Question about Microsoft Computers & Internet
Window ME protection error
When I start my compupter I get a bleu screen with the following message:
While initializing Device Config Mg.
Window protection eror.
You need to restart your computer.
System halted
I tried to use Window KB but I could not find the file they suggested.
I would really appreciate your help.
Thanks
  • 29 Answers
Hay found this Microsoft knowlege Base article that might help.
http://support.microsoft.com/kb/187612
Since your computer probably came with ME I am thinking the second solution might work. Let me know if you have any more questions.
Thanks
Posted on Sep 13, 2009
When i start up wd my book essential it is not initialized. when i click offline setting i get error message that external drive is write protected. my drive is not partitioned or formatted but i cant do...
To initialize the harddrive do the following:
Start > Control Panel > System & Security > Administrative Tools
Then..
Computer Management > Disk Management
Then..
on the lower half of the window will be your drive. RIGHT CLICK and select Initialize.
Feb 28, 2011 | Western Digital My Book Essential Edition...
I have a asus eeepc 900 netbook.suddenly it stop booting & everytime showing"windows could not start because the following file is missing or corrupt:Windows/system32/config/system.You can attempt to...
Windows could not start because the following file is missing or corrupt:
/WINDOWS/SYSTEM32/CONFIG/SYSTEM
You can attempt to repair this file by starting Windows Setup using the original Setup CD-ROM
Select “r” at the first screen to repair
So then i click r at the first screen and nothing happens...It keeps on repeating to repair on and on with the same message after i clicked r. I can't even access to the window...what can i do???
Jun 15, 2010 | ASUS m6n Notebook
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
I get this error when I try to play a DVD on my laptop using WDVD
I assume that you are using a TV with the Computer to watch a Blu-Ray disc using HDMI connection.
In order to play a Blu-ray Disc (BD) movie on a television, the display configuration must be set to display on the television only. Having the image set to display on the computer and the television at the same time will generate the above STOP error message "Your display environment does not support protected content playback message".
Follow this procedure to properly configure the settings
needed to play a Blu-ray Disc (BD) movie on a television.
1. Connect the Computer to the TV using an HDMI cable.
2. On the Computer, click the Start -> Control Panel -> Appearance and Personalization -> Adjust screen resolution.
3. In the Display Settings window, click the Advanced Settings button -> Intel Graphics Media Accelerator tab -> Graphics Properties button.
4. In the Intel Graphics Media Accelerator window, under Operating Mode, click the down arrow and then click to select Single Display.
5. Under Primary Device click the down arrow and then click to select Digital Television, and then OK.
6. At the Confirm the Desktop Change prompt, click the OK.
7. In the Advanced Settings window, click the OK button.
8. In the Display Settings window, click the OK button.
9. In the Control Panel window, click Hardware and Sound.
10. In the Hardware and Sound window, under Sound, click Manage audio devices.
11.In the Sound window, click to select HDMI Device, and then click the Set Default button.
12. In the Sound window, click the OK button.
13. Now close the Control Panel window.
NOTE: Also check for any update for the software you are using to play the videos and update for the Video Driver
Good Luck!!!!!!!!!!
Oct 10, 2009 | HP Computers & Internet
Error code 37
Hi there
The Code 37 error may occur when the concerned device is not connected to the system correctly and when its driver is faulty. A code 10 error is common when you add or remove USB devices or video & sound cards to and from your PC. When these errors occur, you may receive the error message given below.
Windows cannot initialize the device driver for this hardware. (Code 37)
To resolve code 37 errors, first ensure that your device is properly connected to your system. For instance, check all the cables of your printer or check that your sound or video adaptor is properly seated in its slot.
Try to remove and reinstall the device, and run the Add New Hardware Wizard from the Control Panel to see if Windows detects and installs it. If this does not resolve the issue, then update the device driver by performing the following steps:
  1. Open Control Panel and select System.
  2. In the System Properties dialog box, select Hardware tab, and then click on the Device Manager tab.
  3. Scroll down the Device Manager window and identify the faulty hardware from the list.
  4. Right-click on the hardware and select Update Driver.
  5. Follow the screen instructions to resolve the error.
If these steps do not resolve your error, then the problem might be with your device. Get it checked by an authorized technician.
Good luck
Jan 14, 2009 | Computers & Internet
Error message on E260 player
Same problem delete a couple of songs up to 6 mg or 10 whatever then allow to refresh then download your songs back in the music file. the sansa needs some memory to know it has the sdcard in it...
Dec 28, 2008 | SanDisk Sansa e260 MP3 Player
Installation failure
I have already started to answer on the original thread!, let's keep the conversation in one place.
Oct 08, 2008 | Computers & Internet
Windows wont start up
NEED YOUR PC/LAPTOP REPAIRED......
ARE YOU HAVING ISSUES WITH YOUR PC OR NOTEBOOK NOT WORKING THE WAY YOU EXPECTED
well if your having issues with your wireless/black screen issues/bad-slow performance/
nb settings/error messages/recovery and restore/Internet Explorer/pop ups/Microsoft/sound
/software/hardware, pretty much anything at all why not try me FOR FREE at moonbayboys@hotmail.com
....i also help with the removel of virus/spyware/malware
Jul 31, 2008 | Toshiba Satellite A105 Notebook
Dhh-200
i need now how i carge my batt and i hear my muisc same time
Apr 14, 2008 | Won mobiBLU DHH-200-8 Digital Media Player
Computers & Internet Logo
27 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
