Question about Nintendo Wii Console
The wii remote won't turn on.
I try to turn on the remote but the lighs on the bottem just blink and turn off.I know its not the batterys because i just put new ones in!
  • John May 11, 2010
    It sound like its searching for the connection with the Wii. and if it doesnt find it,it will shut off. I know ther is a button on the Wii to help with pairing. I would suggest read that section in the manual, but I want to say that you have to hold the little red button and then try to connect.
    Problem Solver:
  • 5 Answers
Open the back part of the remote and take out the batterys then look at the bottom right and click SYNC. then open the sd card place that is on the wii. after click the red button then the remote will be conected to the wii and will start working
Posted on Sep 12, 2009
Wii Remote wont sync with the Wii
open the battery door on the remote, theres a red button. also there is a red button on the wii in the SD card slot press the one on the Wii then the one on the Remote.
Nov 28, 2013 | Nintendo Wii Remote Controller
Wii remote won't sync
  1. Press the Power button on the Wii console to turn it on.
  2. Remove the battery cover on the back of the Wii Remote to be synced. Open the SD Card Slot cover on the front of the Wii console.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED on the front of the Wii Remote will blink. While the lights are still blinking, quickly press and release the red SYNC button on the front of the Wii console.
  4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. This sync procedure must be followed for each additional Wii Remote added to the system.
Mar 08, 2012 | Nintendo Video Game Consoles & Games
The Wii turns on but the remote won't connect to the screen...all lights working also, bought a new sensor bar and still nothing...???
Turn on the Wii console, when at the home screen press any button on the wii remote, if the lights on the wii remote remain dark then it needs new batteries.
If the lights all light up at the same time then stop this means you are not synced. Press the 1 and 2 buttons at the same time to sync, this will work if they have been synced before.
If your four lights still blink blue then you need to open the little compartment on the console that is right below the disc tray. Inside is a little red button, press the button. Now open your battery compartment on the wii remote and take out the battery, then press the red button inside. Put the battery back in and the controller should sync up. If you are still having trouble you will need to contact Nintenedo Technical Support.
Hope this helped!
May 16, 2011 | Nintendo Wii Console
It will not pick up the remotes i know its not the sensor bar as i have tried that on someone elses wii
Have you made sure the remotes are linked with the Wii? To link a Wiimote with a Wii
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
This procedure must be followed for each additional Wii Remote added to your system.
Mar 24, 2011 | Nintendo Video Game Consoles & Games
When wii is turned on the start screen that shows the remot and asks to hit a comes up in three different languages can not move pass that? Remotes not responding
try syncing your remote by doing the following (and make sure batteries are good)
Jan 16, 2011 | Nintendo Wii Console
I just got the wii fitness but my wii remote does not want to conect the lights flash and then just stops and the remote don't work what can i do
have you tried syncing the wii remotes ?
Note: Make sure you have placed batteries in the Wii Remote.
  2. Remove the battery cover on the back of the Wii Remote you wish to sync up, and press the SYNC button just below the batteries. The Player LED will blink.
  3. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 to 4).
Dec 26, 2010 | Nintendo Wii Console
Wii remote will not work new batteries just blink all
Hey Jack, How many remotes are you able to connect at a time? If you have multiple remotes try turning the ones you know that work off, and putting them in another room(so you know they will not try to connect). Then try connecting with the bad one. If that doesn't work you might have to sync the remote: hold down the red sync button on the wii, located next to the sd card slot, while holding down the red button on the remote, located under the battery cover on the back. Now try connecting. If it still doesn't work, the LED lights in the sensor bar might have burned out, this happens a lot when you keep your sensor bar directly on your tv without the stand(the tv gets hot and burns out the lights), a lot of people do this because the stand looks bad. Go buy a new sensor bar, they sell them at wal-mart for $20, plus they're wireless, so you don't have to worry about that thin little wire popping. Test the new wii bar, if it's still not working, then you're remote is just worthy of getting returned.
hope this helps! -cj
Aug 21, 2009 | Nintendo Wii Console
Wii remote wont work
ITS THE BATTERIES, MUST HAVE BOUGHT BAD ONES,THEY DON'T LAST FOREVER IN STORES EITHER
Jul 15, 2009 | Nintendo Wii Console
Remotes won't turn on
ok,you changed the battery already but did you synchronize the remote to the console?beside the battery of the remote is a small red button.did you try to press this button? as well as the red button on the console?it is located on the memory card port of the wii.try it first,let me know
Dec 25, 2008 | Nintendo Wii Console
Wii remotes will not stay on
2. Remove the battery cover on the back of the Wii Remote you wish to sync up.
3. Remove the battery pack & install regular batteries.
4. On the back of the Wii remote press the SYNC button just below the batteries. The Player LED will blink.
5. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
6. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
7. Quickly remove the batteries and reinsert your Battery Pack.
8. Return to Step 2 for each other remote.
You may run into this issue any time your battery pack has a 0% charge left in it for a duration. Try to keep them charged to prevent it from occuring in the future.
Dec 16, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
110 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
