Canon LC-510 Help needed I installed a flat cable in the scanner section and it buckled. This is the cable that works with the scanner unit. Does anyone know what I am doing wrong
Heated and cooled seat on 2004 expedition stopped working how to reset them
Heating and the cooling both don't work ? Just one seat or all seats ?
Your best bet have it checked for DTC'S - diagnostic trouble codes to start .
Climate Controlled Seat Module (CCSM) Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1342 ECU Is Faulted CCSM INSTALL a new CCSM and CARRY OUT programmable module installation (PMI). REFER to Climate Controlled Seat Module . B1358 Ignition Switch or Blower Electronics Circuit Short to Ground CCSM Go To Pinpoint Test Q . B2477 Module Configuration Error CCSM This DTC indicates programmable module installation (PMI) has not been done to a newly installed module. CARRY OUT PMI. REFER to Section 418-01 . CLEAR the DTC. CARRY OUT the self-test. B2486 Climate Controlled Seat Module Voltage Out of Range CCSM DEPOWER the supplemental restraint system (SRS). REFER to Section 501-20B . DISCONNECT driver safety belt buckle pretensioner electrical connector or passenger safety belt buckle pretensioner electrical connector of the affected seat and CONNECT restraint system diagnostic tool 418-F395 to the safety belt buckle pretensioner harness connector. CONNECT the battery ground cable. CHECK circuit 294 (WH/LB) for a fault. REPAIR as needed. If okay, REFER to Section 414-01 . Once the repair is complete, DISCONNECT the restraint system diagnostic tool from the safety belt buckle pretensioner harness connector and CONNECT the safety belt buckle pretensioner connector of the affected seat. REPOWER the SRS. REFER to Section 501-20B . B2488 Thumbwheel Switch Voltage Out of Range High CCSM Go To Pinpoint Test R . B2521 Tach Circuit Failure CCSM Go To Pinpoint Test Q . B2729 Cushion Over-Temp Detected CCSM Go To Pinpoint Test S . B2730 Back Over-Temp Detected CCSM Go To Pinpoint Test S . B2731 Differential Temperature Fault CCSM Go To Pinpoint Test S . B2792 Heat Switch Short to Ground CCSM NOTE: If HEAT is pressed for greater than 20 seconds on the climate controlled seat switch, DTC B2792 will set in the CCSM.
CLEAR the DTC. If the DTC does not clear, DEPOWER the supplemental restraint system (SRS). REFER to Section 501-20B . DISCONNECT driver safety belt buckle pretensioner electrical connector or passenger safety belt buckle pretensioner electrical connector of the affected seat and CONNECT restraint system diagnostic tool 418-F395 to the safety belt buckle pretensioner harness connector. CONNECT the battery ground cable. CHECK circuit 1551 (VT/WH) for a short to ground. REPAIR as needed. If okay, INSTALL a new climate controlled seat switch. Once the repair is complete, DISCONNECT the restraint system diagnostic tool from the safety belt buckle pretensioner harness connector and CONNECT the safety belt buckle pretensioner connector of the affected seat. REPOWER the SRS. REFER to Section 501-20B . B2793 Cool Switch Short to Ground CCSM NOTE: If COOL is pressed for greater than 20 seconds on the climate controlled seat switch, DTC B2793 will set in the CCSM.
CLEAR the DTC. If the DTC does not clear, DEPOWER the supplemental restraint system (SRS). REFER to Section 501-20B . DISCONNECT driver safety belt buckle pretensioner electrical connector or passenger safety belt buckle pretensioner electrical connector of the affected seat and CONNECT restraint system diagnostic tool 418-F395 to the safety belt buckle pretensioner harness connector. CONNECT the battery ground cable. CHECK circuit 1550 (WH/OG) for a short to ground. REPAIR as needed. If okay, INSTALL a new climate controlled seat switch. Once the repair is complete, DISCONNECT the restraint system diagnostic tool from the safety belt buckle pretensioner harness connector and CONNECT the safety belt buckle pretensioner connector of the affected seat. REPOWER the SRS. REFER to Section 501-20B . U2362 UBP Invalid Data Node ID CCSM NOTE: DTC U2362 indicates a network concern, the CCSM is not the source of the fault.
CLEAR the DTC. If the DTC does not clear, REFER Section 418-01 .
Nov 26, 2016 | 2004 Ford Expedition
My canon ir 2016 is showing adjusting waiting to scan after I want to do photocopy Please help me
Dear, check all the ccd flat cables of scanner unit and dc boards back side and replace them which are faulty due to long time which lost the metallic strength for which this issue comes .One flat cable is fitted from scanner lamp unit to its board which is long cable and two flat cables are fitted with this scanner board to back side pcb which are long and another one is connected to two pcb boards at back side one comes from mother board to other board,
Nov 23, 2016 | Canon imageRUNNER 2016 All-In-One Laser...
Error 225 in canon 4350 imegemanage printer pls sent solution
E225 is the error code regarding the CIS unit malfunction. First reconnect the flat cable to the CIS unit. If still problem is existing do the following steps in the service mode press "Additional function"," # "( to enter the service mode) Use the arrow keys to scroll to HARDWARE TEST, press OK Use arrow keys to scroll and select CIS TEST, press OK Now as shown in display press 1,2,3,4 and check if the CIS is glowing in White, Red,Green &Blue. If CIS is not responding, it's time to replace the CIS unit. If the CIS is responding properly do the following procedure.
Now dismantle the scanner section and apply a suitable lubricant( Silicon oil can also be applied) to the portion of the flat cable which touches the bottom plate and also to the portion of the bottom plate over which the flat cable is sliding.
If still issue not solved it's time to replace the CIS unit
May 19, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
Hi, when i start my print canon mf4010, it show me in the image book system error e225, i don't know why, please help me. thanks IMJA
PROBLEM REGARDING CIS UNIT(SCANNER) Reconnect the flat cable to the CIS. If still problem continues, apply lubricant to the flat cable where it touches the bottom and to the bottom plate over which the cable is sliding. Check if there is problem still. If still there is problem. Replace the CIS Unit
May 19, 2011 | Canon Office Equipment & Supplies
I have a message E100, what do I need to do?
From the Canon manual --
E100
When the scanner motor is started up, the BD input signal does not arrive within a specific period of time.
When the scanner motor is started up, the motor rotation is too fast, and fails to reach a specific revolution within 20 sec at time of deceleration.
While the scanner motor is rotating at a specific speed, the BD input signal cycle is not within a specific range (±2%) for an equivalent of 10 mm (print distance).
While the scanner motor is rotating at a specific speed, the BD input signal cycle is not as indicated (±2%).
During the WMUPR period after the power switch has been turned on or the front cover/left cover has been opened/closed, the drum unit is absent.
Possible cause
: The wiring is faulty (short circuit, open circuit). The laser scanner unit is faulty. The DC controller PCB is faulty. The drum unit is not installed.
That level of repair if it is indeed the wiring requires a qualified tech to resolve.
Mar 22, 2011 | Canon LaserCLASS 510 Printer
I downloaded software yesterday to make my 3210 all-in One photosmart printer compatable with windows 7 operating sx on my new pc It is printing fine but can't get the scanner to work. My email is...
There are a couple of issues that can cause this. 1) Did you install the full software before you connected the USB cable (if you are using that connection)? If not, did you uninstall the generic software and remove the data cable before installing the software? Try a new data cable and a direct connection if you are using a print server or USB hub. Scanners require bi-directional communication and will fail even when the printer works.
Are you launching the scans from the computer or the scanner? Try launching the scans from the computer first. Remember you need to set the destination button defaults in the HP software and the monitor program needs to be running to see those button presses. Try scanning with Windows Fax and Scan (New Scan) or Paint (File > Import from Camera or Scanner > New Scan).
Navigate to http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&dlc=en&product=439488 and select your OS version (32- or 64-bit Win7) and click Next. Then look in the section Utility - Diagnostic Tools. Download and run the HP Scan Diagnostic Utility. Also check if you need one of the Update patches (there is one for scan files going missing).
If you are using the unit as a networked printer, also try a new data cable. Make sure the router is not dropping packets and that your firewall isn't blocking the incoming signal from the scanner. (Try scanning with the firewall temporarily disabled.)
Check if the unit has a scanner lock and unlock the transport lock if it is in the incorrect position. Check if the lights come on and the unit moves when you try to launch a scan. If the lights aren't coming on or the scan unit doesn't move, the unit probably needs service.
I hope this helps.
Nov 14, 2010 | HP Photosmart 3210 Printer
Will my Canon MP510 work if Black ink cartridge installed alone?
No, Canon machines only work with all inks installed, you can get air bubbles in the printhead without inks and that would ruin the printhead.
Jan 14, 2010 | Office Equipment & Supplies
Where can I get ADF parts?
eBay: Find Xerox Documate 510 Workgroup Scanner w/ADF - PARTS UNIT in the Computers Networking , Scanners , Standard Flatbed Scanners ...
cgi.ebay.com/Xerox-Documate-510-Workgroup-Scanner-w%2FADF---PARTS-UNIT
Dec 03, 2009 | Canon imageCLASS D880 All-In-One Laser...
Canon ir 330-400 copier
it is supposed to use a separate scanning board (Interface Board-D1) with SCSI connectivity and TWAIN software.
Mar 15, 2008 | Canon imageRUNNER 400S Copier
Print function isnt working
What a tank! Great machine. I have never tried to connect to a computer. What op system are you using? Windows Vista and maybe XP may not support this model. Look for undates. What cable are you using? I just checked with Canon and found this unit is supported by Win 95/98. A firmware update from Canon may solve it.
May 29, 2007 | Canon LC-3175 Laser Fax
22 people viewed this question
k24674
jasbo
jasbo
