FAN MOTOR NOT WORKING IN PANASONIC SPLIT SYSTEM CU-C24DKU. WHERE CAI FIND IT OR A REPLACEMENT
  • 1,238 Answers
Http://www.panasonic.com/consumer_electronics/bp_split_ac/pdf/CS(CU)-C18(24)DKU_sm.pdf
Go to this site. It has your unit manual. Check it for part numbers and possible solution. Hope this helps.
Posted on Sep 12, 2009
I got a C9 error on a C12AWR artcool split ac which doesn't work anymore i replaced the mainboard of the outdoor unit which didn't help i replaced the fan motor which didn't help either does...
Split = Outdoor unit fan problem. Check Outdoor fan motor is plugged in, Electrically & Mechanically sound, if not replace motor, otherwise replace PCB. Multi V
= indoor PCB failure. Replace PCB.
Let me informed again if problem persists,.
Oct 25, 2011 | LG LA185HV Split System Air Conditioner
Airswing function not working on panasonic aircon split system
Remove side screws and pull out the PCB compartment, and check wiring to swing motor. Most of the time, the clip would have been removed on transportation or during service time. If connection is good, replace swing motor. Thanks.
Feb 05, 2011 | Panasonic CW-XC83HU Air Conditioner
Panasonic Split system turns off all the time
May be your fan motor mechanism blocked. Open the cover and rotate blower motor manually. If it's struck, replace bearings or motor.
Dec 26, 2010 | Panasonic Heating & Cooling
Panasonic split system fan motor overheas
put the lubricants or grease motor bearings
Oct 10, 2009 | Heating & Cooling
Fan motor not working split ac
jump motor to proper voltage to test.
if it does not run it is bad and needs to be replaced.
Phil
Jun 11, 2009 | Dayton Permanent Split Capacitor Motor Fan
Lg split system ch 05 error outside fan not working
Solution # 1, Check Condensor Fan Motor Capacitor 4uf or MFD
# 2, Check Motor Windings
# 3, Check Relay OR Defination Contactor
# 4, Check Connection Terminals
hope will help u 2 solve this
GOOD LUCK
Jan 26, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Panasonic Split System Air Conditioning.
we have a old national air con cassette model cu-5chv11p , works for three days , then controller comes on e4 error ,and then switches off , and will not reset .
Dec 28, 2007 | Heating & Cooling
Split system airconditioner Panasonic model CU-A28CKR.not responding to remote
Try turning of the power to the unit.Wait 60 seconds and try it again.This may reset the unit.
Nov 24, 2007 | Heating & Cooling
Heating & Cooling Logo
208 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
