Question about GE Profile GCG1580LSS 15" Built-In Trash Compactor with 1.4 cu. ft. Capacity, Hidden Controls & Remo...
GE trash compactor ZCG3100BVV-02 won't start. I out a new on/off switch and it still will not start
  • adf332 May 11, 2010
    my gcg1580loss would just hum and not start. i found the switch that reverses direction on the motor had burnt contactors. i cleaned the switch that is mounted on the motor and it works great now. i couldn't find a replacement switch otherwise i would have replaced it, i think it comes with a new motor.
  • 999 Answers
Most likely a ram position switch but could also be a bad motor. process of elimination will lead to the faulty component...Eric
Posted on Sep 12, 2009
Ge profile trash comapctor loud banging noice
You have something wrapped on the compactor screw assembly (The assembly is a threaded rod about 24 inches long and 3/4 inch in diameter. ). Most likely it is plastic bag or some other plastic. Pull the entire compactor out (remove the hold down screws first). Then look for the obstruction on the screw assembly, cut it off and try while not in the compactor hole to make sure it works.
Jun 18, 2014 | GE Profile GCG1580LSS 15" Built-In Trash...
Trash Compactor Thumps
I would guess there is a limit switch that tells the machine to stop once the compactor has retracted.
May 04, 2013 | Kitchen Appliances - Others
Ge compactor stops after just starting
the running cycle for this type of trash compactor is a max of about 30secs. The fuller the bag is the shorter the cycle. However, if this is not how yours is running try checking to see if there is any trash stuck between the ram and the basket. Or make sure that the foot peddle is still staying in the "up" position.
Feb 27, 2012 | GE Stainless Steel Built In Trash...
GE profile trash compactor makes loud noise and pulsates
sounds like you have a bad ram bushing on unit... you will have to pull out and watch operation ...there is also a differential switch that tells unit when to stop that sometimes gets worn and needs replaced... it generally is at the top or on the side of bin ....most likely it is one of the two items that has failed...
Jan 05, 2011 | GE Profile GCG1580LSS 15" Built-In Trash...
I have a GE trash compactor I have to hold up the foot pedal for it to work. When I let it go the compactor stops. thank you
There is a spring that holds up the pedal. It is broken or has come apart. By the pedal in the up position it is a safety switch allowing the compactor to run. You may have to repair this or simply put a small block under the pedal of the unit to run.
I hope my suggestions helps and all the luck to you.
burdfrenzy
http://stores.ebay.com/Pittsburgh-Joes-Pants-Nat
Dec 23, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
Whirlpool Compactor: starts making banging noises....
it sounds like there is something in the motor or a gear is getting ready to go out i suggest calling ge if it under waranty
Nov 15, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
HIT FOOT SWITCH AND MOTOR RUNS AND CUTS OFF WITHOUT COMPLETE CYCLE
trouble in ur wire going to the swtich contact ge about this problem looking forward to helping u Shaun
Aug 18, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
GE Profile GCG1580LSS 15" Built-In Trash Compactor with 1.4 cu. ft. Capacity, Hidden Controls & Remo... Logo
943 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
