Question about Garden
LT1045. Starter motor will not start. Removed it
LT1045. Starter motor will not start. Removed it from engine, and it works. Battery is fine.
Is there a relay or fuse issue? 20A fuse
on side appears fine.
Thanks,
Art
dartperry@comcast.net
  • 1 more comment
  • dartperry Sep 12, 2009
    Yes, the engine itself turns. It would start if only the engine starter motor would work. Since the starter motor does not start, I cannot get the engine to start.
    I have good battery. I have removed the starter motor from the engine and hooked it up to a power source, and it worked. So, it would appear, to me, that the problem is somewhere between the key and the rest of the electrical system.
    When I turn the key, with the starter motor reinstalled, the lights turn on, but the starter does not. No clicks, no sounds, nothing. With the key on, and I engage the electric clutch, I hear the clutch engage appropriately. So, it appears electricity is getting to the lights and the clutch. From there, I cannot tell. I did confirm the cut-out switch under the seat is functional.
    Now, I am stumped. Are there other cut-out switches to check? Anything else?
    THANKS!,
    Art
    yes
  • Donnie Wilson
    Donnie Wilson May 11, 2010
    does your engine turn over freely?
    President:
  • 986 Answers
You will have a starter solionid follow your starter wire and you will find it there will one wire from the batt and one to the starter and one small wire I bet when you find this solinoid the small will has came unhooked,Thanks I hope this helps you
Posted on Sep 12, 2009
I have a Cub Cadet lt1045 the starter clicks up to try and turn the engine over but the engine is stuck. Any ideas on what it could be
I had a similar problem with my car. It turned out to be the starter motor was sticking. Put in gear and rocked it back and forward to move the pistons. Tried again to start and it worked. Eventually had to replace the starter.
I know yours isn't a car, but might be worth seeing if that works.
May 21, 2016 | Cub Cadet Garden
Engine starter spins and will not start motor somethines.
Remove the engine cover to expose the starter motor (or take the starter off). Lubricate the starter bendix, its the gear atop the starter motor shaft, use Marvel Mystery oil and then work the bendix a bit and it should fix it. If the teeth on the bendix or flywheel are damaged obviously that is where the problem lies.
Jul 16, 2014 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Solenoid clicks cub cadet lt1045 mower won't start. Has new solenoid, starter battery and spark plug
It is possible the starter safety circuit is triggering. This is an interlock to prevent injury when starting and checks for things like driver not on seat, park brake engaged, etc.
Refer page 12 of the manual available on this site if you do not have one.
http://data.manualslib.com/pdf/4/341/34016-cub_cadet/lt1045.pdf?6c17c6482511338711d5965e5bb6681c&take=binary
Apr 23, 2014 | Cub Cadet Garden
Suzuki Vitara 2007
The battery terminal connections is loose or corroded.
Battery faulty or discharged, if the cable are clean and tight on the battery turn the key to the ON position and switch the headlights or windshield wipers. If they won't run then the battery is discharged.
Broken, loose or disconnected wires in the starting circuit.
Starter motor pinion jammed in flywheel ring gear.
Starter solenoid faulty, Starter motor faulty, Ignition switch faulty.
Nov 23, 2013 | Suzuki Cars & Trucks
Engine will not crank on lt 1046. New battery. Seat switch is working. Seems like the clutch safety switch. Any ideas. thanks. Bill
both the seat and clutch safety switches must be working for the unit to start, ( or at least for checking purposes be Jumpered) but for your unit check this link for a breakdown of your machine (Lt1045 anyway ) http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1045+Tractor+%282007+%26+before%29
May 27, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
STARTER WONT TURN ENGINE SOLENOID CLICKS BATTERY IS FULLY CHARGED
Do you have 12volts dc to your starter when your solenoid clicks?
if not replace solenoid,if yes check starter next and then be sure engine is not siezed?
Apr 30, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
My 2004 330ci won't start, does not turn over. The battery is fine, all electrical in the car work fine, plus trying to jump car does not work & a green light is showing on the battery in the truck....
If the battery is fine, why jump it? Faulty thinking to state or think: all electrical in the car work fine. If it did the starter motor would be turning the engine over. The starter motor work on electrical...not all is fine.
check: 1) 60a starter fuse/relay. 2) voltage to starter when turning key to activate starter motor, this will rule out ignition switch or relay. 3) apply direct voltage to starter motor to detect bad starter motor.
Jul 02, 2010 | 2003 BMW 330
The bike was running fine in the evening. Rode to work parked the bike took the key out. The battery was dead in the morning. Put the 10 amp charger on and the motor started to turn over with the key off!...
your starter button is malfunctioning. maybe some oxidation in the switch. when starter button is pressed in that can cause your other electrical stuff to not work.
May 16, 2010 | Motorcycles
Have a Mitsubishi starter for a small 3 cylinder (Toro Mower)
Removed starter and tested with new battery and jumper cables...starter worked fine. Replaced battery and cleaned cable attachments...unit started as usual.
When starter throws this would indicate that the interconnect circuits are intact..the engine still would not turn...that leaves the battery, the cable, or a siezed engine. The engine flywheel turned easily...no siezure. That left only the battery and cable. Battery was 3 years old...cable was corroded...bad combination. Battery was replace and corrosion removed from the cable terminals...started first crank.
Apr 12, 2009 | Diesel Garden
My briggs&stratton ohv 17 hp electric starter will not turn over
I worked at a tool rental center while attending college and encountered the problem that you are having many times. The problem was caused be a variety of issues however can be determined by checking the following:
Worn starter motor bearings that would be indicated by higher than normal amp draw. Check for hot starter motor or hot cables.
Weak battery. The battery should be removed and tested for free at auto parts store. The battery should be replace every season to extend the life of the starter motor.
Belts or hydraulic pump that is not fully releasing from engine pulley or output shaft. Remove the spark plugs from the engine and tune engine by hand, it should turn rather freely.
Finally, compression release feature of engine is not working properly. Check engine service manual for proper adjustment of valves so that compression release will work. Finally check oil level for over full. Too much oil will raise compression. Good luck with your problem and email for more info.
Feb 12, 2009 | Garden
Garden Logo
206 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
