Question about Toro Lawn Mower With Toro Power Tools
Toro model 20038 self propel problem
I have a Toro model 20038 Personal Pace mower. The self propel is not working very well and has progressively been getting worse. The belt is good and engages properly. It appears that the wheels are slipping on the axle. The mower is 5 years old. Could it be the keys on the axle that have worn down and need to be replaced?
Try taking the back wheels off and lubricating the joint cogs and wheels with ,say, 3 in 1 oil . The dealer recommended doing this once every couple of years as preventative maintenance when I bought mine , and it has solved sticking problems for me .
Posted on Sep 12, 2009
Can I put a key start on a toro 20975
you could use a key as an immobilisation but without a starter motor it is impossible (i am guessing it is a pull start gas mower?)
Aug 21, 2016 | Toro TimeMaster 30" 190cc Personal Pace...
Toro timemaster is 3+ years old and doesn't self propel when you push the handle forward any longer.
Either the transmission is shot or the gears on the wheels that turn have been worn away;. They are plastic and do not last long nor take much abuse.
Apr 04, 2016 | Toro TimeMaster 30" 190cc Personal Pace...
Why do the wheels lock up on my self propelled 22" recycling mower
Sounds like they need cleaning & oiling. Check that nothing is keeping it from moving. I have ran over string or cord before & got caught and wrapped around wheel.
Oct 27, 2014 | Toro 22 in. Personal Pace with Blade Stop...
I have a Toro mower made in 5/09 self propel system it grinds when you pull it in reverse. The selp propel is not working. The belt is on. and it seems to be only the left rear wheel? The cable is not...
Yes it is the transmission. A Mower shop will charge you about $225 to fix.. I order parts online and fixed mine for $90. Transmission consist of 3 gears which turns the rear wheels to self-propel.
Jul 21, 2014 | Toro Lawn Mower. 22 in. Personal Pace with...
Replace right rear hieght adjuster on a toro self pace mower
Remove wheel, remove screws mounting adjuster, straighten or replace.
Oct 02, 2012 | Toro 22 in. Personal Pace with Blade Stop...
Toro 2009 personal pace mower transmission went out
You should post this question in the lawnmower section so the proper expert will see it..
Aug 29, 2012 | Toro Lawn Mower. 22 in. Personal Pace with...
Toro self propelled lawn mower dies after an hour
maybe u have to much oil in it or there mite be a stone in the carberator or petrol tank thats blocking the petrol ?
Aug 07, 2012 | Toro Garden
Toro Personal Pace self propel problem.
Your self-propel is probably belt driven. Belts can make an awfully lot of noise when unhappy. Possible it has rolled over and is running on the wrong side of the belt or is worn and just needs replaced. Hope this helps.,
Jun 19, 2009 | Toro Lawn Mower With Toro Power Tools
SELF PROPELL NOT WORKING GOOD
Have you checked the belt that drives the wheel? This is more than likely the problem. It may be broken.
Jim
May 30, 2009 | Toro Garden
Where does cable go at top
It depends on the model, but it hooks up to the handle, on the underside. If it is the personal pace handle (the one where the whole handle moves) It is usually on the lower right corner of the handle. if it does not have personal pace, and just regular self propel, there should be a small hole somewhere on the lower handle. The hole would most likely be on the left side.
Mar 06, 2009 | Garden
Toro Lawn Mower With Toro Power Tools Logo
1,245 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
