Question about Canon PIXMA MX310 All-In-One Printer
Same here ...
Up until two days ago the scanner function was fine, but now the scanner driver is not working (partially). I can scan using the automatic document feeder, but not when I lay a document on the machine manually.
I can use the simple scan function but not the scanner driver.
I've recently upgraded to snow leopard, I wonder if this could be part of the problem?
Why won't Minolta film Scanner work with iMac and OSX 10.6.2?
Hi
I bought a secondhand, nearly new Minolta Dimage Scan Elite 5400 a few years ago but never tried to use it until now when I tried to get it to work with my iMac running OSX 10.6.2. I uploaded the Dimage software but I cannot get it to recognise the scanner - any suggestions? Do I need to get updated drivers?
Feb 02, 2010 | Konica Minolta Dimage Scan Elite 5400 II...
How to use the scanner on an Epson DX4450
here you go buddy, leads you to the FAQ and the right manual
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=lkuCfcvA9cw3FDMg2fU002Fvgo64pkBVv4dzGfT08eqYk6sU003D&tc=5
Aug 16, 2009 | Epson Stylus Multifunction Inkjet Printer/...
SmarThru Office can't see scanner (nor can word)
Windows is using Window's default scan driver, so it's working only within Windows scan wizard feature. You will need to install the Scan Driver separately to work with SmarThru and other software. The Scan Driver is available at Samsung website.
Apr 16, 2009 | HP PSC 1350 All-In-One Thermal Printer
Canoscan 9950F scanner will not scan with Win XP
Since you have had the scanner a while, you may not have a recent enough driver to work well with XP: until I smashed my 9950F, I was scanning under XP with the ScanGear CS 10.324a driver with no problems (the driver is dated 22 June 2007). You can download it from several sources on the web, I used
"http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=120&modelid=10446#DownloadDetailAct"
Other than that, they report some issues if the system drive is NTFS, but I was using NTFS for my system (and only) drive, so I don't see any reason for this to be your problem.
Good luck,
CWM
Mar 19, 2009 | Canon CanoScan 9950F Flatbed Scanner
Scanning problem with a CanoScan8600F
Hi
 go to the your scanner properties please see there your current path.. and change the the path.. select your free hardisk space..which driver you've free space.. ther only stored you're all documents...
it will work
Nov 18, 2008 | Office Equipment & Supplies
Dell 1815 dn printer scanner issue: single line appears in scans
Do you get the same line when you use the adf for other purposes?
If so, check the scanner glass just before the platen for something like white-out on it. Clean both the scanner glass and platen glass with Windex.
That is a common problem on all ADF scanners.
Good Luck
Nov 15, 2008 | Dell 1815dn All-In-One Laser Printer
Scanning App won't open.
Actually, it's okay- I just installed the windows drivers under Boot Camp, and that seemed to 'reset' the scanner under OSX.
Oct 12, 2008 | Epson Perfection 1670 Flatbed Scanner
HP Solutions Center can not communicate with HP 3500c Scanner
Had exact same problem. Went to HP site and they said to check "add or remove programs" functions (in control panel) and if there are multiple copies of HP software to download their fix. I checked, had multiple copies, downloaded patch and all worked well again.
Sep 21, 2008 | HP ScanJet 3500C Flatbed Scanner
Canon 440f won't scan
I had exactly as described on my new 4400f scanner. Have resolved by uninstalling the toolbox software (it was at 5.0.1.2), downloading toolbox s/w from canon site, file name is S6A04mux.exe - toolbox 5.0.1.1 Installed this and all works from the scanner front panel
Jan 06, 2008 | Canon CanoScan 4400f MultiFunction Color...
Canon PIXMA MX310 All-In-One Printer Logo
41 people viewed this question
old marine
old marine
