I have a western digial scorpio HD in an external inclosure. My pc will not recognize it
  • Chris
    Chris May 11, 2010
    Hello Have you tried connecting it to a different computer? Is it formatted for windows, Mac or a PVR box? Reply with this info and I can offer some asistance, please try the drive on another computer before replying and if it works identify what each computer is running(Windows, Mac or Linux). Thanks for using FixYa, Chris
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Oct 07, 2009
    Scholar:
  • 98 Answers
Check if the USB cable is working. Check also your BIOS settings if the "PLUG and PLAY" is enabled. Stick only on that 2 things. Thank you.
WD 1200BEVS
you can pull out the hard drive from box and connect it directly with computer see if it can recognized it, can not install drive can be due to problem with the disk FW or Hardware.
try to listen the drive carefully, is there any abnormal noise, beeps ??
hope it helps.
Apr 11, 2014 | Western Digital Scorpio WD1200BEVS 120 GB...
WD2500BPVT Western Digital 250 GB Scorpio Blue is not recognized in pc. Tried 2 different computers already. I want to be able to get the data from it.
Sounds like the drive has croaked. You can get the data but expect to spend upwards of $1000 or more to a data recovery company.
Jun 06, 2012 | Western Digital 250 GB Scorpio Blue SATA...
I have a Satellite A20 that does not start up. I just installed XP in a new HD from the original set of Toshiba CDs, however the Notebook does not recognize the HD. I installed the HD in an external...
wow. i just dealt with this yeserday for somebody. we had to reformat the hard drive while it was in the external inclosure and then re install it on the computer. BUT FIRST check the connections when you put it in. that laptop was the most pain in the but to get the hard drive to seat properly.
let me know
Mar 20, 2011 | Toshiba Satellite A205-S4617 Notebook
External HD is not detected by laptop Windows XP
A common issue...I'm sure your hard drive is working fine, Windows is just not giving it an unused drive letter.
1. Insert the device (camera or usb drive)
2. Right-click "My Computer" and select "Manage".
3. Click on "Disk Management"
4. Right-click the item in the list that looks like your camera or usb drive, and then click "Change Drive Letter and Paths."
5. Click "Change".
6. Give it a drive letter that is not being used.
7. Click OK.
The device should work instantly after that.
Feb 09, 2010 | Western Digital Scorpio WD1600BEVS 160 GB...
MY PC WONT ALLOW MY EXTERNAL HARD DRIVE TO LOAD AND CANT LOCATE THE DRIVERS
If you are using Windows 98 SP2 or newer support for the external HD is built in. Installing drives shouldn't be necessary, just Plug & Play.
While it is possible the OS has become corrupted the most likely reason is a bad hard drive controller chip on the drive itself.
If very recently purchased I'd take it back to the seller and ask for an exchange. If that isn't possible, if the drive is still under warranty I'd send it back to the manufacturer for replacement. Look them up via Google and get an RMA # from their support staff first.
Feb 05, 2010 | Western Digital Scorpio WD1600BEVS 160 GB...
I am using SuperDuper to clone my 160GB MacBook Hard Drive to a 500GB Western Digital Scorpio Blue. My problem is that I cannot determine why neither the SuperDuper program nor the MacBook itself...
The Western Digital Scorpio Blue 500GB hard drive is formatted for PC, not Mac. The simplest way to get your MacBook to recognize this new drive--and therefore copy the files from your old drive--is to plug it in to a PC and format the drive. I was advised to format with FAT 16, as this would be recognized by my MacBook. Fortunately, the process was not that involved, since the Vista-driven PC found the drivers for the WD Scorpio Blue automatically. Once formatted, I safely removed the drive and plugged it into my MacBook via a USB port using a BYTECC Drive Mate. Magically, it now appeared on my MacBook Desktop and was recognized by the cloning software I was using, SuperDuper. Three hours later, the files on my old hard drive were successfully cloned onto the Scorpio Blue--except now I had an additional 364GB of storage space. Swapping out the old drive and replacing it with the new was not a big deal at all--just make sure you have the right screwdriver for the last task--a Torx #6. Mission accomplished.
Oct 24, 2009 | Western Digital Elements powered by WD 320...
Lost my installation CD for my Western Digial external hard drive
If you register your drive on http://support.wdc.com you will be able to access the software that came with your CD.
Jan 24, 2009 | Western Digital 500GB My Book World...
HD laptop Dell ispiron 2200
You have to look for a ATA-6 5400 RPM hard drive.
e.g. you could use the Western Digital Scorpio 160 Gb
If you need more help, just post some info back.
Apr 21, 2008 | Dell Inspiron 2200 Notebook
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
