Polaroid FLM-3232 Manual Download
Polaroid FLM-3232 Service Manual Download
Feb 26, 2009 | Polaroid FLM-3232 Television
Cannot return to TV from DVD play
If you have a Directv receiver, and you have to be on channel 3 on the TV to watch it, then we have to get you off the video input. On a Directv remote, there should be a button toward the top left hand side that says "TV input." Try pressing this first. If that doesn't work, then look for the button on the Insignia TV remote control that says "tv/video," "source," "input," or something along those lines. Press it (some TV's make you press it several times to change the input). Just make sure that your Directv receiver is on before you start pushing buttons.
Give that a shot.
Jan 06, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
Program remote to a direct tv reciever
You are most likely out of luck using these as universal remotes. You are better off purchasing a Logitech remote and programing it for the Polaroid and your Directv box.
Jan 06, 2009 | Polaroid FLM-3232 Television
Directv remote code for polaroid tv
Slide top button on remote to tv. Press and hold mute and select button until the green light on the remote blinks twice. Then press 991. Then press 1. Then press the tv power button once. If the tv doesn't respond hit the channel up button on the remote. If that works press select to store the code and slide the switch back to the left. If it doesn't work keep hitting channel up until it does. It can take up to 30 minutes but it works.
Jan 16, 2008 | Directv RC23 Remote Control
Remote code
We had a slightly different problem. DirecTV listed many codes but none of them worked. I scoured the Internet and found one that did the trick - 10178! I hope that works for you. If not, the Polaroid codes that were listed (but didn't work for us) were:
10765, 10865, 11262, 11276, 11314, 11316, 11326, 11327, 11328 and 11341.
Jan 03, 2008 | Polaroid 3211TLXB 32 in. LCD Television
Sharp 42" lcd remote code for a polaroid vcr/dvd
I hope that helps.
Dec 03, 2007 | Polaroid FLM-3232 Television
DirecTV Remote Control of Polaroid TLA-01511C
These worked for me
Polaroid 10765, 10865, 11262, 11276, 11314, 11316, 11326, 11327, 11328, 11341, 11498, 11523, 11991, 11992
Nov 23, 2007 | Polaroid FLM-3232 Television
Polaroid FLM-3232 Television Logo
215 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
