Question about Garden
Craftsman II LT 4000 MOD # 917-255691 with a Kohler Command 14 HP Engine SN#2202002414. Wont start with key starts with jumpstart on starter. With key to on positon. Replaced the starter solinoid, ignition switch, burn out 15amp fuse. Ignition switch enables float bowl switch.
  • 389 Answers
Check the wire from the ignition switch to the small terminal on your solenoid with a volt meter to make sure you are getting current to the solenoid. If not try a "jumper wire" connected to the same terminals and see if it now cranks. If it does, replace the wire
Posted on Sep 14, 2009
  • trunkizback Jun 19, 2011
    you'de be surprised at how many times this problem comes up on the riders I work on...10% of the time it's an ignition ( switch..solenoid..wire problem ) 90% of the time it ends up being one of the kill switches..IE the seat switch..the blade on switch ..try bypassing ( run a wire as a jumper ) these switches and see if it won't start.Feel free to e-mail me at trunkizback@yahoo.com
Craftsman lawn tractor 917.271060w/kohler 15.5 hp engine cranks but backfires thru carb and wont start.
my 15 hp kohler engine backfired while i was using it, now it wont crank and backfires thru carb
Oct 10, 2010 | Craftsman Garden
18hp kohler engine (grasshopper) won't start. Single click from starter/solenoid when key turned. Battery new/charged.
I have a duetz-allis mower with 18hp. kohler eng. won't start, have new seloniod, new circuit breaker, getting fire to switch & out. Still won'tstart
Aug 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 54 in lawn tractor W/ 26 hp Kohler engine
Could be, but test each item with your tester. Test key switch (12V in and 12 V out when turned to start., operator present switch 12V in 12V out (seat) Clutch switch, etc. till finally you test for 12V on the small terminal on the starter solonoid. Happy testing!
Jul 19, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Kohler 17.5 command. will not start
The woodruff / flywheel key is likely partially sheared. Pull off the air housing, remove the starting clutch, to get to where you can see the flywheel key. I bet you will find that the key has distorted. Easily replaced once flywheel is pulled. Make sure to use the correct key when replacing it.
May 30, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Will not start. Now hear a faint click when I turn the ignition.
check for voltage at starter whe turning key to start if you have 10 or more volts the starter is bad if you have around 4 volts try tapping on starter while in the start position on key may just be froze up.if you have no voltage at starter then the solenoid may be bad.
Aug 02, 2009 | Craftsman Garden
No spark on my 14 hp kohler engine
Sometimes there is rust on the crankshaft and the magneto can not pick up the signal. Leave the sensor on the engine, try cleaning the rust off the crank damper and then run a clean rag between the sensor and crank. The gap varies but a old fashion matchbook seems to work in case the sensor is loose. Good Luck
Jul 26, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kohler engine wont recharge on tractor
Either the stator went out or the voltage regulator is faulty and must be replaced
May 29, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
898 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
