Question about Kenmore 63942 Dryer
Kenmore dryer 65923 is blowing out cold air, why?
Seemed to happen overnight
  • 64 Answers
EITHER YOUR HEAT SENSER, OR YOUTR HEATING ELEMENT HAS GONE BAD
Posted on Sep 14, 2009
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
Gas dryer starts blowing cold air after 5 minutes
This sounds like the dryer coils are failing. They tend to fail as they heat up. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jun 24, 2010 | Kenmore 73932 Gas Dryer
The dryer runs but only blows cold air. It's a gas dryer. Kenmore 90 series
Have you checked the igniter yet or tried replacing it?
It is generally the first thing to go when this happens.
Benjamin
May 24, 2010 | Kenmore 73952 Gas Dryer
Dryer is not heating up.
90% of electric dryers emitting cold air need a new heating element installed. If you've checked the thermal fuse, and verified the unit has around 220 volts of power, then the only thing left is the heating element. Typically costs around $40-$60. Can be done by you if you have basic electrical knowledge, otherwise call an electrician.
May 13, 2010 | Kenmore 62802 Electric Dryer
ONLY BLOWING SEMI COLD AIR> NOT REAL COLD LIKE IT SHOULD BE. cleaned front condencer still not ice cold. worked fine two days ago
return air ducts are iced up , unplug unit overnight or use a blow dryer in the freezer area. Ducts are behind rear panel left and right side
Nov 27, 2009 | Kenmore 53642 / 53644 Side by Side...
Fridge not working freezer works what should i do
see if you can hear the evaporator fan running in the freezer. if you can't you will need to replace it as this fan pushes the cold air from the freezer into the fridge to keep it cold.
Nov 07, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
No longer blows hot air, only cold air
when a dryer does'ny blow hot air,it's normally either the element or the stats on the element.
Nov 01, 2009 | Dryers
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Kenmore 90 series electric dryer blowing cold air only
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
Jan 15, 2009 | Zanussi TC7102W Electric Dryer
Whirlpool Dryer blows cold air when starting no heat
Did the fuse blow out? If so then the heating element is shorted out. This happens frequently when they fail. If the fuse is blown check the condition of or change out the heating element.
Dec 29, 2008 | Weather King 12AJA4801AH Air Conditioner
Kenmore 63942 Dryer Logo
91 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
