Question about Dryers
I have a duet dryer elec. truns on but will not run. when I push the start bottem it just beeps
  • 986 Answers
Usually this means the belt is broken,the belt may have just been old and worn out and it was time to replace it,or perhaps the wheels locked up or the idler and caused the belt to break. Look around for stiff wheels, bad bearings, glides and idlers. Its a good idea to oil the rollers with some temp resistant oil such as zoom oil. Dont use WD40 as this stuff is highly flammable and may cause a fire.
Posted on Sep 12, 2009
I have front load duet elec. dryer when I started it made a grinding sound and now I get is a click sound with nothing happening. Help
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 28, 2011 | Whirlpool Dryers
I have a Whirlpool Duet Dryer GEW9250 which has all panel lights light but when you push the start button it beeps once and the sensing light is on and it doesn't start. I changed the Thermal fuse...
heatman101
Aug 19, 2011 | Dryers
I press the start button on my whirlpool duet dryer and it beeps, but doesn't start
This is a common issue caused by a blown thermal fuse located on the blower housing and wired in series with the motor. Power to the motor is then cut and therefore cannot run. No dryer function works when the motor cannot run. Click on the link below for the complete details of the troubleshooting and repair procedure.
Whirlpool Duet and Kenmore Elite Electric Dryers Not Starting
Aug 13, 2011 | Whirlpool GEW9250 Electric Dryer
The dryer won't start, when I push the start button is just beeps. I checked the door and it's shut and nothing is in the way. It was working a few hours ago. We had a bump in the power earlier today...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Feb 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Won't start, keeps beeping when i push start.
The door switch has gone bad. Replace door switch and you should be good to go.
May 16, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Beeps but doesn't start
Duet dry lights up, hit the start button and it just beeps and lights flash. but will not start.
Mar 01, 2009 | Whirlpool GEW9250 Electric Dryer
Won't start, beeping sounds
sounds like the door switch might be an issue,, does teh tub light go on /off as you open the door??? if not try manually pushing the switch in a few times.
Oct 25, 2008 | Whirlpool GEW9250 Electric Dryer
Dryer just says beep beep beep everytime I push start
sounds like you may have a bad door switch(mach thinks door is open when it is not).open door and look on front panel that door pushes into.you should find a small button covered in a grey rubber boot.push on it and listen for a click,if u dont hear a click the switch is bad.if u do hear a click it could still be bad or you can have a open thermal fuse
Sep 29, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
Top Dryers Experts
