Question about Amana AGDS902 Gas Kitchen Range
The oven light will not go off when the door is closed on my Amana AGDS902. any recommendations?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 92 Answers
Check to make sure there is no switch to manually turn on the oven light. Most have a switch now to turn them on without opening the door so you can check the food without letting out the heat. Hope this helps.
Posted on Sep 12, 2009
I have an Amana AGDS902WW stove/oven. The oven is not heating properly. Sometimes it takes a very long time to heat and others it will not heat up at all. Is the problem in the thermocouple? If so, where...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Oct 07, 2010 | Amana AGDS902 Gas Kitchen Range
Amana oven AGDS902SS started beeping and showing a F1 error.
F1=Electronic range control failure
It is telling you may have a fauilty control...need to replace control or EOC.
If you are an novice working over the control board. please do take the help of an authorised technician doing that.
Mar 02, 2010 | Amana AGDS902 Gas Kitchen Range
How do I clean my amana gas self cleaning oven
I have an Amana self-cleaning oven, Model AGR5715QDQ. I can't find my manual - how do I start the process of cleaning? Elizabeth
Nov 22, 2009 | Amana AGDS902 Gas Kitchen Range
The stove is locked, how do I unlock it so I cn open the oven door?
You might have the oven scheduled for cleaning. If so, clear that. You also might have a child safety lock that was put on by accident. If you can not find a clear button, try to reset the oven cleaner for a minute or two and have it shut off. If none of the above works, go to your breaker box and shut the power off. It should reset the electronics. I hope this works, I see a lot of complaints about Vikings not opening after cleaning.
Nov 15, 2009 | Amana AGDS902 Gas Kitchen Range
Hello. Regarding my Amana range (MODEL: AGDS902),
You will have to replace the bottom element.
John
Oct 03, 2009 | Amana AGDS902 Gas Kitchen Range
Amana first addition oven (approx 10 years old) will not heat
I had a similar problem with my Amana oven, also about 12 years old. It was slow to heat and sometimes wouldn't reach the set oven temp. I replaced the oven igniter on a tip that it wasn't drawing enough current to open the gas valve solenoid. That did the trick. It starts immediately and heats to the right temp. Good luck. Joe
Dec 23, 2008 | Amana AGDS902 Gas Kitchen Range
Amana gas range will not heat up in bake mode
it turned out to be the igniter...a friend tested it and found it to be bad.....
Nov 16, 2008 | Amana AGDS902 Gas Kitchen Range
Oven door won't close tight
order and replace door springs part # 32052801 youll need 2
Feb 22, 2008 | Amana ACF3355AS Gas Kitchen Range
Amana AGDS902 Gas Kitchen Range Logo
98 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
