Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Everytime i try to run the washer it gives me a F1 reading on the dial, Why?
  • 15,935 Answers
Keypad/User Interface Failure
A fault code of "F" then "1" flashes when there is a primary control failure.
You will need to replace the machine/motor control assembly.
Page 14 and 16, in the manual link below will help you with this.
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
To Access/replace the CCU:
#1
Unplug the Whirlpool Cabrio power cord from the wall outlet. Turn off the water supply to the washing machine. Pull the washer away from the wall so that you can access the screws behind the control console. Remove the hex head screws securing the control console to the washer with a nut driver. The screws are on the lower rear edge of the control console.
#2
Lift the control console up, and rotate the console forward so that the face of the console is resting on the top of the washer. Locate the interface board cable connector to the right of the plastic tube on the back of the console. Pull the end of the connector straight out of the control console. The primary machine control is the box that the plastic tube connects.
#3
Place small pieces of masking tape around the nine wires connecting to the primary machine console. Label the wire locations onto the masking tape with a pencil. Grasp each wire at the connector with your fingers, and pull the wires away from the primary control. Pull the plastic tube out of the primary control.
#4
Locate the nut toward the bottom of the primary control. Remove the nut with a nut driver. Lift the front of the primary control slightly, and slide it down to disengage the retaining clips. Pull the primary control out of the control console. Insert the new primary control into the control console. Slide the primary control up to engage the lower clips. Secure the primary control to the console with the single hex head screw.
#5
Push each of the wire connectors into their respective positions on the primary control until they lock into place. Push the plastic tube hose over the port on the right side of the primary control. Remove the small pieces of masking tape from the wires.
#6
Position the control console back upright on the top of the washer. Secure the control console to the washer with the three hex head retaining screws. Slide the washer back against the wall. Turn on the water supply and plug the washer into the wall outlet.
TECH SHEET LINK: http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567037.pdf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
Reads F1 and the lights around dial all come on and flash
Hi
This is a simple one for me. you would need a new central control unit , part #W10189966
TY
Feb 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 comes up everytime you wash a load of laundry.
F1 = Primary Control Failure
F then 1 flashes when there is a primary control failure. Replace the machine control assembly
Thank you
Sep 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
When I start the washer the dial flashes and says F1
The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
Thank you !!
Aug 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error
Thank you !!
Jul 20, 2010 | Whirlpool LSR5132PQ Top Load Washer
Receiving the F1 code
Hi, ok so there was a recall on the control boards it's fine don't be scared all you have to do is call 1800-659-7026 give them your info and model and ser.# they will then send someone out to replace the control board it takes about ten min for all of it and it is all free no matter when you bought it. But in mean time quick fix for all of you is to unplug the washer then hit power then stop over and over tell there is no power left in it then plug it back in and it will work fine for awhile you may have to repeat if it does it again. But after they come out it will work fine. yes this has happened to me it sucks it took two years to find out what was wrong they didn't even tell us I had to ask alot of parts guys and look it all up. So for everyone that this is happening to I'm sorry I just hope this gets out to all of you because I work very hard to know my product and take care of my customers ask any of them and it's not easy working STRAIGHT commission and people don't want to come back for these kind of things. But remember the reason why you came there in the first place we will give you the lowest prices in town and we know what we are talking about, well most do if not they ask me:) so I really hope this helps someone out there.
Take care
Jun 15, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Code F1 Appears
It is the RPS sensor, cover by whirlpool. Get your model number and serial number ready and call the 800 number on the machine, tell them you heard it here that it is a recall so you don't get the run around. The sensor is located on the stater motor and comes with a new harness and cost you nothing.
May 15, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer was supposed to go in to spin cycle and alarmed with I believe F1. Is there anything I can do to fix this problem
There is a recall for the Cabrio for having the "F1" error(I had mine fixed by whirpool for free). Sounds like you are getting the F1 error code. If you have not had the washer repaired under the warranty program then you should give Whirlpool a call and get it repaired under warranty. When you call them say that you are getting the "F1" error code and have read on the internet that there is a recall. Have your model number,serial number and date of purchase available. They will send someone out to inspect the washer and repair if they have the control board in stock(they had to order mine and it took 2 days for it to arrive). I also located the phone number you will need to call for service...1-800-253-1301
Jan 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Only runs 2 mins then shows F and i clear it try to restart it it will start to fill then shows sd
Dec 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Code : E3 -F1-
I have an Inglis electric stove with a self cleaning oven We turned the left dial to "CLEAN" and when turned the right dial to clean, a buzzer went off. Can you give me any advise?
Oct 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
49 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
