Question about Dryers
Model dg303 need to install the themostate fuse. Where is it located
  • 986 Answers
Steam and lots of antifreeze leaking. Where is the themostate located? Do you have a picture?
a thermostat is not your issue. you need to get to an audi mechanic ASAP. you have a serious problem.
Dec 08, 2010 | 2002 Audi A6
Need to know were is the themostate is located on my audi 1996 quattro
It depends on what engine you have - each engine has a different location.
Aug 10, 2008 | 2000 Audi A6
No power
THese diagrams may help some
http://www.pcappliancerepair.com/model-display.php
Dryer NO Power
You really need a volt / ohm meter to check for Continuity & Volts
Its well worth the investment... $15.00 bucks give or take a few
I would check to see if you have 220v to back of dryer where the cord mounts to dryer,
If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat.
Check themostates & heater for Continuity... Most models, Now have a..
Hi-limit fuse that need to be checked for Continuity and replaced if bad
if you dont have a ohm meter you can hook the wires together
with a small piece of wire and by pass the themostates and hi limit fuse to see if thats the problem or not
Nov 03, 2007 | LG DLE5932W Electric Dryer
Electric Dryer
Dont see a model # or make  but here some tips
Oct 17, 2007 | Dryers
Fuse keep blowing
I would check temp out of dryer should be 140 - 160
Is your cycling themostate good, cutting off when suppose too?  and Hi limit on burner good?
THe cycling themostate control drum temp, hi limit on heater is a back up and the hi limit fuse on burner backs up it all
Oct 16, 2007 | Dryers
Maytag Neptune Dryer
Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuses that need to be checked for Continuity
Oct 14, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag model
You really need a volt / ohm meter to check for Continuity & VoltsIts well worth the investment... $15.00 bucks give or take a few
Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuses that need to be checked for Continuity they have to be replaced
Oct 11, 2007 | Maytag Atlantis MDE7400AY Electric Dryer
Neff condenser T/dryer with no heat
You really need a volt / ohm meter to check for Continuity & Volts Its well worth the investment... $15.00 bucks give or take a few I would check to see if you have 220v to back of dryer where the cord mounts to dryer, If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat. Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuses that need to be checked for Continuity.
Oct 06, 2007 | Dryers
Samsung rs21dcns
Cant bring up anything on the # u provided
Some refrigerators run  the defrost themostate...
 IF  d. thermostate bad of some frigs fan motor will not run ..
check thermostate for continuity . frig has to be at 20 to 30 degrees to check.. got to be certain temp to close themostate
can cut wires and splice to ..by pass thermostat to check
Oct 01, 2007 | Samsung RS2630SH Side by Side Refrigerator
No Defrost
Take back panel off freezer and ohm out the heater and defrost themostate.... Need type and model # for more help
Sep 18, 2007 | Refrigerators
Dryers Logo
76 people viewed this question
Top Dryers Experts
