Question about Microwave Ovens
Where is the filter and how do I clean it on my ge profile ventless hood
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If the model is not vented
to the outside, the air will be recirculated through a disposable charcoal filter that helps remove smoke and odors. The charcoal filter should be replaced when it is noticeably dirty or discolored (usually after 6–12 months, depending on hood usage). To remove the charcoal filter, disconnect power atthe main fuse or circuit breaker panel or pull the plug. Remove the top grille by removing the 2 screws that hold it in place. Slide the filter towards the front of the oven and remove it.
Please tell me the model number of your Unit so that i can provide you with model specific information.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 12, 2009
How to turn off reset filter light on ge profile microwave just bought
Remove entirely the filter and try again, then put it back.
Sep 01, 2017 | GE Microwave Ovens
Light bulb above stove under microwave hood
According to the GE manual it is a 120 v 20 watt halogen bulb, the GE product number is WB36X10213. That is the cooktop light/nightlight that would be on the stove hood. HTH!
Sep 25, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
GE PROFILE SPACEMAKER 2 JVM2070SH001 MANUAL HOW DO i REPLACE CHARCOAL FILTER?
That's covered in the owner's manual. If for some reason you don't have yours, you can download GE owner's manuals and installation instructions here.
You can find handy exploded views and order parts (including filters) here.
Jan 10, 2011 | GE Profile Spacemaker Over-the-Range...
Ge profile spacemaker 2.0 model#JVM2070SH001 - HOW TO REPLACE CHARCOAL FILTER.
GE profile spacesaver 2.0-does not heat and slight smell of electric burning when it is turned on. Turntable turns, fans work keypads work- just no heating and the electric odor. Filters and inside are...
MOST LIKELY YOU HAVE WHAT IS CALLED A MAGNETRON THAT HAS FAILED... IT IS THE PART THAT DOES ALL THE HEATING ...YOU DO ALSO HAVE A HIGH VOLTAGE TRANSFORMER THAT SEND POWER TO THE MAGNETRON BUT IT SOUNDS LIKE A MAGNETRON.... to be honest with you unless you are servicer it normally cost more to repair and for a few dollars more you can purchase a new one..... good luck to you.....
Jan 03, 2011 | GE Profile Spacemaker Over-the-Range...
Is there a filter that goes into the vent of GE Spacemaker 2.0 profile microwave (model# JVM2070SK01)?
You should first refer to your owner's manual. If for some reason you don't have it, you can download it here free.
See page 38 and 39 of the manual for info on the filters.
If your oven is set up to vent outside, it will have cleanable grease filters.
If it is set up to recirculate, it will have a charcoal filter which cannot be cleaned, but must be replaced about every 60 days.
It is part number WB2X10956 and you can order it and other parts and accessories here.
Dec 17, 2010 | GE JVM2070 Microwave Oven
Determine venting requirements
When you initially unpackage the microwave oven it is already set up for RECIRCULATION mode (which is VENTLESS). However, since the unit recirculates air rather than exhausting it out through the wall or roof, it usually uses a couple of small charcoal filters behind the upper grille and mesh filters on the underside that have to be changed or cleaned periodically. These filters will accumulate grease and dirt over time and should be periodically checked in order to maintain proper ventilation and air flow. Information pertaining to the location and care of the filters is explained on Page 4 of your Owner's Manual.
NOTE: If you wish to convert to a VENTED system, the instructions are listed on Page 4 of the Installation Guide.
If you do not have either manual you can obtain copies at managemylife.com. Just type in your model number as "GMH3174XVB" and you will find the manuals listed in a .pdf (Adobe) format that can be printed or downloaded for FREE.
If you have any questions, please post back and let me know. I hope this helps you.
Mar 25, 2010 | Microwave Ovens
How do you change the charcoal filter on the GE Profile spacemaker 2.0
You can download GE owner's manuals and installation instructions here.
You will need the
full model number from the tag on / in the unit.
You can find helpful exploded view diagrams and order parts (such as a charcoal filter) by entering your full model number from the tag on the oven
here.
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly for more help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 08, 2009 | GE Profile Spacemaker Over-the-Range...
My spacemaker keep dripping grease on my wall, what should I clean?
I would suspect a clogged grease filter (which can be cleaned) and/or charcoal filter (which cannot be cleaned and must be replaced).
The manual will give you the details.
Also be sure the hood vent exhaust fan is working correctly.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jun 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How do you install charcoal filter on a GE profile Convection oven.
Jun 02, 2009 | Microwave Ovens
Microwave Ovens Logo
14 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
