Question about KitchenAid Architect Series KEBC107KSS Electric Single Oven
Oven works intermittently
My KA gas oven quits working part way through the cooking cycle- but intermittently, so the repair guy comes out and can't find anything wrong with it, but then I'll cook something and think it's done only to find that it is half cooked. The oven stays on, so does the fan, and the temp. may say what it is supposed to say but whatever is inside isn't cooked and you can tell it's not heating properly just by putting your hand in. If I reset it, there is no ignition sound and the oven will just stay on "Lo" and not get any hotter, ie. to the 350 degrees where it is supposed to be! Any suggestions, this is driving me crazy- I'm afraid to invite anyone over for dinner incase the oven quits on me (which it did at the last 3 parties I've had).
Thanks,
mo
    President:
  • 1,314 Answers
Well i had a service call like this one time almost drove me crazy lol so to try to help im going to tell you about it every thing checked out but oven would not cook right finnaly i took the gasline loose from the regulator and rust and trash had built up so heavy on the regulator screen it was restictin the flow of gas so when the contol demanded more gas it couldnt get it but it wouldnt set a fault code because nothing were wrong with the conterols
Posted on Dec 29, 2007
Is it normal or safe for steam to come out of the air vents on my zanussi oven. Model ZCV66030BA? Doesn't seem very safe to me even though repair man says so
Our SamSung oven has steam coming out the vents when we cook certain things.
I think the repair guy is correct.
Jan 05, 2018 | Zanussi Ovens
I have about a 14 year old Whirpool Double Oven model RBD275PDB1. The other day it was working and then in the middle of cooking something it just went off-nothing working. I checked the fuse and it was...
If there is no power at all then I would check where the house power comes into the oven.Be sure to turn off the power before looking in the conection box.Hopefully you will not have to pull out the oven to find the box.
Jun 13, 2011 | Whirlpool RBD275PD Electric Double Oven
My gas oven keeps shutting off during cooking amana apartment size free standing gas oven
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 18, 2011 | Amana Ovens
Hello, We have a Kenmore gas stove model # 71761. The burners on top work good.The issue is with the oven portion. Oven is working. Flame comes on upon ignition to desired temperature setting and then...
It sounds like yous stove is working fine. Cycles fine. If you think the stove is cycling more often than when new then ck the seal on the door. You may be loosing heat.
Jan 14, 2011 | Ovens
Takes for ever to reach temp
you may want to check to make sure both elements are working, if only one is working it will take longer to reach temp and to cook
Sep 18, 2010 | Fisher and Paykel AeroTech OS302 Electric...
I'm a landlord and my tenant's oven will not heat up to the proper temperature intermittently. I had a guy come out and test the oven and it works fine, yet my tenant is still complaining the oven is not...
Absolutely. That is the first thing I would think that would cause such a fluctuation of temperatures. BUT if it is a gas oven (WITH A PILOT FLAME) then FIRST consider the thermocouple needing to be changed. If the thermocouple keeps faulting it will shut off gas sporadically and keep the gas off until it resets temporarily on its own.
Mar 13, 2010 | Ovens
Oven sometimes doesn't heat up. Sometimes heats up to desired temp, then quits working. Sometimes doesn't even heat up at all. When preheated light comes on, thermometer in oven usually says about 100...
This sounds like a weak igniter, it would have to be a gas oven and the symtoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 14, 2010 | Amana Ovens
No gas to lower oven - Cannon Camberley
Hey Stephen - try setting the clock then set the cook period. the oven will only work when that's on i think.
May 07, 2009 | Ovens
Bosch 755 Oven resets during cooking
Hi Jim. Thanks for your request re prob with your oven.
Unfortunately, this is not a problem I have come across before, so in this instance, I am unable to help solve it for you.
Only thing I can suggest at this time is that you check all connections and plug in connectors, you never know it could be caused by a bad or intermittent connection.
Once again, sorry I can't be of more help.
Jan 06, 2009 | Bosch HBL 755 Stainless Steel Electric...
KitchenAid Architect Series KEBC107KSS Electric Single Oven Logo
183 people viewed this question
Top KitchenAid Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Whirlpool
Whirlpool
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
