Question about Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05M0A
Used frigidaire Just tried to use a second-hand frigidaire upright freezer. It worked about a week, but did not get super cold. Now it wont even freeze water. We are using a heavy duty extension cord. Any ideas?
  • vonrocket Dec 11, 2007
    Thanks for the help. I am running it now. It is freezing water, but the compressor is a bit hot, no doubt about it. Any ideas about adding gas?
  • shzcrzi May 27, 2008
    If the unit is running, and the compreesor is hot but the unit is not getting cold, then how do you add "gas"?
    Problem Solver:
  • 17 Answers
Look around the back of the freeze and at the bottom you will see a small black compressor .Put your hand on it and if it is running you will feel it vibrating. If it vibrating but running very hot them it means you have no gas in the system so the freezer won't freeze. If the compressor is cold and not running then it could be eaither the relay on the compressor or the board on the front either way you will need to get an engineer in
Posted on Dec 11, 2007
My frigidaire upright freezer has been working fine until about 2 weeks ago. Now pizzas aren't freezing and freezer corn is soft and i put a ham in it and that was a week ago and it is not froze.
There should be a temperature adjustment inside the freezer somewhere. It will look like a slider or a dial, and be labeled something like "Colder" and "Less Cold" on opposite ends of the scale. If this is set to its coldest setting, and the temperature still is not cold enough to solidly freeze food (ideally, a freezer's temperature should reach ZERO degrees Fahrenheit), then the unit needs to be serviced by an appliance repairman.
Nov 30, 2017 | Frigidaire Freezers
Upright frigidaire freezer light flashing 6 degrees pressed super freeze will it reset??? How do I know if super freeze button working??
Check along the back and sides of the freezer for any vent-like openings that are covered or blocked by packages. There may be a sensor that's not getting air flow as it should. Although most upright freezers are now frost free, there still can be ice buildup in critical areas such as the thermal sensor or the fan. Can you tell if the fan is running?
Even if the compressor has failed, your frozen items will keep the temp down for several days. I suggest you move the frozen goods to a neighbor immediately. Meat or fish in particular quickly becomes unsafe to eat without at least refrigeration.
Sep 03, 2016 | Frigidaire Freezers
Upright self def. freezer not getting cold
Is your compressor running? Try this: place your hand on top the compressor, quickly-in case it's hot-it should be vibrating and cool/warm to the touch. If it's not running then the cheapest/fastest test is to try a 3in1 start kit from a local appliance shop. The 3 in 1 start should be around $14 to $20 to wire up. It's extremely simple to wire up, just ask the clerk at the appliance shop's parts counter and they will explain it. I hope this helps you out!!! :)
Nov 19, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Just had a new upright Frigidaire freezer delivered two days ago. Plugged it in immediately. It did not get cold after several hours. Turned it off then back on. Unplugged it. Unplugged it for several...
Whenever you get a frig or freezer delivered it is best to wait at least 24hrs (some say 8 hrs) before you plug in. It maybe unknown to you if this was shipped to you in the laying down postion. If it was and you plugged in it will not work because laying down the oil migrated away from the compressor.
Other than that the freezer could have (possible chance but still possible) problems that are out of your control. If you brought it at a retail store you have at least 2 weeks to exchange. Do that a.s.a.p.
Dont bother trying to figure out just exchange!!!
hope this was helpful
Apr 04, 2010 | Frigidaire Freezer Refrigeration White...
My freeer stopped working after the temps dropped
freezers have a range of ambient temperature uses
most are plus 10c to 35c if using some units in garages etc. they just dont work...too cold for the poor things...
Feb 04, 2010 | Frigidaire 11.6 cu. ft. / 328 liter...
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire upright freezer and frig with freezer on top
it might have low volatge to compressor and burned out overload try unplugging it again wait a few hours and plug it back in it might start working good luck if it doesnt try replacing relay overload compasator they sell a kit called a 3 n 1 start kit
Aug 27, 2007 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05M0A Logo
300 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
