Question about Kenwood Radio TK 260 360 270 370 2100 3100 Compatible Battery
Front panel turns off
My Kenwood ts-2000 radio has develop a problem where the front panel shuts off. The radio is still drawing current and sometimes I can turn it off with the power switch but not always.
Have you performed a FULL reset on the TS-2000?
To perform a full reset:
With the power off press and hold down the A=B button and with the other hand turn on the TS-2000.
After that you will have to press the A=B one more time. The radio will reset itself,
and the display will show 14.000 MHz in the main band, and 144.000 MHz in the sub band.
Please let me know if it worked for you.
Tommy
KG4TDM @ arrl .net
Posted on Nov 09, 2009
Kenwood ts-440. Not transmitting.
Gee Randy, you didn't give a lot of information about your problem for us to go on. Does the radio go into transmit but no power is produced in the AM mode? AM is the first mode to check. Make sure that you have your RF POWER control turned fully clockwise. You should see about 40W of output. If you don't see any output, check for the DC current draw using an ammeter. Look at the current (radio set to AM Mode) during receive, and them go into transmit. If you don't see a substantial rise in current, then is is likely that the PA amplifier has problems, very likely that the output transistors are blown. There is an internal fuse that you should check. That doesn't usually blow, but every once in a while, it will open.
Oct 07, 2017 | Kenwood Radio Communications
How do i turn off the tnc indicator on the ts2000
per the manual the main band is the default for the built in terminal node controller you may have to change it manually by pressing the vfo A or B.
Oct 24, 2014 | Kenwood TS-2000
Kenwood ts-2000 internal antenna tuner fail to tune
it's not failing to tune, it shutting off as tuned. 1.25:1 is below it's threshold to tune
Feb 05, 2014 | Kenwood TS-2000
Ts-2000 doesn't TX
Driver & or Final transistores?
Jan 28, 2014 | Kenwood TS-2000
Kenwood TS-2000 no PC link,
Hi Tim,
I Hope This Helps You: join yahoo group specific to your radio Make/Model, I'm certain that you will get the advice you require and you can download manuals, diagrams and other great, useful goodies.
Regards,
Peter
Feb 02, 2013 | Kenwood Radio Communications
How hard is it to replace the finals in a kenwood ts-2000
Hi Damon,
It's Bloomin' hard, and it's tricky if you have little technical knowledge.
Yes Kenwood is a darn good brand, so to keep your Kenwood darn good, pay for the repairs, it's darn worth it.
Cheers,
Peter
Jul 02, 2012 | Kenwood TS-2000
Kenwood TS-2000 low UHF RF output
Hi Robert,
Lightning damage is disarsterous for anything electronic, let alone a 2-way, I believe that there is something else that's been overlooked and it could be the RF switch on the board.
This unit needs to go and get a radio doctors opinion, else the radio may eventually die a slow death.
Kenwood is a good brand and if you paid good money to buy it, you need to spend a reasonable price to have it checked out.
That's my only advice for you.
Regards,
Peter
Nov 18, 2011 | Kenwood Replacement Batteries: KNB15MH...
TS-570 shuts down
SOUNDS LIKE LOW POWER CAPACITY OF POWER SUPPLY. MANY NEW RADIOS WILL POWER OFF IF THE POWER SUPPLY SAGS AT TX. BY REDUCING THE POWER OUTPUT YOU REDUCE POWER DRAW AND DOES NOT SHUT DOWN. CHECK CONNECTIONS ON POWER INPUT OR TRY A LARGER OR DIFFERENT POWER SUPPLY. ALSO CHECK SWR SHUTDOWN.. GOOD LUCK. KB9JNO
Jan 03, 2009 | CTG Auto T-Switch
TS 2000 KENWOOD TRANCEIVER
I have the same problem with my TS2000 , in VHF I can heard small signals only if I turn on the PRE Amplifier ...
It start just few hours of use .
Jul 31, 2008 | Computers & Internet
Kenwood Radio TK 260 360 270 370 2100 3100 Compatible Battery Logo
311 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
