Question about Mitsubishi WS-55809 55" Rear Projection Television
Service menu ?
I can't get into the " Service Menu ". I tried a bunch of different ways with no luck.
  • 4 Answers
Try on remote, pressing: menu 0,1,5,7, it should work.
Taz
Posted on Dec 11, 2007
RCA 42 in Replaced the 42RE010C878LNA0-A1 Board now a good picture but upside down how do I fix it
from remote press menu and highlight contrast enter code 1950 and see the service menu comes up. if not try 9735 same way.and change product id in service menu. try different .ids. each time you change id unplug tv and plug in .see if picture change.or do same process each time until show good.
Jan 19, 2015 | RCA 42la45rq 42-inch 720p lcd tv
Service menu?
Jand,
Try unplugging the Tv for about 15 minutes then plug it back in and power it up. That should clear the micro of any settings lock and restore the Tv to factory settings. Then see if you can change to your different inputs.
Bill
Dec 01, 2007 | JVC AV-36D104 36" TV
Tip
Service menu codes mitsubishi
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
# Using the remote control press:
{MENU} {0} {3} {5} {3} buttons.
{MENU} {0} {3} {5} {7} buttons.
# Then use {VIDEO} or {AUDIO} buttons to enter two different groups of adjustments.
# {VIDEO} and {AUDIO} steps along through the adjustments, and {+} {-} does the adjusting.
# Press the {ENTER} button to save the change.
# Press the {MENU} button twice to exit service menu.
{MENU} {1} {2} {5} {7} buttons.
{MENU} {1} {2} {5} {9} buttons.
{MENU} {1} {3} {7} {0} buttons.
{MENU} {2} {3} {5} {6} buttons.
{MENU} {2} {3} {5} {7} buttons.
{MENU} {2} {3} {5} {8} buttons.
{MENU} {2} {3} {5} {9} buttons.
* Then use {VIDEO} or {AUDIO} buttons to enter two different groups of adjustments.
* {VIDEO} and {AUDIO} steps along through the adjustments, and {+} {-} does the adjusting.
* Press the {ENTER} button to save the change.
* Press the {MENU} button twice to exit service menu.
{MENU} {8} {2} {5} {7} buttons.
Mits VZ8 chassis Menus
Option menu, Menu 1270
Service Menu, Menu 1257
Convergence Menu, Menu 1259, 4 Fine,
5 Coarse, 6 Misc.
on Apr 29, 2015 | Mitsubishi Televison & Video
I've had my Sharp Aquos LC20E1U for a number of years. A couple of times recently it just shut off on its own. It started OK again the following day. However, last time this happened, it wouldn't even...
service menu procedure text changed by midge to work with Sharp LC-32P70E & probably the same for similar models.
There are probably ways of really messing up your set if you do the wrong thing from the service menus, so do this at your own risk:
To enter service menu, make sure the set is plugged in but turned off at the power button on the top of the tv,
then while holding both input button and volume down button, push the power button. Within about 5 seconds, the set will power up keep holding the input and volume down buttons until a small "K" appears in a box on the left side of the screen. Then press and hold the channel down and vol down buttons at the same time to enter the service menu.
Once the service menu is displayed on the screen, you can get the screen to display different levels of solid grey by pressing the number keys on your remote. i.e. press "1" to get a relatively dark grey, 2 for a lighter grey, and so on up to 6 which is a bright white screen; 7, 8, and 9 don't appear to do anything. (this was for adjusting grey levels, other settings are available too) Press any number a second time to return to the service menu...
Not sure wether the grey background settings apply, but for entering the service menu it does.
I think to get out of service mode you have to disconnect the TV from the mains and wait about 30 seconds.
it's some time since I used the service menu on the Sharp Aquos but I do remember you can do a full reset to factory settings as well as turn on, off and reset certain system settings too you will just have to experiment with the remote keys, I think the colour fastext key access different menu levels etc but as I said I am unsure, at least this procedure will get you there so you can try for yourself.
Hope this helps
Please come back to let me know if the service menu procedure works for you.
Good Luck
Midge.
Feb 10, 2011 | Televison & Video
I forgot the code on my xerox fax confirm f116
Check menu,8,2. You may be able to print out the road map on the different menue configuration.
You should be able to print out by
selecting menu ,*, 8 and printed with Menu, "*", 1.
Not seeing the machine is difficult to see the different ways the menus are going to.
Technical parameters are different and has a different enter mode. This needs to be researched further for explination.
Good luck, this may take a lead in the right direction.
Nov 12, 2009 | Xerox FaxCentre F116 Plain Paper Laser
Need to access service menu/mode
To access the Zenith service menu: Hold down the menu button on the remote control until the menu disappears. Then type in 9-8-7-6-enter. This should do the trick. Be careful what setting you change. I would recommend writing them down before you change any. Hope this helps.
Apr 30, 2009 | Zenith IQC50H95W 50" Rear Projection...
KV-9PT20 have a different service menu handshake?
It is an old model of 1994 and does not have service menu facility.
Not fault of remote, TV has no service data adjustment menu option.
Apr 14, 2009 | Sony KV-9PT20 9 in. Television
Overscan
For Factory Menu, press MENU 1 3 7 0
Service Adjustment Mode, press MENU 2 3 5 7
Convergence Mode, press MENU 2 3 5 9
Use the VIDEO or VIDEO buttons to enter two different groups of adjustments
Use the VIDEO / VIDEO buttons to toggle thru the adjustments
Use the + and - keys to adjust
When finished with adjustments, press ENTER to save
Press MENU twice to exit service mode
Hope this helps. You should look for the vertical height or size adjustment. Do not adjust anything you don't know about.
Dec 28, 2007 | Mitsubishi WS-65313 65" Rear Projection...
Accessing the service menu
This is the right way, what is wrong with set?
Oct 06, 2007 | GE 31GT659 31" TV
Alba 3406 tvd
Connect pin 1 & 5 together (momentarily with a small switch), on the remote control handset. with the tv already switched on, This will put the set into the engineering set up mode. You can step between the various options by using the -/-- button. the Mute button invites you to save your changes which I believe is saved when you next press the -/-- button. there are 18 different service pages in all, be very careful not to change things which should be left alone, as this menu controls the way this set operates. The menu button exits the service menu. I believe menu 13 should be the AV-SND options menu, you can select either DK-I-BG or M sound systems. only set one system to "on"at any one time. You may also need to check 14, the C- SYSTEM options Menu. Good Luck, A D.
May 05, 2007 | Alba DVD-513 DVD Player
Mitsubishi WS-55809 55" Rear Projection Television Logo
59 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
