Question about Garden
Troybilt 4 cycle trimmer (TB475ss) won't start. New tank, new plug, new gas??? Will occasionally start, run for about 10-15 secs, then stops. Won't restart. Help!
Take the plastic cover off that covers the muffler and cylinder head. I've had 2 cylinder heads crack. The trimmer still ran but had little to no power and would not throttle up. First head cracked at the head bolts. The second one cracked above the bolts. The side that has the carb and fuel tank is harder to see and you must remove the carb and fuel tank to check. Also I've read online that this trimmer has a problem with the fuel line cracking at the bulb and in the tank.
Posted on Oct 29, 2009
I can not keep my weedeater running?
Mark, Ensure plug is good, remove,inspect replace in tn tank fuel filter if clogged, remove muffler and clean screen in side, carb., carb. could be dirty or out of adjustment or diaphragms worn out and needs rebuilding. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
http://support.mtdproducts.com/app/answers/detail/a_id/10666/~/basic-troubleshooting---handheld-string-trimmers-(gasoline-powered)
Toro String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Jun 11, 2016 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Model TB425CS WHAT IS SPARK PLUG GAP
Al, .025" is the plug gap for your trimmer,page 20 in your manual. There may be a recall on your model to do with safety.
http://lawnandgarden.manualsonline.com/manuals/mfg/troybilt/tb475ss.html
Troy Bilt Model TB425CS Parts
Troy Bilt String Trimmer Sold at Lowe Recalled for Laceration Hazard
May 15, 2016 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
My poulan won,t start ,i put new primer bulb on and new gas lines nowit won,t start
Flush old gas. Clean or replace spark plug. Check float on carb, clean carb bowl if equipped.
Jun 03, 2015 | Poulan Garden
Husqvarna weed eater starts , but blows alot of smoke & then stalls out
Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
Craftsman Trimmer starts then dies
How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
How to Clean Two Cycle Two Stroke Engine Carburetor
Sep 06, 2012 | Husqvarna 128 LD Weedeater
I have a Troy Bilt 4 cycle trimmer, TB475SS. The small fuel line in the gas tank has come off. I is about 6" long with a filter at the end. The trimmer can not **** any gas. How can I reattach it...
i would suggest to change all you fuel lines. troybilt uses specific fuel lines that they sell. you cant use your regular tygon fuel lines.
Sep 23, 2011 | Troy Garden
Troybilt trimmer primer bulb collapses. it will start occasionally but will only run a few minutes.i have replaced the primer bulb and gas lines and still have the same problems.
it should have a small vent in the fule tank cap if its blocked the primer bulb will be sucked in as the fule pump can **** any fule from the tank
check the tank cap first,,,,,
Aug 08, 2010 | Troy Bilt Tb70ss Gas Trimmer
What is the fuel line size for Troy Bilt TB525CS Trimmer?
Yes, something special to know. If the new fuel line is going into the gas tank, be sure to cut a steep angle on the end of the line going into the gas tank. This will allow enough of the line to get into the tank where you will be able to grab it thru the gas fill opening with needle nose pliers and pull it thru.
Apr 14, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Troybilt cultivator/edger starts, but dies under load
yes if it is a 4 cycle
with trimmer LEVEL Take out the plug and the oil level should be at the bottom of the threads where you took the cap off.
sae 30 weight is the oil to use
It can be a problem if you have no oil in the crankcase.
Be sure your stop button is where it belongs and go thru the procedures listed on trimmer to start it
fresh gas and if it is a 4 cycle you need not to mix oil and gas for this trimmer
May 25, 2009 | Troy Bilt Tb70ss Gas Trimmer
My TB475SS starts and then dies right away. i
It usually wont idle very well when it's cold, Goto #1 on the choke give the rope a couple of "quick" tugs, and then move it to #2 Give it one or 2 more tugs with a little throttle, now it should be running witha little throttle, let it run like that for a minute then move it to #3 kinda still pumping the throttle a little and it should take off fine. If this is the 4 stroke, mine did the same thing until it was broke in good. (About 4-5 uses), now I have to say its more reliable than any 2-stroke I've owned and I use it commercially. 1st or 2nd pull everytime and is ready as soon as it fires! Hope this helps!
Apr 14, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Garden Logo
1,217 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
