Question about Baxter OV300E Stainless Steel Electric Oven
When we turn the switch on, the light inside the oven goes on, but the touch pad does not come on, it comes on by itself after a while, or will shut off in the middle of cooking.
  • 43 Answers
Control board defective. Before replacing the control board make sure that your incoming water pressure is no higher than 20 psi and that your door gaskets and fan seal is intact. Torn gaskets or a worn fan seal will allow steam to enter the burner compartment and damage your control board.
Posted on Jan 13, 2012
Touch pad all lit up on GE 30 " slide in range
locate service manul / wiring diagram comees with all usually convenietly located taped to back inside pannel. shut off breaker , or slide out an unplug, read, manul if present plug back in fallow the set up steps,an trouble shoting. press,bake, set temp,and press start press timer,set timer ,and,press start again.should do it,.if not check for loose wire on oven senser.possible touch pad replacement. worst case. good luck
Feb 22, 2013 | GE Ovens
Double wall oven broiler goes off by itself f7 comes on light bottom oven goes on and off by itself whole panel will not operate and then will--serviceman was in said it is the panel ya think??
it could be the touch panel or the computer board,the model number you gave isn't the full model number like 10 different models came up,next time get the number off of the machine not the book,if this is a newer machine you can push the clear/off pad, unplug the touch panel ribbon for a minute or two,if the code comes back it's the computer board,if it doesn't come back it's the touch panel.he must have pulled out the tech sheet and showed you what it said for an f7 error code and if he said it's the panel he must have done this test.
Apr 18, 2011 | GE JRP24 Electric Double Oven
Oven overheats and shuts down with F1 error
F1 touch pad / ERC test
This simple test will help determine whether the ERC (Electronic Range
Control or Clock) or the touch pad is defective when F1 error code is
present.
Note: Some models incorporate the touch pad in to the ERC
as a single assembly, in which case this test is not necessary. Simply replace
the ERC (Clock).
Warning: If you feel in any way uncomfortable
performing this test or making this repair, please contact a qualified appliance
repair technician.
1. Disconnect power to the range (unplug the range
power cord or turn the power off to the range at the circuit breaker). It is
very important that the power to the range has been disconnected, so please
double check before continuing.
2. Gain access inside the control
panel.
3. Disconnect the touch pad (also called keypad or membrane switch)
ribbon from the ERC.
4. Make sure there are no lose wires, or anything else
that may cause a short when power is turned back on. Assemble the control panel
back the way it was.
5. Turn the power back on.
6. Wait for at least one
hour to see if the F1 code comes back (usually accompanied by a beeping
sound).
7. If F1 comes back, replace the ERC. If it does not, replace the
touch pad.
Dec 25, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Getting an F1 error. Oven shuts off F1 will not stop beeping
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Read
Nov 21, 2010 | GE Profile JKP56 Electric Double Oven
F1 error code and constant beeping and oven shuts off.
Hi gwhiz03,
If you are having error code F1 with your Jenn-Air double wall oven this is because you have a defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Hope this helps.
Thank you for using FixYa.
Feb 10, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
Maytag oven shuts off?
Hi. This is a possible touch pad, or EOC(Electronic Oven Control Board) failure code. The test below will help isolate the issue.
This simple test will help determine whether the EOC (Electronic Oven Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the EOC as a single assembly, in which case this test is not necessary. Simply replace the EOC (Clock).
Nov 20, 2009 | Maytag MEW5530D Electric Single Oven
I have an in the maytag gas oven that keeps beep and show f-1 when its shut off
This simple test will help determine whether the ERC (Electronic Range/oven Control or Clock) or the touch pad is defective when this error code is present.
1. Disconnect power to the range/oven (unplug the range/oven power cord or turn the power off to the range/oven at the circuit breaker). It is very important that the power to the range/oven has been disconnected, so please double check before continuing.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC/EOC.
6. Wait for at least one hour to see if the code comes back (usually accompanied by a beeping sound).
7. If the code comes back and the beeping as well, replace the ERC(control board). If it does not, replace the touch pad.
Nov 02, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
Oven light flickers on and off rapidly
I have seen several problems with the touch pad (membrane switch assembly) causing weird problems with the lights. also something to check is the door hinges. I have seeen several cases where the door hinges wear out and the door does not close completely and doesnt quite push the door switch in. The easiest way to check this possibility is to push in on the door while the light is acting up and see if it quits. If it doesn't, the problem most likely lies in the mebrane switch (touch pad). Good Luck!
Oct 06, 2006 | Dacor ECS127 Epicure Stainless Steel...
Baxter OV300E Stainless Steel Electric Oven Logo
181 people viewed this question
Top Baxter Ovens Experts
Owen Barnes
joneable
Level 1 Expert
Jerry Kramer
Jerry Kramer
Are you a Baxter Oven Expert? Answer questions, earn points and help others
