Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
SHE45M05UC Bosch dishwasher
The units controls light up when powered on but the unit will not start and cycle. It is brand new, installed today. Any advise welcomed
  • handywork1 Dec 11, 2007
    I did use the help book and even called California to speak with a rep who gave me several different options for retarting/ rebooting the unit but nothing seemed to work. I was hoping someone who has installed this unit and had the same problem could offer some help. I have heard if the float valve is stuck the unit will not work.
  • 456 Answers
Open the help booklet and follow the instruction if it is not working you can get replacement.
Posted on Dec 11, 2007
Bosch SHU9915UC won't start. all lights come on but unit doesnt start. is there a reset button somewhere in this unit?
Reset the dishwasher by pressing and holding the "Start" button for at least three seconds. Depending upon the Bosch dishwasher model you have, you also can push the "Cancel-Reset" button to reset the dishwasher. Select a new cycle and press "Start."
Jan 03, 2018 | Bosch Dishwashers
Wash cycle stopped with water in the bottom. Seems like there is no power. Can't get lights on cycles buttons to turn on. Power button does nothing. Checked circuit breakers. All are on. Lights and outlets...
Check the wiring in the units junction box. Its located at the bottom right corner. You will likely find melted connectors. If so, you need to cut the wires back and replace these connectors. Make sure you turn the power off before doing any of this work of course. Good Luck.
Jan 14, 2011 | Bosch 24 in. SHX46A05UC Built-In...
Dishwasher signals "clean" inside five minutes
I would check tosee if your water meaning hot water temp is hook up correctly. i have seen cold water going to machine and causing the machine to do funny things. 1 the unit drains.2. it fills.3.it washes if the water is cold there is your problem .make sure b4 you start machine the water going in is hot. let me know how you made out maybe we can further check. p.s im a old bosch tech:)
Jan 26, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
Have water to unit, lights are on and I hear it running, but it never fills with water
check the float assy below the lower rack ensure it moves up/down freely if not it will have to be remove to be cleaned but to test push the unit down if water enters then float needs cleaned if not fill valve is possible but not the only thing the timer could be but remote
Aug 19, 2009 | Bosch Evolution 500 SHE45M05UC Stainless...
Bosch Dishwasher will not power on
I saw my repair man do the following, which you might try...
Open the door and simultaneously press & hold down the power button with the 2 buttons used on your model to "Cancel & Drain." If the unit comes on it now is in self-diagnosis mode. Release the buttons and close the door. The unit should start to fill with water. Press the power button to exit the mode.
Jun 28, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Brand New Bosch Stopped Working On First Use
need to make sure no breakers have tripped if not then replace operating thermostat. if it is only a few days old you should be able to get the dealer to cover service call and labor
Jun 21, 2009 | Bosch Evolution 500 SHE45M05UC Stainless...
SHE45M05UC
the problem is the float switch is stuck
Dec 11, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
140 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
