Question about Kenmore 24032\24036 Top Load Washer
Fills up then stops, hums also - Kenmore 24032\24036 Top Load Washer
    Brigadier General:
  • 3,917 Answers
Most washer models have snap-clips holding the front of the top panel down, with hinge-like clips at the back.
Carefully pry up the top panel on the front of the machine using a tool that won't scratch the finish, such as a plastic or wooden wedge. If it does not pop loose fairly easily, then carefully examine the back of the machine to see if this is a rare model that has screws holding down the top panel. (But really, it _should_ just pop loose.)
Once the top panel is tilted up to expose the inside, you should be able to see everything you need to see inside the body to evaluate a spinning drum problem.
Posted on Sep 12, 2009
Wash machine fills up starts cycle then stops it dont go to rinse then will start making a humming noise
it has bad cycle timemer switch in it replce with new one about 80.00 dollars
Dec 24, 2014 | Washing Machines
Whirlpool Ultimate Care II LSB200KQ1 Top Load Washer - the washer filled and then stopped. No humming, no sound, no action when we turn the knob. Thoughts?
The limit switch that detects that the lid is closed is probably defective. You've already probably experienced how the agitator would stop if the lid was opened when the machine was working properly--same thing.
Jul 17, 2012 | Whirlpool Washing Machines
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Machine stops at rinse cycle and hums
check the setting of the water temp for the rinse cycle. If one of your water supply valves is closed (HOT/COLD) the tub cannot fill with the proper water temp selected. The hum noise you are reporting is associated with the fill solenoid valve located in back of the machine.
Also, I have found the problem to be the screen located in the fill valve clogged with rust and water deposites. Disconnect both water lines and verify the water supply is not restricted.
Hope this helps..
If not, a more thural description of the problem may reveal more clues to assist in troubleshooting.
Thanks and good luck...
Apr 26, 2009 | General Electric Clothes Washer Timer -...
Loud humming noise when dishwasher is filling with water
sounds like it could be furring in your water piping. may need a plumber to check it out.
Mar 16, 2009 | Dishwashers
Will fill bottom then hums
Check to see if something is caught in pump or in bottom of dishwasher stopping the arm.
Mar 12, 2009 | KitchenAid 24 in. KUDI01TJ - Multiple...
Dishwasher starts to fill then just hums
Sounds like a motor problem. Behind the chopper is an access to the impeller, try turning the impeller or the chopper blade and see if the motor will rotate. If it doesn't, then something is stuck preventing the motor from running.
Mar 07, 2009 | Dishwashers
KitchenAid Clothes Washer, Fills and then Hums, Blew Breaker
no, need to empty water theres enough room to pull to side, and yesathought it spins by hand i like to see it spin under load. its possible you have a bad capacitor
Jan 31, 2009 | Washing Machines
Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Jul 24, 2008 | Roper RAS6233KQ Top Load Washer
Dishwasher keeps stoping
Favorite for bosch is the water inlet modual which monitors the water flow in could be faulty, If incorrect pulses take place the motor wont proceed. Otherwise listen for a hum after water stops filling. If there is a hum, the main wash pump is jambed and has to be sorted out.
Jun 08, 2008 | Bosch 24 in. SGV43A03 Built-In Dishwasher
Kenmore 24032\24036 Top Load Washer Logo
Sal De
fordexpert
Whirlpool
Whirlpool
