Question about Kenmore 24032\24036 Top Load Washer
Kenmore washer fills up and stops - Kenmore 24032\24036 Top Load Washer
  • 5,911 Answers
Check your lid switch.
If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain, this is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If the switch is not activated by a lid strike, it will activated by a hinge actuator located next to either the left or right lid hinge. You will need to remove the operator console in order to access this type of switch.
If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
A new lid switch (if needed) can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. All these sites offer competitive pricing, so shop all them for the best price.
Posted on Sep 12, 2009
Kenmore he2 won't stop filling
sounds like a faulty inlet valve. if its got 2 pipes at rear too fill. turn 1 off and if it still fills the other 1 is faulty and vise versa
Jun 18, 2014 | Kenmore HE2 Plus Front Load Washer
Kenmore washer fill with water then stops. Replaced lid switch, still doing the same thing, fills and stops
Sounds like you washer timer isnt advancing. If so then you will need to buya new one. Try Ebay for good prices. Good Luck
Sep 24, 2011 | Kenmore 22422 Top Load Washer
My Kenmore washer would not stop filling with water. i checked and the pressure sensor hose was of the switch, i rehooked it, but it still does not stop filling with water. do i need to do something...
Hello.
Kenmore washer come in a variety of s and styles,including extra-large dishwashers and dishwashers that are accessible for thedisabled.
A Kenmore washer automatically resets itself every time a washingcycle completes.
If you want to reset an Kenmore washer in the middle of acycle, you can easily do so. Resetting a Kenmore washer takes only a fewseconds to complete.Instructions.
1 Press the"Start/Stop" button.
2 Hold the buttonfor three seconds and release.
3 Select the program and options on the frontpanel you want the dishwasher to use. Press "Start/Stop" to restartthe dishwasher. You have now reset a Kenmore washer Thanks.
Jul 30, 2011 | Kenmore Washing Machines
Washer wont agitate or stop filling on any setting
Hello Friend, Just replace the water pressure/level switch. Replacement will make it fill correctly and agitate. Happy to help.
Nov 18, 2009 | Kenmore 24712 Top Load Washer
Kenmore washer won't stop filling during initial wash cycle
I had the same problem too on one of my washers (not kenmore) it didn't complete cycle because someone turned off the hot water valve. soo i turned on the hot water and it worked fine. keep in mind that mine wasn't a kenmore. hope this helps some...
Oct 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer won't stop filling and go to next cycle automatically
if not running over ck to be sure drain is proper height and end of washer drain hose is not too tight in standpipe sound like siphoning after 1st wash and not filling to advance to rinse also be sure washer dring hose is not more than 6-8 in into standpipe
Aug 15, 2008 | Kenmore 24032\24036 Top Load Washer
Series 70 Washer Won't stop filling
yes and also make sure fill tube is not clogged or debreed
Jul 05, 2008 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
69 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
