Question about Samsung RB215LASH
Ice not dumping
The lever is down and the ice will not dump. You can use the manual dump button and the freezer beeps when the water is automatically refilling in the tray. What is the problem
  • 999 Answers
There is a thermostat in the IM to sense when the ice is ready. Check that first...Eric
Posted on Sep 12, 2009
Whirlpool ice maker quit.
If it's similar to my Samsung, mine did the same. There is a reset button at the front of the box which contains the ice cube tray. If you press it, the ice tray rotates to dump the cubes, then refills. Hope this helps.
Sep 03, 2017 | Whirlpool Refrigerators
Hi i have km-320-mwh hoshizaki ice machine, this machine is discharging water in drain continuesly except when it is dumping ice is this normal ...too much water is being lost please help many thanks...
By looking at the model number it is a water cooled unit. It will dump water down the drain continuosly as that it how it cools the compressor. If it was a MAH it would be air cooled and no continuos dump of water.
Aug 09, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Ice maker has ice motor doen't dump the ice
Your ice-maker may need to be "hard-reset". To do this, perform a manual-defrost by emptying out the freezer (and fridge) and shutting all power off to your unit for several hours (at least half a day unless you can be sure the temp in the freezer has fully reached ambient. Next, with freezer empty, restore power, make sure the "ice" setting is set to off, then set the forced power-freeze mode (you can refill the fridge, but leave the freezer empty for now. When the power-freeze completes (at least 2.5 hours) you can refill the freezer, set the "ice" mode to block/crushed (IE something other than off) and then hit the "black reset button" to restart the ice-maker. IF it still will not dump the cubes then the ice sensor/control board may have failed.
May 24, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
After 2yrs of not using the icemaker, moved
Good day,
Pour water from small paper cup until it near fills the well of the ice maker. With the lever down, close freezer door and wait 2 to 3 hours. If it dumps then the ice maker should be good, if not, replace ice maker.
If dumps O.K. then the dual water valve is bad, and needs replaced.
You should check the fill tube that runs from the back of the machine to see if it is blocked with ice. (requires removing ice maker) but even so, if it is iced, you'll need to clear, but the water valve in the back rear of the machine is leaking and still needs replaced.
Thanks for using FixYa
Dec 20, 2009 | Refrigerators
Ice maker stopped working
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Sep 05, 2009 | KitchenAid KSRP25FNSS Side by Side...
The ice maker suddenly stopped making ice. The "arm" is down. Should it be up?
arm down ...Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 16, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Ice maker not working doesn't fill or dump or make any noise, stopped suddenly
Make sure the lever is down first . if so ,pour about 1/2 cup of water into icemaker and see if it harvests (dumps) . If it harvests , then the water valve is bad . If not , and the ice stays in the icemaker , then the icemaker is bad .
Jul 12, 2009 | Kenmore 64522 Top Freezer Refrigerator
Icemaker not producing ice
Most automatic ice makers have a lever (looks like a piece of wire) that is prevented from being in the down position when the bin is full. This stops the ice maker from producing ice when not needed. The lever can also be lifted manually to a locked up position which turns the ice maker off as well. If the lever is in the up position, simply press down on it, it should release and return to the down position. Once down, the ice maker will begin producing ice again (the unit will have to complete its cycle before you see any ice, normally a couple hours or less). Hope this helps.
Please take the time to give this solution a fix ya rating.
clarkco
Mar 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not dumping ice
The freezer has to reach a certain temp. in order to freeze ive. You might have to wait overnight for ive-- keep the freezer closed.
Aug 27, 2008 | Kenmore 53642 / 53644 Side by Side...
Samsung Icemaker Problem
I also had the ice tray stuck in the dump position. I unplugged it waited 5 minutes and pluged it back in. And the Ice tray moved back into the correct fill position, and the arm did drop down, But now it has not filled with any water. So now what should I try?
Feb 20, 2007 | Samsung RS2534 Side by Side Refrigerator
Samsung RB215LASH Logo
164 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
