Question about Cameras
Sakar MC zoom 1:3.5, f=80-200mm
I have a sakar MC zoom 1:3.5, f=80-200mm lens, Is it possible that i can use it to my MINOLTA MAXXUM DYNAX 3xi? what adaptor will I need? Please help me experts..Thanks
4 Suggested Answers
  • 37 Answers
SOURCE: Frozen zoom lens
Sounds like there is a misalignment internally. This will probably need to be repaired at a shop.
Posted on Nov 03, 2007
  • 37 Answers
SOURCE: Camera lens
It sounds like a CPU chip incompatability issue. Sigma has that problem sometimes but are usually very good about rechipping at no cost (at least for Nikon-mount lenses). What did they say when you asked them?
cammedic
  • 667 Answers
SOURCE: mounting a teleconverter on a minolta camera
AS you have found out, the Maxxum AF mount and the MD mounts are much different. They do make tele-converters that allow the use of MD (non-AF) lenses on a Maxxum series camera. You would still need another adapter to make the MD Tamron converter work,
Posted on Jan 08, 2008
What size lens fits a Minolta Maxxum 3xi??
It depends entirely upon what you're after and the type of photography you wish to undertake.
Any Minolta AF mount lens will fit. 28mm is a standard wide angle, 50mm is a standard lens with a field of view approximately the same as the human eye, 80mm is a slight telephoto and for distant subjects 200mm is a long telephoto. Some lenses combine a few into one, they're called zoom lenses and will typically be something like 35-70mm, or 70-200mm. The measurements relate to the focal length of the lens, but generally the larger the number the longer the lens sticks out at the front. Zoom lenses are bulkier and heavier than fixed focal length lenses, but they're also the most commonly used types these days.
Sep 03, 2010 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
I have a Maxxum 7000i 35mm camera and in the display there is the word Help flashing what does this mean This happend after i tried a differnt lens, the lens opened than closed The lens that i tried was a...
Konica lenses do not fit Minolta cameras. I think you messed something up.
Minolta MC and MD lenses worked on the older manual focus Minolta bodies. They will also work on the Phoenix and Seagull clones of the old Minolta bodies.
The Konica lens should only ever be mounted on a Konica camera.
Your 7000i is now a Minolta paperweight. You need to send your 7000i for repair or replace it.
You could also look on Ebay for another Maxxum body to use your lenses designed for the Minolta A mount. As a rule, camera lenses are not interchangeable. You can use any Maxxum lens on any Maxxum body as a rule, but Minolta changed their flash shoe after the original 7000 series. Flashes that work with your 7000i will work with any subsequent Maxxum.
lightspiritphotography.com
Oct 25, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Minolta maxxum 3xi how to use the camera
Hi
You can download a complete users guide to your camera from this link
http://safemanuals.com/user-guide-instructions-owner-manual/KONICA%20MINOLTA/DYNAX%20MAXXUM%203XI-_E
Just click on the PDF on that page to get the whole guide.
Hope this helps. Please do rate this answer. Thanks.
Sep 02, 2009 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Looking for Digital Camera to use lens
Your Minolta QTsi Maxxum takes a Konika Minolta AF lens. These lenses work on these Konika Minolta DSLR cameras:
DYNAX 5D / Maxxum 5D
DYNAX 7D / Maxxum 7D
Dec 16, 2008 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Auto focus quit working.....Help !!
google its user manual
changing lens from stock might be the issue
or 8 years auto focus sensor may be stuffed
Apr 11, 2017 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Rewinding
Hi - You can download the manual from the link underlined in blue below:
Maxxum 3xi part 1
Maxxum 3xi part 2
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 17, 2008 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Manual
Maxxum 3xi part 1
Maxxum 3xi part 2
Informatica
Lens adaptor
The good news is that it is possible to get the camera to operate with the lens & adapter :-)
The bad news is that you'll only be able to use it in manual mode :-(
To get the camera(s) to actually fire, you will need to change some settings.
For the Maxxum 7:
Go to Custom settings (No.16) and change to 'Lock Off'.
For Maxxum 7D
Go to the settings menu (purple cog icon) and then to sub-menu 3. Change Shutter lock to Off.
With the camera set to Manual mode, you can still use the built-in meter. Half-press the shutter button and you will see a metering scale appear in the viewfinder. This will indicate whether the shutter/aperture setting you've selected will over/under-expose the image. Adjust your settings until the indicator bar is over the zero.
Hope this helps,
Matt.
PS. Even if you could somehow modify the adapter, the lens won't have the necessary electrical and mechanical coupling for the cameras to control it in an automatic mode.
Mar 05, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
Cameras Logo
445 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
