Question about Vacuums
Power-Flite Vacum It don't have the sucking power it had
  • 1,673 Answers
Re: Power-Flite Vacum
Check filters and the hose and make sure that nothing is plugged. Also check all of the seals, check to make sure there are no cracks on the door or on the back where the bag sits.
Posted on Jan 15, 2008
0 characters
3 Points
Power head not sucking
Check for obstruction or clog. Sometimes a warn belt can slow down causing the clog. Check and replace.
Oct 19, 2014 | Vacuums
XMy Vacum cleaner won't suck
check for any blockage in the hose or the power head unit...
Jun 04, 2014 | Electrolux Vacuums
The bottom of the vacum isn't sucking
My dyson animal seems to have a blockage in the base it makes I sucking noise then pops the sucks ion threw the wand is fine
Oct 22, 2012 | Dyson DC28 Animal Bagless Upright Vacuum
Rotating brushes don't spin.
Turn it over and pull out the brush holding assembly and insure that the master brush's stem is not broken off in the socket. The socket is geared to the vacum operated turbine that powers the brushes. There is the air input located next to the brushes and the filter might be clogged. If no air is being sucked into this red filter then it will have no vacum to turn the brushes. Insure that the flap is not closed behind the input filter. The flap is controlled by the brushes on selector switch.
Jan 29, 2011 | Hoover F5888-900 SteamVac Upright Wet/Dry...
When i conect the vacum part to maun system it
There is a motor in the power head that could be out or the receptacle, electric cord on power unit or loose wire in power head.
Oct 14, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Spin vacum won't suck up water
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter. Or the lid is not locked down all the way.
Dec 15, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Bissell powerforce bagless upright vacuum 6594-w
Be sure when you put the dirtant dust container in place that it is in properly. I have had this and believe it or not this container has enough room to fit without it seating properly. Take the dust container out and reseat it making sure the bottom is secure and then turn the lock lever in place. Try it again. What happens is you get an air gap which allows some air to flow but the vacum does not function properly.
Aug 26, 2007 | Bissell 6594 PowerForce Bagless Upright...
Powr-flite PD 2500
I need a control knob (on off and speed) for a powr-flite pd2500, any ideas when I can obtain one
Jul 28, 2007 | Powr Flite PD2500 Handheld Vacuum
Vacuums Logo
53 people viewed this question
Top Vacuums Experts
Roger Potts
Are you a Vacuum Expert? Answer questions, earn points and help others
