TV wont' stay on. I press power button and after 10 minutes, the TV shuts itself off. It was working fine for the last 5 or so months, this started yesterday. Help.
  • 525 Answers
Bad connection.this can be done by some one who has experience in soldering.
Thank you
Posted on Sep 12, 2009
I have a Emerson LD190EM1 Tv DVD combo. It will not work with my Dish Network remote. What is the IR code?
I also have the same tv with no luck on my dish network with the codes. However, I just did an autoscan and found the code, but it doesn't tell you what code. I am sorry I cannot give you the code, since manually entering them did not work, but the auto scan did work!
To run auto scan follow these steps.... it took me about 5 minutes to find on my dish network remote.
1. Press and hold the tv mode button until all other mode lights flash.
2. Press the red power button (not the red tv power button, but the power button which normally shuts off your receiver only)
3. Press the up button (about every other second) When your remote finds the code, your tv will automatically shut off.... once it shuts off, DO NOT press the up button again.
4. While the tv is off, press the pound (#) button.
Your remote will be programmed to your tv. Turn on your tv with the small red power button with the tv wording and test other functions (volume, etc.)
I tried this last night, waiting about 3 seconds in betwwen with no luck after 30 minutes, just a tired finger from constantly pressing the up button. But tonight I tried it on my LD190EM1 and paused for a second inbetween pressing up and almost fainted when the tv actually shut off within 5 minutes of starting! Best of Luck!!!
May 19, 2011 | Televison & Video
Mitsubishi WS-65611 Projection TV When I turn
The problem is common to Mitsubishi projection TVs. Technicians dubbed it as the "blinking green light of death" due to its notoriety.
Here's the basic troubleshooting of the said problem.
  1. Make sure that no front panel buttons are inadvertently stuck in an "engaged" position.
  2. Disconnect ALL devices from the TV.
  3. Press the SYSTEM RESET button and hold for 10 seconds. Proceed if the problem still exist.
  4. Press and hold POWER and MENU buttons simultaneously for 20 seconds. Proceed if the problem still exist.
  5. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours.
If you are still having the problem, either of the following is causing the problem:
  1. DM Board Capacitors have FAILED
  2. Power supply failure
  3. EEPROM Board failure
If the capacitors are bad on the DM board, you can replace it by yourself and save a couple of bucks. The capacitors will cost you about $4 or less compared to $200 when you ask a technician to do it for you. Just insist that the 4-1000uF, 16V capacitors be replaced They usually insist to replace the DM board and cost you $500-$800. These are the capacitors on the DM board with the bulge indicating they are bad.
Same thing with the power supply. You can check the filter capacitors for this kind of problem.
Please let me know if you decide to do the repair yourself and need the guidance to do it.
Nov 30, 2009 | Televison & Video
KDS-R60XBR1 Sony Projection SXRD
The lamp may be starting to go, the symptoms you describe are classic warning signs. You could unplug tv let it cool down and check lamp most likely the glass will not look clear maybe a little milky or smoky in areas..dead give away.
Mar 07, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
TV Turning on and off by its self
You have problems with a condenser that allow the power supply to maintan an acceptable level of voltage in order to keep the TV on. take to a tech to be fixed. unfortunatelly, this problem needs a tech to take measures in the circuitry to find the component that causes the problem.
Nov 06, 2008 | Philips Magnavox TS3260C 32" TV
My Go Video 32" flat screen HDTV will stay on for 5 to 10 seconds then shuts off!
I have the same exact problem with my Go Video 32" HDTV. Yesterday the power stayed on for several hours, now it wont stay on for more than 5 - 8 minutes.
Please someone help!
TJ@streetkidssoftball.com
Sep 28, 2008 | Televison & Video
TV shutting off
try this part first 5600110347 you can get it at www.vancebaldwin.com
Jan 31, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
TV turns itself off after a few seconds, no picture at all
As far as fixing goes, you might as well get a new TV... Unless its a LARGE EXPENSIVE HOLY $%^# TV, It will cost more to fix, than to just buy a new one, unless its under warranty, which being an older model as that (or so im reading) It may not be covered.
Try unplugging the TV, and while unplugged, hold down the power button for a full minute (yes, with the plug NOT in the wall) after a minute, plug it back in, and try. Its a hard reset. If it still does not work, and you've tried different outlets, It's probably a repair issue, and you'll need to get someone to fix it, or just junk it :-/
Nov 11, 2007 | Sylvania SST4322 32" TV
Televison & Video Logo
Top Televison & Video Experts
