Question about Nokia 5500 Sport Cellular Phone
My phone's headset function would not de-activate too!!!!!
My phone's headset feature got activated some how and after searching all over the options and menus I did not find any option to de-activate it. I don't know what to do now. Can anyone help??? I could not find any thing in the profile which could change this problem as was suggested!!
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
To remove call barring activation
Call Barring - Enables you to restrict or bar certain or all types of calls to and from your mobile phone, i.e. outgoing calls, outgoing international calls, incoming calls. Barring is activated with a personal code.
Call barring is a mobile phone feature that allows the user to set certain prohibitions on incoming or outgoing calls. This is an effective means to prevent the phone being used to make expensive international or premium rate calls, particularly when the phone is to be used by people other than the subscriber.
Many companies that provide handsets for business use now employ call barring as a security measure, to control their use and restrict calls to pre-approved numbers. The user's personal code must be used to activate this feature.
How do I get it?
Contact your local Service Provider. You will need a four digit barring code. Initially this will be 0000. You should create a personal barring code for security. Please consult your cellphone's instruction manual.
What does it cost?
This service is free.
Also you can deactivate it from your cell phone..
Different cell phones have different setting functions,
You can try these out. It's the general way to deactivate call barring (NOKIA) .
Follow the below instruction:
Go to Menu,
Enter settings,
Scroll to Security,
You will see call barring on that list,
Click on it,and scroll to last option and you will see cancel call barring.
Your cell phone might not be the same with these functions,but the procedure are aways the same..
Good luck.
May 28, 2011 | Nokia Handsfree For 6020, 6101, 6102...
How do you restart its factory settings to delete the existing paired phone and and a new one?
The VoyagerPro headset does not have a reset feature other than turning it off and back on. The VoyagerPro will only link to two active Bluetooth devices at any one time. If you have purchased a new phone, it should just be a matter of activating the Bluetooth feature on the phone and headset and syncing them to each other. If the older phone is causing you issues when pairing the new phone, just delete the headset from the old phone. That should take care of the problem.
Good luck from Headsets Direct!
May 12, 2011 | Plantronics Voyager PRO Bluetooth Headset
I need instructions on how to pair my WEP200 to my new cell phone please.
1 Turn your bluetooth headset off. If it is on, press and hold multi-function button(for about 4 seconds) until the LED blinks twice. 2 Prepare your bluetooth enabled phone to be ready to go to search mode. 3 Turn your bluetooth headset on in pairing mode. (Press and hold the multi-function button for almost 9 seconds. The LED will be steadily LIT.) 4 Activate the Search option in your phone. You should see Samsung WEP200 in your phone's screen. Choose that and press OK 5 The phone will ask for a passkey. Press 0000. Then press OK. Give it a few seconds, your phone and bluetooth headset will be paired.
Mar 21, 2011 | Samsung WEP200 Headset
I cannot connect the bluetooth headset to my iphone
Hello
Prepare your iphone to be ready to go to search mode.
You can see 1.Search 2. Wait for request. Don't press on Search yet. This needs to be done after the bluetooth headset is in pairing mode.
Activate the Search option in your phone. You should see Samsung WEP301 in your phone's screen. Choose that and press OK.
The phone will ask for a passkey. Press 0000. (That's four zeros.) Then press OK.
Enjoy the handsfree experience.
Nov 11, 2010 | Samsung WEP301 Bluetooth Headset
My nokia BH-215 is not pairing. The green light blinking continuously.
hello, clear setting or reset, to delete the pairing from the headset , press and hold the power key and the answer/end key (for about 5 seconds) until the red and green indicator lights start to alternate. to reset the headset if it stops functioning , even though it is charged connect the headset to charger while you press and hold the answer/end key , Ensure that your phone is on and the headset is off.press and hold the power key (for about 5 seconds until the green indicator lights start flash quickly. activate the bluetooth feature on thr phone, and set to search for bluetooth devices. select the headset from the list of found devices . enter the passcode 0000 to pair the phone. hope it works
regards
shaun
Oct 10, 2010 | Nokia Consumer Headset
I wanna to be unsubscibe mazook.com from my mobile +966 557452327 ( motorola )
Dear sir/Madam, \r\n
Please De-activate my mobile number 0562678798.
kindly request pls de-activate mozook.com
Aug 16, 2010 | Motorola Mobility RAZR V3i SLVR L7 L8 OEM...
How do i pair my h700 bluetooth with my samsung sgh-a767
Click on your start option, then go into settings, you may have to open "all programs" to see the settings icon, after you get in the choose the last option on that screen which I believe is option "G", next page will show a option for "Connections" (A), then option "C" bluetooth, then follow the pairing options.
Hope this helps.
May 14, 2009 | Motorola Mobility H700 Wireless Headset
Nokia 5500 headset function
Hi. Try change your profile from options menu. You may have headset profile on of something.
Dec 21, 2008 | Nokia 5500 Sport Cellular Phone
110i/1112 Nokia cant activate headset option
generally wen you insert the headset pin it goes automatically to headset profile, if this is not working then go bak to the vendor & get the phones software changed
Oct 13, 2008 | Nokia 1100
Nokia 5500 Sport Cellular Phone Logo
218 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
