Question about Zenith Televison & Video
I have Zenith TV 42" P42W34P Poroblem is add bar (black 3" vertical @middle screen. Please let me know the real problem. Thanks, Lorenzo Rubia
  • 5 more comments
  • Lorenzo Rubia
    Lorenzo Rubia Sep 12, 2009
    where exactly located the driver board at is it the connected from power supply.
    Thanks,
    Biomed
  • Lorenzo Rubia
    Please let me know where exactly the drver located at. If you can send with diagram it will help.
    thanks,
  • Lorenzo Rubia
    Which one sir, is it the one rightside with wire connection 8-wire with red and blue or the middle board . Please let me know.
    thanks
  • Lorenzo Rubia
    I think this driver board is different from the one i have here. This one is a plasma TV not projector.
    i cant figure out where exacty this board is. i alreadyy checked out the ribbon where the vertival line occured but still giving the same thing.
    thanks,
  • Lorenzo Rubia
    Sir, ive aleady removed the back cover but still i cant see the rectangle like shaped aluminum slots and the four fuses. What can i do. Please thanks
  • Lorenzo Rubia
    Yes i tried to apply some pressure between the metal and orange ribbon and it worked fine after 30 mins, it came with the same problem. What will be the next step. Please
    thanks,
  • Lorenzo Rubia
    thanks,
    President:
  • 1,462 Answers
Black vertical lines on your P42W34?
SOLUTION 1:
Apply pressure between the silver metal board and the orange ribbon cable on the bottom portion of the TV where the black lines occur.
SOLUTION 2:
(If soution 1 doesnt work)
Just reheat and add soder to fuse connected behing the driver boards.
It's an easy fix usaully takes a hour. Over time the connection from the soder on the driver board dries and seperate or loses value due to heat transference. Remove the back locate the driver boards they are rectangle like shaped alumiun slats that run across the bottom of the plasma. Underneath the slats you'll see four square like fuses with the number 100 imprinted. Purchase a sodering iron at Sear for $15 add a touch of soder to the ends of the fuse to re-establish the connection. Repeat process for all driver boards, make sure the unit is unplugged before you proceed. If it's fried replacing it is not a problem just resoder the new fuse to both ends to establish the rely.
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Posted on Sep 12, 2009
  • 2 more comments
  • Vinod Kumar
    Vinod Kumar Sep 12, 2009
    Yes the board that is connected to the power supply is the driver board....
  • Vinod Kumar
    Here is the picture of the driver board
  • Vinod Kumar
    This solution should solve your issue, the picture is not accurate
    Remove the back, you can see rectangle like shaped alumiun slats that run across the bottom of the plasma
    Can you see the specified things
  • Vinod Kumar
    Add a touch of soder to the ends of the fuse to re-establish the connection.Repeat process for all Fuses,
1" black vertical line in center of screen. Sony Plasma.
NOT DEFECTIVE!!!
There are 4 or 5 ribbon cables on the bottom or on one side, they control part of the plasma screen. Check the ribbon cable2_bing.gifnear the black lines. Unplug the ribbon cable and look for black chipson the underside of it, I think they say 100 on them, you need toresolder both ends on each chip. Should fix the black line issue.
Aug 19, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
BLACK VERTICAL LINE ON RIGHT SIDE OF TV
I hope you are handy with tools!!!!!!! Just wanted to let everybody know that my plasma has the same problem but mine works fine for a minute and then it has the black line.. I took mine apart as suggested above.
I took regular wrtting paper used as a shim to make the contact
tighter, so far is working just fine.. I do not know if the paper is safe but I'm allways watching mine screen.
Please read this link http://www.fixya.com/support/t226674-zenith_p42w34_edtv_plasma_black_line
Jan 26, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Black vertical line 2 in wide on zenith p42w34p
Hello, I can help you fix your plasma TV. If you have Black vertical 1.5 inch line/s that come and go. Please feel to call or message me at 1-503-432-9904 or pleasefixitdave@yahoo.com Ask for Dave! Later guys!
Jan 02, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Black verticle line on screen of zenith p42w34
I'm sorry you have not been given a clear answer on how to repair your TV. I know how to fix the problem you are having (1.5 inch Black vertical lines that come and go) If you still need help fixing your Plasma TV please feel free to message me @ pleasefixitdave@yahoo.com or just give me a call @ 1-503-432-9904 and I'll help you fix your TV buddy! Ask for Dave! If your reading this post and you have a plasma or LCD type TV and need any type of help please feel free to give me a ring or message me with the problem your having. I'll do my best to help you!
Talk to you later!
Dave :-)
Nov 30, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Zenith P42W34P Plasma Display Panel
Hello, My name is Dave and I can help you fix your Plasma TV. Do you have Black vertical 1.5 inch line or lines on your screen that come and go? Then give me a call. Please feel free to give me a call @ 1-503-432-9904 or message me at pleasefixitdave@yahoo.com
Thank you!
Dave,
Nov 20, 2008 | Akai PDP-4247 Television
Black stripe down TV plasma screen
I'm sorry you have not been given a clear ansewer on how to repair your TV. I know how to fix the problem you are having (1.5 inch Black vertical lines that come and go) If you still need help fixing your Plasma TV please feel free to message me @ pleasefixitdave@yahoo.com or just give me a call @ 1-503-432-9904 and I'll help you fix your TV buddy! Ask for Dave!
Talk to you later buddy!
Dave
Apr 05, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Vertical Black line 3 inch width on Plasma Samsung 42C96HD after 2 months of use
I also have the same problem I phoned Samsung today to explain the tv was only 14 months old, they didn't wanna no because it was out of warrenty by 2 months. I am getting a black solid line down the left hand side of the screen. I ended up phoning Dixons were we bought it from, they have told me to get an independent engineers report done & send the report to them within 14 days. Dixon told me it was a known problem with Samsungs. They said they will fix it free of charge if they can if not they will send vouchers to the same value of the television. So beware stay clear of Samsungs.
Feb 03, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Vertical Black bar on the screen
What is the model number it sounds like pixel problems or board problems. For more info ctechnicians.com
Jan 06, 2008 | Televison & Video
Zenith P42W34 EDTV Plasma Black Line
Oct 19, 2007 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Black vertical line on p42w34p plasma
could be a loose ribbon cable on a buffer board, or one of the buffer could be going bad
Oct 03, 2006 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Televison & Video Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
