Question about Epson Stylus DX6050 All-In-One InkJet Printer
Epson Stylus DX6050 rumbles + shadowed printing
A couple of days ago my Epson Stylus DX6050 printed OK. Today it will print but it rumbles and the printing is shadowed across each line.
Epson stylus dx6050.......2 years old.... printer problem..... every print is now including parallel horizontal lines about 1 inch apart throughout the A4 sheet - either in black, blue or yellow. the...
You have blocked nozzles in the print head. Try using SSC Utility (free download just google it)
Try the powerful clean. If that does not work then a new head is required and on an epson its just not worth it and a replacement machine is the best option.
Jun 05, 2011 | Epson Stylus DX6050 All-In-One InkJet...
My Epson DX6050 has run out of colour ink but i just want to print black only. how can i print my text doc in black?
Sorry, any inkjet printer will not support without colour caterige, so please fill colour then take printout in black . If my sugession is helpful pls rate this answer
Feb 26, 2010 | Epson Stylus DX6050 All-In-One InkJet...
Why is my epson DX6050 printing pink when the cartidges are full
you dont ur printer much thats why ur printer catirage have blocked its printing holes show it to the catrirage dealer near to you and tell them that your cartirage head is block and printing pink...
Nov 29, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Epson RX620 yellow lines/blocks on page
Try to print the nozzle check, and see what your out put is like.
If it is not giving you a regular pattern, then have the nozzle
replaced. Most times when the nozzle is clogged with ink, you
get such out-puts. So follow this steps.
How to print the nozzle check:
1. Press the Setup button.
2. Use the arrow buttons to select Nozzle Check, then press the OK button.
3. Confirm the message on the display, then press the OK button to print the Nozzle Check.
Shown below are some examples of what the nozzle check may look like.
Nozzle check pattern with no gaps
Nozzle check pattern with gaps
Apr 14, 2009 | Epson Stylus DX6050 All-In-One InkJet...
How do I get the print cartridge out of the Epson Stylus DX6050 to change it
Hi, Click file, Print, Preferences, Maintainance, Choices there to Maintain the Printer.
Including changing the cartridge,nossle check. etc
Lift up the deck on the Printer ( front )
Print cartridge housing with cover, remove or pull back the cartridge cover. replace 1 at a time for
correct installment. Print test page.
Always run 2 or 3 sheets off, cleans it out too...
Turn off and remove usb from PC for 5 minutes...
Connect backup to the PC. only when booted up.
Regards
Richard.
Mar 11, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Epson Dx6050 not printing in magenta & yellow? Have cleaned heads 5 times now & Im nearly out of ink. Its a brand new printer
Have you tried taking them out and putting them back in? Sometimes they don't 'seat' properly. Are they Epson carts?
Aug 28, 2008 | Epson Stylus DX6050 All-In-One InkJet...
Epson Stylus DX6050 All-In-One InkJet Printer Logo
362 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
