Question about Bose Car Audio & Video
Radio is on theftlock how do i get the
Radio is on theftlock how do i get the code..???
  • Bose Master
  • 4,869 Answers
In order to attempt to calculate your code , the radio will have to be removed from the dashboard .
Then POST A NEW QUESTION .....quoting the radio  MAKE+MODEL plus ALL the NUMBERS+LETTERS on ANY LABELS , BARCODES or STAMPED IN THE METAL CASING
Also quote the MAKE of CAR
Posted on Sep 12, 2009
HOW DO I UNLOCK THE RADIO ON A 2005 BUICk LA CROSSE?
On you tube Go here for more Info.http://audioxpress.org/delco-radio-theftlock-unlock-codes/ WE CAN UNLOCK YOUR RADIO IF ITS A DELCOLOC II OR A DELCO THEFTLOCK RADIO
Mar 01, 2015 | 2005 Buick LaCrosse
Gm delco theftlock radio wont turn on?
You have to enter the theft code which was set into the radio. The owners manual will tell you how AS LONG AS YOU HAVE THE CODE. If you don't have the code, any GM dealer will help you out and call in to get your code. They will want to make sure you own the vehicle.
Jul 22, 2012 | Cars & Trucks
2004 GRAND PRIX RADIO THEFTLOCK REMOVE
You need to enter the unique code for your radio that was given to the orig owner. If you do not have that you will need to see the GM dealer.
Jun 25, 2012 | Cars & Trucks
I have a pontiac 2004 van i need to unlock the radio
Your '04 is too new to unlock on your own.
There are 2 types of GM Theftlock, Theftlock I and Theftlock II. The Theftlock I is found in pre 2000 vehicles, and Theftlock II is in the later models.
Theftlock I - Uses a volatile user settable code that is input through the key pad on the front of the Radio. If the power is lost (dead battery etc.) the code is gone and must be re-entered for the radio to work. But with the correct procedure the owner can unlock it.
Theftlock II - Uses an EPROM (erasable/programmable read only memory) or a PROM (the difference is you can not alter the prom once it is programmed).
In either case the code is burned in and holds even when the power is lost. With Theftlock II the radio is married to the vehicle by way of the VIN. When the vehicle is started the computer compares the number in the radio with the VIN in the body control module. If they match, the radio works, if not the radio displays LOC and you are finished, there is no easy way around it. The radio will not work until you make a trip to the dealer.
The dealer will use a TECH 2 scanner to change the VIN stored in the radio. The radio does not need to be removed (for the serial number or any other nonsense). The technician just plugs into the computer and resets the VIN in the radio.
Thank you for using fixya, you can try removing the fuse to your radio for 5 min and reconnect it. This will reset the radio back to default and re-read the Vin number to the PCM to match with the radio. At most time this will get your radio working again and all you have to do is to re program the pre-set and clock.
Aug 06, 2010 | 2004 Pontiac Montana
Unlock radio need code to lock radio mufflerman08@yahoo.com
Your '02 is too new to unlock on your own.
Thank you for using Fixya and you may want to try pulling the fuse to your radio for 2 min and then reinstalling it. This may reset your radio and have the ECM recognize the radio matching VIN number to the Trailbalzer.
Jul 15, 2010 | 2002 Chevrolet TrailBlazer
I need a radio code to unlock gm part 10356164
Your '05 is too new to unlock on your own.
Thank you for using fixya and keep us posted.
Jul 10, 2010 | 2005 GMC Yukon
I NEED TO UNLOCK MY STERO IN A 2004 TAHOE
There is no actual "security code" in the radio as in past model years. The newer theft deterrent system utilizes the class 2 serial data to determine if the radio is in the appropriate vehicle...in other words it compares the VIN it has stored in it's memory with the VIN of the other modules (body control and PCM) in the vehicle to "check" to see that it's in the correct vehicle.
Each time the radio receives the "run" power mode message, it compares the VIN information it has stored to the VIN information received from a module on the class 2 serial data circuit responsible for transmitting that information. If a mis-match occurs, the radio display will indicate to the user the radio is locked. Once this takes place the radio will not respond to any buttons/commands and becomes inoperative. But the dealer can reestablish the radio into a different vehicle with a scanner.
Thank you for using fixya and good luck. you might get luck by removing the fuse toy our radio for 5 min and reinstalling it, this will reset the radio to default and all you need to do is reset the clock and radio presets.
Jun 15, 2010 | 2004 Chevrolet Tahoe
GM Delco Radio unlock code
The Theftlock I is found in pre 2000 vehicles and Theftlock II is
in the latter models.
Theftlock I - Uses a volatile code that is input through the key
work.
If you do not have the code, you can get it by phone, email, etc.
but you will need the 6 digit Radio ID number.
To get that, just turn on the ignition and hold down the 2-3 keys
(sometimes 1-4) and the first 3 digits will appear in the display.
Then hold down the AM/FM button and the last 3 digits will
show up.
With this number you can get the unlock code. This code is
available all over the place for less then $10.00. Just search
on theftlock. Use the HR and MIN buttons to enter the code
and you are in business.
This may sound a bit complicated at first but you can do it
in less then a minute with a little practice.
not alter the prom once it is programmed). In either case
compares the number in the radio with the VIN. If they
If the radio has an EPROM the dealer will use something called
a TECH 2 DEVICE to change the VIN stored in the Radio.
The Radio does not need to be removed (for the serial
into the computer and resets the VIN in the radio. It can
be done (if you know how) in less then 15 minutes.
I checked around and the going rate is about $60.00
(none of the dealers I contacted would do it for free).
That works out to $240.00 per hour, but still much
cheaper then a new GM Radio.
If the radio has a PROM then the chip must be changed
and that seems to be factory only, in other words a new
radio! The good news is, only a very few of the high end
GM vehicles are equipped with a PROM so it is highly
unlikely that your radio has this anti theft feature.
Good Luck!
Sep 19, 2009 | 2000 Chevrolet Astro
I need a theftlock code to unblock it!
Try 0000 first and if that does not work, go to www.radio-code.com they should be able to get your radio working again. Good luck and let me if this helped.
Jun 29, 2009 | 2000 GMC Safari
Cadallic 2002 radio reads locked theftlock active
You need to enter a code from the cadilac dealer
May 01, 2009 | 2002 Cadillac Deville
Car Audio & Video Logo
232 people viewed this question
Top Bose Car Audio & Video Experts
xxxxxx xxx
Tina Robinson
_ST_
Are you a Bose Car Audio and Video Expert? Answer questions, earn points and help others
