Question about HP Photosmart C6100 All-In-One Printer
"Improper Shutdown" - Printer keeps turning on and off.
I have exactly the same problem. Have tried unplugging, turning on and off, look for a jam, etc. What to do?
Got the same problem following a message "Printer ink failure" code 0xc19a0035. Instructions say to shut down using button on/off. But printer refused to shutdown. After 30 minutes, I disconnected power cable. Removed cartridges. Reloaded cartridges. Reconnected power cable and got "Improper shutdown" message with continuous cycle. Solution: 1. While the printer is still turned on, unplug all cables and cords at the back of the printer.
2. Unplug the power cord also from the wall outlet...
3. Wait for two minutes.
4. Reconnect power cord to the wall outlet first.
5. Press and hold the pound (#) and six (6) buttons.
6. While holding down the two buttons, reconnect the power cord to the back of the printer and after two seconds, release pound and six buttons.
7. Turn on the printer if it turns off... and it's fixed.
8. Be patient to let printer run its tests.
Posted on Sep 14, 2009
Testimonial: "This did help! I also had to go to the HP website and download the software, drivers & any updates and then reconnect my wireless network again."
    Problem Solver:
  • 15 Answers
The "improper shutdown" message disappeard, but the "look for carriage jam" continued, as the printer made a gear-grinding sound as it tried to reset. When it quit moving and grinding, the carriage was almost all the way to the left. I pushed it to the extremem left (moved about 1") and went through the process again. This time, after more grinding and groaning, it began the initialization process and finished it. Works fine now.
Posted on Jun 01, 2010
IT WORKED!!!!!
Posted on Apr 26, 2010
Improper Shutdown Message
1. Disconnect the power cord from back of printer ( while printer is powered on )
2. wait for 10 seconds
3. hold and press the Power button and connect the Power Cord.
4. Release the Power button after 3 seconds
5. Follow the Instructions on the printer screen.
Later try to shutdown it, it should not give the message again
Jun 16, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP PHotosmart c6150 keeps shutting on and off repeating the same meassage improper shutdown.
You need to reset the printer. I had the same exact problem with a C6150. Unplug the power cord from back "while printer power is on" (doesn't have to be fully booted just turning on). Wait 20 seconds, hold # and 6 keys together and plug power back in. Continue to hold until power goes off or semi-reset message comes up. Power up (if off) press OK for any error messages and let the printer cycle. Should be good to go. Mine sounded very noisy while it was trying to allign internally. I can only suspect that was the initial problem but this process fixed mine and it runs great now. Hope this helps.
Jan 27, 2010 | HP Photosmart C6180 All-In-One InkJet...
Message Improper Shutdown and screen just keeps recycling and cannot get menu back on and no way to print
try unplugging the printer direclty from the wall jack and press the power button for 20 secs.. then plug cable back in. turn on the printer ..
if it doesnt work.. then try doin a reset..
the procedure for the reset is ( unplug the power cable from the walljack.. then press the # and 6 key together and while pressing and holding these two keys plug the power cable back in and release the buttons after 20 secs u plug in the power cable..
.. after this process.. it will take few minuts to initialize.. chek it works or not
Oct 18, 2009 | HP Photosmart C6180 All-In-One InkJet...
Model c6180 printer gives improper shutdown error
The printer is not getting enough power. When you get this error message it means the printer is being turned off by unplugging the power cord. In this case it maybe that the printer is not getting enough power due to being in a surge protector or perhaps the power module is no longer holding power correctly.
First step is to disconnect printer from any power strip, surge protector, or extension cords and plug in so directly to the wall. If printer still will not stop looping cycle you may need to contact hp for a new power module.
Sep 25, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printer cycles on/off and displays "improper shut down"
Aug 25, 2009 | HP Photosmart C6100 All-In-One Printer
My HP C6180 is caught in a start up loop...
Hi there, " Unplug the printer cable from the computer. " Unistall the printer drivers from Device manager and also unistall the all the printer appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the printer. " then you can connect the printer and and try to Print the test page.
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Aug 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
Impropershutdown
Press 6 and # while disconnecting the power cord (wait a little bit) and connecting it again. When the display is turned on again you can release the buttons.
After this reset you need to enter language, location and any wireless settings etc.
Aug 09, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6180 - IMPROPER SHUTDOWN
Not a big problem,try resetting the printer using the # and the number 6 buttons,holding them down and then inserting the power cord at the back of the printer.
In case it doesnt you can always contact a free online technical
support with an online live techbuddies technician at
http://tinyurl.com/m7ghqz
Apr 15, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6180
unplug the printer and then plug it back in. turn it on and Hold the 6 and # button until the printer shuts off, this should do a hard reset
Apr 02, 2009 | HP Photosmart C6180 All-In-One InkJet...
When i send a print nothing happens. I opened the lid to check for a jam. nothing. but when i closed it the screen on mu printer says carriage jam.....
Sounds like the "deadly embrace" problem...
Computer says to itself "waiting on printer status"
Printer says to itself "waiting on computer status"
Results....nothing.
Try this:
1. Shutdown (using the normal operating system shutdown) the computer.
2. Turn off and unplug both the computer AND the printer at the same time.
3. Plug the printer back in first (and if necessary, turn it on) THEN
4. Plug in the computer and allow it to start normally.
Now try a print.
Let me know if this works for you.
Jun 19, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP Photosmart C6100 All-In-One Printer Logo
2,139 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
