Question about Maytag Washing Machines
I own a Maytag Washer Model #PAV5157AWW that is displaying the following problem: On the final spin cycle the water is not emptied (using an earlier spin cycle solves the issue right now).
    Problem Solver:
  • 15 Answers
Believe it or not my washer had the same problem and my neighbor came over and bypassed my lid closure button and it works great. Seems the button that the lid hits is controlling the cycles. So he bypassed it. I don't know how exacting but he had to take the top off and redo some wiring, so I would call someone if I were you.
Posted on Sep 12, 2009
Maytag HAV2460AWW struggling to spin and drain
Gently tilt machine backwards and look underneath for stretched or damaged drive belt.The drive belt also runs pump. If it is slipping under load then the machine will not spin at full speed and pump out the wtare correctly, thuis leaving some in the machine at the end of the cycle.
Sep 07, 2012 | Washing Machines
Will not spin fast enough on final spin cycle to
ITS POSSABLE ITS NOT PUMPING FAST ENOUGH. CHECK THE DRAIN HOSE AND MAKE SURE IT HAS NO KINK. IF THATS OK IT MAY HAVE A BUILDUP OF SOAP. RUN A EMPTY CYCLE WITH NO SOAP. IF THAT DONT WORK YOU NEED A REPIARMAN TO CLEAN OR REPLACE THE PUMP.
May 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer will not start final spin cycle
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Apr 05, 2009 | Maytag EPIC MFW9700S Front Load Washer
My maytag neptune washer will not perform the final spin cycle. Therefore the clothes are still wet. Any solutions
Maytag washer parts, GE washer parts, and other brand names on the market are all designed to work interdependently with each other. This system starts to break down if even one part begins to encounter difficulty. Your washer's spin cycle flings a large amount of water out of the clothes, but if the water can't drain, the clothes will soak it all back up, defeating the purpose of the cycle. Excessively wet clothes after the spin cycle may not be caused by faulty washer parts, but rather a blocked drain is a very good bet. Check the drain line for a blockage and try again. If your hose is kinked or bent, this can also cause a drainage problem. The failure of one simple part creates a larger problem for all the washer parts. What can cause a blockage? A number of items; paper left in the pockets of your jeans, coins or other debris, even socks. Check your hoses, and make sure your laundry has empty pockets for future loads.
Feb 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptun will not agitate or spin
Change your timer. or timer sensor. behind your knobs
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Clothes still wet after final spin cycle
It sounds like you might have a broken belt or the belt just slipped off the pulley!
Jan 22, 2009 | Maytag Atlantis MAV6451 Top Load Washer
How can i fix my washer myself?
The washer will not ever completely drain according to Maytag. A certain amount of water stays in the outter tub for balancing the machine for final hyper-spin. However if the machine is not spinning all of the water out and your clothes come out sopping wet....read the long thread I typed out to another person earlier.....it's about 2-3 questions up on the same topic
Dec 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Follow up on Neptune Problem
You need to replace 2 parts here.The control board(located in timer panel)2.replace the wax motor.
May 19, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer bangs during spin cycle
chances are you had a blockage in the pump and it tried to spin with the water still in the drum. check the bottom hose and filter for blockages so it does not occur again.
Jan 19, 2008 | Washing Machines
Washing Machines Logo
166 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
