Question about Kenmore 62602 Electric Dryer
When you open the door to our Kenmore Dryer it does not stop tumbling
  • 6,784 Answers
HI. this will occur if the door switch is malfunctioning. The switch structure mat be misaligned, or the actual circuit may be damaged as well.
Inspect the switch for the above stated faults. If the switch is aligned correctly. simply replace the door switch. It is stuck closed.
Posted on Sep 12, 2009
Dryer still tumbles even when door is open. It will turn of and stop when i turn it manually to off
The door actuator mounted on the door or the switch mounted on the dryer is missing or broken. The dryer is supposed to stop if the door is opened. Replace the door actuator or the switch.
Mar 03, 2015 | Dryers
Dryer that wont stop tumbling
Well we know the door switch is functioning properly so that usually just leave a timer issue.
Dec 05, 2014 | Dryers
Opening door does not stop tumble dryer--kenmore 80
The door latch functions as an electrical interlock. If the dryer continues rotating with the door open, the latch may have failed or something may have gotten jammed in it
Oct 08, 2013 | Kenmore 62802 Electric Dryer
Dryer is tumbling but not heating
if you remove the back you will see the heater box to your right,at the top of the box is the heater fuse,also the bottom half of the box is the heater coil,it come off just remove the 2 screws,if you have a meter you can test it if not take it off and look to see if you see a broken wire anywhere,your model number is inside the door-mike
Jan 28, 2010 | Kenmore 63942 Dryer
Push start button the dryer will tumble, but immediately stops
there is a relay that latches on when you push the start button .. that relay is released by the "door open" switch .. i would suspect that the "door open" switch is bad .. thats usually a button that is pushed in when the door is closed ..
Sep 19, 2009 | Kenmore Dryers
Kenmore dryer wont stop, just cycles through all the setting
Replace the timer if it continues through and past a timed cycle.
Aug 03, 2009 | Kenmore 62802 Electric Dryer
Dryer works for few minutes then stops
clothes can open the door if door latch is weak, causing door opening and stopping the cycle, or a bad automatic sensor
Feb 17, 2009 | Kenmore 62602 Electric Dryer
Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Jan 21, 2009 | Dryers
Kenmore Dryer
check also,
  • the other ends of all cables connected to the relay,
    if the other end of any part of the latching circuit has loosened, the relay will not latch closed when the start button is pressed.
  • Door Switch, it is part of the latching circuit
Sep 21, 2008 | Kenmore 62872 Electric Dryer
TUMBLE DRYER SUDDENLY STOPPED WORKING. ALL LIGHTS FULLY FUNCTIONAL BUT THE PROGRAM WON'T START WHEN START BUTTON PUSHED. RED LIGHT IS FLASHING ON START BUTTON. mODEL WTE6920
I have a kenmore dryer, bought used, and it was working good but it now wont turn on. The light inside comes on when the door is opened, but no matter what the setting, it wont start. It's the Kenmore 70 series, front loading electric dryer. Is there a fuse or reset button I can try?
Sep 15, 2008 | Dryers
Kenmore 62602 Electric Dryer Logo
64 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
