My air conditioner is working but only through the top vents not the front vents. Can not locate the vacumn pump . 2000 GMC Safari Van
    Problem Solver:
  • 9 Answers
If the heat vents are controlled by vacuum, the problem is most likely a lack of vacuum to the control panel, or possibly a bad control panel. These are usually designed to send all the air to the defroster if there isn't vacuum to the system. This is probably so you can keep the windshield clear so you can see to drive if there is a problem with the system.
The system gets its vacuum from engine manifold vacuum. This often comes from a manifold vacuum block mounted on the firewall in the engine compartment, or on the back of the engine close to the firewall. If you start the engine and listen for a vacuum leak (hissing noise) under the dash or under the hood near the back of the engine, you may find the leak. It might be a hose that fell off a fitting, a split hose, a broken fitting, or a leaking vacuum canister (these are often mounted under the hood on an inner fender, and are typically about the size of a quart jar, and may be molded plastic or a "tin can" that looks like a juice can with a vacuum hose connected to it). If you find a vacuum leak and fix it, that may solve the problem.
If your HVAC (Heating, Ventilation, and Air Conditioning) system is controlled by electric motors or actuators, rather than vacuum, you may have a problem with a sticking or defective motor or actuator. There are typically 4 or 5 of these that operate the doors in the ductwork to direct the airflow to the different zones, to control air flow through the heater core, and to switch to recirculate mode for AC.
Posted on Sep 15, 2009
I have been driving my 2000 GMC safari van I shut it off. And it won't turn or start
2000 GMC Safari AWD Suddenly won't start - Fixya
www.fixya.com/cars/t1464758-2000_gmc_safari_awd_suddenly_start
Dec 31, 2008 - 2000 GMC Safari AWD Suddenly won't start 2000 GMC Safari AWD, I have never had one problem with this van till now It - GMC 2000 Safari .
Aug 30, 2015 | GMC Cars & Trucks
Where is the fuse panel on a 2000 GMC Safari Van
Check by the drivers side kick panel. To the left of the brake pedal
Nov 10, 2013 | 2000 GMC Safari
The air conditioning does not blow through front vents but through windshield vents, what is the problem?
This is a common problem on all Astro/Safari vans. The problem is a leak in the vaccum lines that control the vaccum switch responsible for changing air direction from the defrosters, dash vents, floor vents..etc.
Many of the problems that plaque the Astro/Sarfari vans and many other "Mini-Vans" is the build up of excess heat in the engine compartment. It\'s a tight place to put a V6-4.3 Vortec engine and the heat generated bounces back and cooks everything on the engine (coils, modules, sensors, wiring, and of course plastic vaccum hoses). No need to mess with your switches or anything behind the dash -- replace those thin plastic vaccum hoses to operate the vaccum switch (located just below the A/C canisters, to the right of the heater/ac blower housing) and your dash switches will magically send heated or cooled air where you want it.
Oct 25, 2010 | 2003 GMC Safari
There's no air coming out from front vents. Air only comes out of defrost vents or lower vents.
the vacumn feed pipes are perished ,remove the interior engine cover to gain access and their are three pipes being fed from the manifold take off and they are all different sizes ,but its easy to do
Aug 12, 2010 | 2000 GMC Safari
Had to have fuel pump replaced on my 2000 Safari Van
You need to find the psi ratings for the pump you have and see if it matches the pressure specs for a 2000 GMC Safari pump.The parts store you purchased it from( or any parts store) should be able to look up that info on his merchandise
Oct 05, 2009 | 2000 GMC Safari
Air conditioner stop working
check if the comp. turning or running. and also check the fan that cool the condenser coil if running. if not check the relay if ON check the voltage across it. If relay do not ON, probably the A/C temp. control not functioning and should be check.
Jun 14, 2009 | 2000 GMC Safari
1999 gmc safari van upper vent
Check under the hood for deteriorated small vacuum hose coming off the intake over to the heater box area.
Repair the vacuum hose.
Oct 21, 2008 | 1999 GMC Safari
2000 gmc safari van
Up to you about grinding . Easier to drop tank and check all elctricals. Nephew didnt and had a short. Almost blew up. Had a similar problem with motor cutting off. My problem was a diode in the alternator
Jun 19, 2008 | 2000 GMC Safari
Heating & Cooling Logo
249 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
