Question about Garden
Line does not last more than 30 seconds - Garden
Trimmer won't prime to start
Look inside the tank. Some units have a stone inside that blocks the fuel line when it is tipped a certain way. Might be what's happening here.
Aug 13, 2016 | Garden
My 2 year old 42" LG TV picture & sound cycles in & out. Center power light pulsates when out but solid when on - line sleep mode. Cycle lasts 30 - 40 seconds
Here is LG's toll free number 800 243 0000. I hope this helps? They are very helpful! Thank you and please leave your feedback for me.
Jul 11, 2016 | LG 42LN5300 42" LED TV 1920 x 1080, 60 Hz,...
Speedqueen flame stays on for only 30 seconds then goes out, puffs back towards gas valve
when was the last time you cleaned out the dryer and vent line,if the air can't move to the outside vent the gas will shut down,remove the vent line from the back of dryer to see if it runs longer,also clean out the duct where the lint filter slides into,it sounds like you have lint blockage either in the dryer or in the vent line.
Jan 15, 2014 | Speed Queen AGS17AWF Gas Dryer
Frozen fuel lines
Frozen fuel or maybe oil is too thick. What Weight oil was put in at last oil change?
Jan 08, 2014 | Dodge Grand Caravan Cars & Trucks
I have an oil monitor heater. it works fine but once it reaches the set temp it makes a horrid howling sound lasting from 10-30 seconds.
I THINK JUMM UR OIL LINE.WHEN UR HEATER IS START & OIL PASSING UR OIL LINE IS JUMM.PLEASE CLEAN THE LINE. OR, LOOSE CONNECTION U CAN CHECK UR HEATER ALL CONNECTION . IF ANY CONNECTION LOOSE IT MAKES SOME SOUND...
Dec 29, 2012 | Heating & Cooling
Can a security issue preventing the 1998 deville from starting be fixed?
Yes it can turn your key to ON not crank for 12 minutes then to off for 30 seconds then to on for 12 minuters then off for 30 seconds then to on for 12 minutes and then off for 30 seconds. Be sure NOT TO crank the car at any time during the procedure. after the last off for 30 seconds start up your car and it should be reset.
Apr 09, 2010 | 1997 Cadillac DeVille
34122 45200 56300 67428 785630 what is the next line ? explain the pattern
We can solve this problem by taking digit by digit.
First and second digit,both are increased by 1,respectively
34…,45…,56…,67…,78…,89…
Third and fourth are the multiplication of first and second digit
3 x 4 = 12
4 x 5 = 20
5 x 6 = 30
6 x 7 = 42
7 x 8 = 56
8 x 9 = 72
so now the series become
3412.,4520.,5630.,6742.,7856.,8972.
Last digit equivalent multiplying the third and fourth digit:
1 x 2 = 2
2 x 0 = 0
3 x 0 = 0
4 x 2 = 8
5 x 6 = 30
7 x 2 = 14
34122,45200,56300,67428,785630,897214
Mar 05, 2010 | Mathsoft StudyWorks! Middle School Deluxe...
Backlight not lighting
Yeah - I know the problem though my "kid" is 51!
Select Menu > Settings > Display settings and then:
Backlight time—to set whether the backlights are switched
on for 15 seconds (Normal), for 30 seconds (Extended), or
not at all (Off). Even if Off is selected, the backlight stays on
for 15 seconds when the phone is switched on.
It's the last line that worries me, though: if your "kid" has caused the backlight to FAIL, then you're faced with no backlight, or a repair/replacement bill!
Kids, eh? Who'd have'em?!?!?!?
Apr 29, 2009 | Nokia 2310 Cellular Phone
Normal pictures fades to blue screen within 30 seconds
The fix for this is here somewhere, as I had the same problem last January and the solution was posted here in March last year. I'll try to find it and post the link to it for you, later.
Nov 06, 2008 | Sony KP-51HW40 51" Rear Projection...
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
