Question about Canon PIXMA MP830 All-In-One InkJet Printer
Canon MP830 Series Printer won't print black text
I've replaced all the print cartridges but for some reason, it won't print black text. I have to change the text color to anything other than black to get it printed. The only thing that I can think of is the black ink cartridge is a generic brand but it's compatible with Canon MP830.
  • Villalaz Sep 28, 2011
    I realize this post is two years old, but the EXACT same thing is happening to us. Was this problem ever resolved? If so, what was the magic trick?! Thanks.
SOURCE: black not printing
Excellent solution. May want to run the maintenance clean head action from the printer menu on the printer and also print a horizontal line test page to make sure the heads are aligned properly.
Posted on Dec 26, 2007
SOURCE: MP830 Cyan Ink won't print
To Fix the stupid Cyan, just unplug the printer, it may take more that one time unplug, its stupid problem, printer needs to reset, I have a full ink of Cyan but it says this "There is more than one Cyan" on the dispaly on the printer, and windows that its missing. I don't know what idiots programmed the printer. but screw them.
for cool stuff check out my site http://www.gagla.com
Posted on May 03, 2008
SOURCE: Black 3ek cartridge not printing
I had the same problem before with 3e black ink. It simply does not print too, so what I did if i get to print black and white i will set the characters into dark gray! it looks like draft printing but the things is it can be printed.. I tried to do every instructions available but to fail. I almost dump it till I decided to set it aside for a while. After a week I tried using it again, and it functions well. I guess the printer just want to say, "HEY BUDDY, GIVE ME A LITTLE BREAK!"
Posted on May 15, 2008
SOURCE: Canon i960 will not print in black ink
I use a no. 4 pan head screw to drill a SMALL hole in the top of the ink cartridge, about 1/4" in back from the front edge, so you can reseal it with the screw when done.
Take a small syringe with a short needle and pull the plunger back.
Insert the needle into hole and hold cartridge in place, IN THE PRINT HEAD, while pushing the plunger down to "pressure feed" the ink into the print head.
Reseal the ink tank with the screw when done.
I think the problem stems from the new or refilled ink tank NOT making a good seal with the print head and then there is a vacuum leak at the joint.
I have done this many times with my various Canon printers with removable ink tanks and it almost invaribly works for me.
I also refil the ink tanks IN THE PRINTER rather than taking them out to help prevent the vacuum break between the print heand and the ink tank.
It also helps to use a photo printing program to "print" out a black, red, blue or yellow page (use whichever color you are having trouble with) to help start the ink flowing again as well.
It does not have to be a full 8 x 10 size, just something about 4 x 6 to help reestablish the ink flow.
Posted on Jul 17, 2008
uten
  • 162 Answers
SOURCE: new cartridge won't print
re-seat the black cartidge, do head cleaning, get a windows test page (go to printers and faxes then right click on the printer icon and choose properties, click the print test page button).
replacing ink cart is the next step or service.
Posted on Nov 26, 2008
My Pixma mp830 will not print black text. What do I do?
Hy, your printhead has dry ink inside. Try to put the print head in ditiled water ( NOT tap water) and live it over night. If that dosent help try in warm distiled water and live it over night. Be careful not to put the print head in the printer when is wet...let it dry for 2-3 hours. If still dosent work you need to replace the printhead.
May 25, 2012 | Canon PIXMA MP830 All-In-One InkJet...
Our Pixma MP830 will not print black text. We've replaced both black cartridges to no avail. It prints color text with no problems. Any ideas?
First of all the print head is clogged just because you have tried to print repeatedly while some of the cartridges are empty. This results ink burn in the nozzle and clog. My recipe: Heat some drinking water in the kettle (70-80 C). Put the head in it and shake gently several times until ink is completely clean (10 minutes). Change the water do the same again. Change the water again (70-80 C) this time put a spoon full of apple vinegar (becomes a natural acidic solution very dilute) shake again, clean with cotton stick. I did it and started to love my mp800 again as much as I just bought it, all colours come back and started to print superior photos again...... Do not touch heads' copper poles and cartridges poles because of the static electric they may mulfunction and colours may becaome totally mixed for a short while...
Dec 26, 2010 | Canon PIXMA MP830 All-In-One InkJet...
The printer will print ok in color, but will not print black ink. No copy or printing.
My best guess without knowing more is that your printer has both a color print cartridge and a black ink print cartirdge. Replace the black ink cartridge and you should be fine. You might also find that replacing the entire printer is less expensive....All the best!
Nov 06, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Need to replace ink cartridge
http://reviews.cnet.com/multifunction-devices/pixma-mp830-office-all/4505-3181_7-31785803.html
Replacing the five ink tanks (cyan, yellow, magenta, black dye, and black pigment) is a simple task. The top of the printer flips up to reveal the ink tanks and the printheads, and by flipping a lever, you can pull out each tank individually. Being able to replace individual tanks is a boon, as you won't waste colors you use less frequently. Also, you won't need separate photo ink to print photos, which we appreciate. Canon ships the Pixma MP830 with full ink tanks. Replacement color and dye-based black ink tanks cost $14.25 apiece, while the pigment-based black ink tank costs $16.25. Canon estimates the cost per page for both black text and color text to be an inexpensive 2 cents.
May 31, 2009 | Canon PIXMA MP830 All-In-One InkJet...
While printing photos my printer has white vertical lines
Sounds like you need to re-align the print cartridge . The reason the text comes out ok is probably because it is only using the black cartridge for text. The color cartridge is the one that's out of alignment. You may have some sort of Cannon utility running in the task bar that will allow you to easily allign the print cartridges. If not, go to the main "Printers and Faxes" window, RIGHT-click on the printer and select "Properties". You should be able to find a button in the properties that's labeled something like re-align print cartridges. It will print out a series of test pages and ask you to select the set of lines that looks the straightest and type it in. It's a good idea to do this every time you replace a cartrige. Hope this helps, If I was able to FixYa, please remember to rate me. Thanks.
Feb 22, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Incomplete printing of black text
try this.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Jun 30, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP830 why do my colour cartridges run out when I only print Black & white?
This is because when your black catirage is over your colour catridge mixeses and print as black you can find a slite difference next time make a note of it
Apr 25, 2008 | Canon PIXMA MP830 All-In-One InkJet...
PIXMA MP500
The number 5 is a Pigment text black while the number 8 is a dye photo black. The text black is for black text mainly and the photo black is for use when printing photos. Since the text black is always running out it means you are printing a lot of documents in plain paper mode.
I recommend using QUALITY refill ink like Hobbicolors which is sold on eBay and will save you a bundle of money. The MP830 is a 5 ink printer so you need the 5 ink kit like the IP4300.
Dec 20, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
581 people viewed this question
old marine
old marine
