i installed winxp but it not boot, so i change the os win98 it will working, from that to upgrate to winxp, the same problem is occur, so kindly give me solution for that
Comment by kokilajai, posted on Dec 11, 2007
i am using pga 370 broad, p3 633mhz,sis 6236 video card, in that we installed win xp but after it finished it will not booting up, so i change to win 98 it booting normally. from that to upgrate win xp installing is over, but it not boot in win xp
Your upgrade options
If you want to upgrade your system to Windows XP, the first thing you need to do is verify that it meets the system requirements for the newer operating system.
You will need:
Windows 98 or later version of Microsoft Windows operating system.
At least a 233Mhz processor. Any manufacturer (AMD, Intel, IBM, VIA, etc.) will do.
At least 128MB of system memory.
1.5 Gigabytes of free hard drive space (note that you should have at least 3 gigabytes if you want to do any meaningful work with your system after the upgrade).
A CD-Rom or CD/RW drive.
Mouse and keyboard (either USB or PS/2).
A video adaptor and monitor capable of displaying 800x600 resolution. If you are not sure about this, change the resolution within Windows 98 by right clicking on an empty area of the desktop and selecting 'properties' then going to the 'settings' tab. The resolution slider is at the bottom left. Set it to '800x600' and click 'apply.' If your screen is still legible, you are fine. If the 800x600 option is unavailable, you may need to upgrade your video adaptor before upgrading Windows.
Note that if the screen becomes scrambled, blank or unreadable, you will probably need a new monitor as your current one cannot handle the required resolution. If your system meets the minimum requirements for Windows XP, it's time to find out which version of the operating system you can upgrade to.
This is Microsofts recommendations
Sean
Was this solution helpful? Show your Appreciation by rating it:
