Question about Roper REX4634KQ Electric Dryer
My dryer roper model number REX6634RQ1 WILL NOT HEAT OR TURN OFF IT TUMBLES THOUGH
  • 986 Answers
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Sep 12, 2009
Any help with reconnecting wires to heating element?
I would only be guessing but it was probably done wrong
Jul 14, 2014 | Roper Dryers
Dryer tumbles but wont get hot
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 14, 2011 | Roper REX3614KW Electric Dryer
The dryer heats up for a few minutes the continues to run with no heat it is a Roper dryer model number RGS7646KQ3
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 25, 2010 | Roper RES7648E Dryer
I have no heat i checked continunity on the element and replaced both thermostats but still have no heat. i have a roper dryer model number rex6634rq1
Check your electrical breakers
Be sure to check your voltage coming to the dryer at the plug and the machine back where the wires connect to the terminals you should have 220Volts.
I think this may be your problem with no heat.
This is a free answer, Please rate me
Oct 03, 2010 | Roper Dryers
No heat
Check out this tip... it will help you with your problem.
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Heatman101
Mar 22, 2010 | Roper RGX4634KQ Gas Dryer
My gas dryer stopped heating
I need your serie and model #
please
May 08, 2009 | Roper RGX4634KQ Gas Dryer
Dryer tumbles, no heat
its a gas dryer it doesnt have ,,heating element...replace thermal fuse
Dec 28, 2008 | Roper RGX4634KQ Gas Dryer
Roper dryer, timer doesn't time out and not heating up?
Dryer will run forever if it doesnt heat up, Dryer has to heat up and thermostat has to get hot and open to start the timer. Odds are rally great, it is your heating element.
Oct 01, 2008 | Roper REX4634KQ Electric Dryer
Roper REX4634KQ Electric Dryer Logo
298 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
