Question about GE Profile¿ Arctica® Energy Star® 25.5 Cu. Ft. Side-by-Side Refrigerator with Dispenser, PSS26MSRSS
PSS25S side by side is freezing vegetables. We
PSS25S side by side is freezing vegetables. We keep increasing the temp on the refrigerator controls but it keeps freezing food.
    Sergeant:
    Champion:
  • 214 Answers
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Posted on Sep 12, 2009
Temperature wont set above 32
*sigh* Yet another bad Chinese made motherboard.
Mar 13, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
My vegetables keep freezing in the fridge, how do i get the fridge at the right temp?
Remove the vegetable/ produce/ meat draws and shelving that support them. Look along the rear wall or the left inside wall for vents that are feeding or directing cold air to the draws. First try to shut or close these vents down. Or you can tape over them to restrict the flow . The normal refrig temp is between 37 to 40 deg.
Jan 20, 2013 | Viking VCSB423 Side by Side Refrigerator
Refrigerator thermastat set to 37 degrees but registers at 28. Freezer set at 0 degrees but registers at -2. Frig/freezer do not feel that cold but vegetable bin (produce bin) in refrigerator is...
i have never seen the problem
my idea is the thermostat is bad. but won,t both of them be bad.
you try to check the damper motor swithch and damper motor
good luck
Jan 12, 2011 | Frigidaire FRS26R4A Side by Side...
Food (vegetables, fruits) on the refrigerater side freezing
Your model has a control damper inside the vent. The damper opens and closes with changes in temperature. It has a pig tail spiral thermostat on the side and if it goes bad the door sticks open or closed. Sometimes it is just frost but you will need to get to it. I will send photos and links in a moment, Thanks Sea Breeze
Jan 20, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Vegetable crispers freezing my vegetables
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Dec 17, 2009 | Refrigerators
Vegetables freezing
Most side by side refrigerators use the freezer to supply cold air to the refrigerator side. They use a duct through the wall between the two sides to let COLD air come into the refrigerator. That cold air will be blown upon the drawers at the bottom, where you are storing your vegetables.
There are two adjustments - or three, depending that will change how the air comes through. The freezer control will set the base temp for the freezer, and thus the temp of the air coming into the reefer to cool it down. The reefer can have a movable vane that increases or decreases the amount of air flowing in from the freezer, the vane being operated at the command of the refrigerator temperature control. Some have a movable plate that limits the flow of air on a fixed basis.
Set the freezer for 0F. Adjust the refrigerator setting, starting in the middle of the range, until a thermometer on a middle shelf, will read at 40F. Take your time, and check once an hour or so, to let it stabilize.
Make sure that you are not blocking airflow in the refrigerator, as the air must circulate to avoid too low a temperature in spots, such as you are experiencing.
May 21, 2009 | Whirlpool ES5FHAXS Side by Side...
I have a GE side by side GS25LGM. The fridge side gets too cold that it freezes the vegetables. There is a humidity control on the vegetable bin. It didn't matter if I set it to high or low it still...
try turning down the thermostat for the freezer side some times the controls seem backward. However most fridges are desighned for thwe freezer side with some thought giving to pushing some air to the refrige side. in most cases it easier to start back at medium settingsfor two or three days.
Mar 12, 2009 | GE GSS25LGM Side by Side Refrigerator
Vegetable draw is freezing the vegetables
if you pull out the vegetable drawer, you will notice a vent on the left side in the back. get some tape ( I use aluminum tape ) and cover the bottom half of the vent, that will help keep your vegetables from freezing. that should solve your problem. Joe
Dec 12, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Everything freezing in vegetable and Custom Cool compartment
you have a temp setting above those shelves left side has a porkshop and left side has a carrot i belive set to to the left side to vegies and see if it helps if still all freezes the you have a broken damper on top that letts air in when it does not needed
Sep 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile¿ Arctica® Energy Star® 25.5 Cu. Ft. Side-by-Side Refrigerator with Dispenser, PSS26MSRSS Logo
246 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
