Question about Malber WD1000 Front Load Washer/Dryer
Where do i put detergent
Lost my instructions for malber wd1000 and dont know where to put what liquids
    Problem Solver:
  • 13 Answers
Contact Malber USA ( to order a new Manual.
Posted on Jan 07, 2008
What kind of detergent do you use and how to operate?
You can use almost any type of detergents, preferably 'Automatics' which are specially designed for washing machines. The operation logic is simple and is well explained in the user's manual.
Aug 20, 2010 | Malber WD1000 Front Load Washer/Dryer
Malber WD1000
door handle broke at plastic insert. Looking for replacement parts.
Jul 05, 2009 | Malber WD1000 Front Load Washer/Dryer
Hi. Mike here. Two "most likely" causes. (1) You simply have a leak at the lower right "cleanout trap". Remove the little white plastic "pull-out" assy. Check the black seal that looks like a little "tire". Is anything caught in it, or wrapped around it, or has it become deformed? Also, check that white plastic (2") washer, in front of it, is not warped (due to overtightening). Unscrew the "knob" (handle) part, all the way out, and separate all 4 parts. Clean knob, washer, tire (seal), and trap assy. Slip washer, then tire, onto knob's threaded "shaft". Flat side of washer goes against knob. Screw knob, washer and tire into trap assy, but only one or two turns. Then, slip entire assy back into machine's recess - and turn Clockwise to tighten. Only tighten hand tight (and I don't mean Macho tight!)
(2) If that doesn't fix, you may very well be using WAY too much detergent. These machines use only 2 or 3 (Max!) Tablespoons of HE liquid detergent. I've seen cases where folks were using 1/2 cup of liquid (or powder) and even more. That causes so much foaming that there have been overflows, from the lower right corner, even though nothing was wrong with the machine. To remedy, run a load empty, with NO detergent.
Good luck, and God bless.
Mar 06, 2009 | Malber WD1000 Front Load Washer/Dryer
What kind of detergent do I use on my Malber WD 1000?
Choice of detergent should be straightforward subject to personal preference;
Concentrated is usually more economical, as you don't have to use as much as with UNconcentrated.
Liquid or powder is no contest, it's liquid every time, it dissolves better in harder water areas and doesn't clog up your dispenser.
Brand choice depends on where you live, we use Persil but supermarket own brands are usually a lot cheaper eg Carrefour.
Hope this is useful
Please remember to give this solution a rating.
Oct 22, 2008 | Malber WD1000 Front Load Washer/Dryer
Dryer won't dry
61 Commercial Ave
Garden City, NY 11530
(516) 294-6660
first empty the waste container on the right buttom of your machine you have to empty that container every couple of washes.if not solved replace the heating element. the tel # above.
good luck
Sep 24, 2008 | Malber WD1000 Front Load Washer/Dryer
Loose Wheel and Leak
1 no just take the nut off and put a lock washer ingetween it
2 your using to much detergent
May 04, 2008 | Malber WD1000 Front Load Washer/Dryer
Detergent doesn't drain
The rod which controls the flow of water to the various compartments needs to be adjusted. It is not a difficult fix. You can contact Malber usa ( and they can "walk" you through it. In the alternative, you can put the detergent in the pre-wash tray without concern.
Sep 19, 2007 | Malber WD1000 Front Load Washer/Dryer
Liquid detergent and liquid bleach are best.
Aug 21, 2007 | Malber WD1000 Front Load Washer/Dryer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
334 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
