Question about Cameras
I HAVE A POWER SHOT A529 NUMBER 099130083 DC3 15V THE ZOOM LENS DOES NOT COME OUT WHEN I WANT TO TAKE A PICTURE.
  • lmeli Sep 12, 2009
    I HAVE A CANNON POWER SHOT A520
    NUMBER 099130083
    DC3 15V THE ZOOM LENS DOES NOT COME OUT IT IS STUCK
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Sticky lens barrier is a quite common problem. It would be caused by split milk or juice, or dirt. When you turn on the camera, the lens barrier won’t open fully. It’s different from a lens error. In this case you can operate the camera just like normal, but you might get only half picture with black shadow, sometimes maybe almost total black because the barrier won’t open.
To fix this problem we need to prepare something:
A tweezers with serrated points, a 1.5 mm flat screwdriver, some wooden Q-tips, isopropyl alcohol, Super Duster(compressed air), double-sided tape, scissors, knife.
Let’s make a special tool first. Cut a tapered piece of wooden Q-tips as shown on T1
Step 1-Turn on the camera, let the lens extend out then open the battery lid, take out the batteries. Let the lens on extend position. Hold the lens body, insert the wooden tool we just made into the gap and turn it slowly to separate the ring.
Now you got the ring off.
Step 2-Insert the batteries and turn on then off the camera to retract the lens. then remove the batteries.Insert the flat screwdriver into the slot(1) about 3-4 mm depth, gently pry on (2) direction a little bit, use tweezer to give a little help on (3) and lift the barrier cover up(Figure 5 will give you the idea). Same on the other side to take cover out.
Step 3-Now take out the barrier plates. Use the screwdriver press the spring post to prevent the spring jumps out when removing the small plates.
Step 4- Clean the barrier cover and plates with Q-tips and alcohol.
Step 5-Remove two springs, clean the lens body with Super Duster. Clean the plate posts with alcohol if you got juice on them.
Step 6- Now put the springs back. Put the screwdriver on the post(1) of spring to prevent the spring from jumping away. Move the spring into the right place(2) carefully. Two springs are in place.
Step 7-Put back the big plates. Put back the small plates. Press and hold the small plate slightly, move the spring to the place shown on red. Now we got all the plates in place.
Step 8-Put on the barrier cover and press it down gentaly. You can feel a click when it gets in.
Now you can put the batteries in and test. If nothing goes wrong, you should see the barrier open and close perfectly.
Step 9-Clean the lens ring.
Step 10-Turn on the camera and remove the batteries, let the lens out again. Cut four small pieces of double-sided tape and tape them on the barrier cover. Check carefuly, don’t let the tape touch any plates.
Step 11- Here is the final step.Put on the ring to match up the index, hold the lens body, press the ring carefuly to make the ring taped on the barrier cover properly.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 12, 2009
    Brigadier General:
  • 4,090 Answers
Try this littel fix.
OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 80 of these cameras with this method. I obtained the fix from Sony who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
Please rate our help to keep the service online
DSC W80 Error Message - Zoom and Picture Doesn't work
There is something blocking the sensors for the lens position. This can something as small as a piece of sand. The motors and gears that move the lens are very small and delicate. You can send it in for repairs to www.unitedcamera.com
Nov 24, 2013 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Will not take a picture
This problem occurs due to following reason. 1) Your battery has become inefficient... In this case change your battery.. that means replace old battery with new one.
2) Motor which manages lens has been malfunctioning... In this case you have to get it serviced...
3) Firmware of the cam has been corrupted. In this case also you have to get it serviced..(This option is very rare)
Hope this has helped you... Please rate the answer.. Thanks...
Jun 24, 2010 | Sony Cybershot DSCW80 7.2MP Digital Camera...
I HAVE A CANON POWER SHOT A520. THE ZOOM LENS WAS OPENED AND I DROPPED THE CAMERIA AND THE LENS WHEN INTO THE CAMERIA. NOW THE ZOOM DOES NOT OPEN ANY MORE. THE LENSE IS OPEN AND DOES NOT CLOSE. I GET NO...
I know this is not the answer you want, but when you dropped the camera you damaged the lens tube (housing) and your camera will require professional repair.
Sep 13, 2009 | Cameras
Zoom in/out power off message
While zooming in-out camera gives error message means lens mechanism is either defective or lens drive motor is bad. In both cases, lens assembly will be replaced.
Contact nearest camera repair shop for fix.
Thanks.
Sep 04, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Sony dsc t300 e 61:10
   The detail of fault is given below,
Self-diagnosis Code   Symptom/State
E 61:10         Zoom operations fault
               (Cannot initialize zoom lens.)
Correction :
Retry turn the power on by the power switch. Check the zoom
reset sensor of lens block (pin 9 of CN402 on the SY-191
board), if zooming is performed when the zoom button is
operated. If it is OK, check the zoom motor drive IC (IC401 on
the SY-191 board).
According to the symptom the possible fault is described above, You have to contact any nearest SONY SERVICE CENTRE to rectify the problem.
 Thanks for using fixya.
May 30, 2009 | Sony Cyber-shot DSC-T20 Digital Camera
Zoom lens will not retract.. Canon Power Shot S21S
the block is damaged ...see if the lens barrels are a little bent or something....
Mar 06, 2009 | Canon PowerShot A75 Digital Camera
Does not zoom in or zoom out
Hey Ulviya,
What is most likely going on is something is obstructing the movement of the lens (i.e. sand). You could try blowing compressed air into the side of the lens to try and dislodge whatever might be in the lens. If this doesn't work I would try putting the camera on a flat surface with the lens pointing upwards and hold the shutter button in, while doing this turn the camera on. If neither of these options work I would have it looked at by an authorized service technician, and it’s possible all it needs is a professional cleaning. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 05, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
No picture and lens does not retract
Well some cameras has features that does not use the LCD screen of the camera, because to save battery power or to get better shots with the focus ring.
You can just use the area where you focus your eye to aim and shoot the object of image.
Try to enabled the LCD screen feature.
The Zoom Lens Wiggles 3 times because it is programmed to zoom at the standard zoom size, this is totaly normal for camera in digital and analog types.
Mar 05, 2008 | Sony Cyber-Shot DSC-P100 Digital Camera
Cameras Logo
16 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
