Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Remote Control closes garage door but does not open
Using my Craftsman garage door opener - both remotes open and close the garage door, but the keypad will close the garage when open, will stop the closing or opening once started, but will not open the garage door if it is fully closed.
    President:
  • 3,197 Answers
It sounds like a case of your keypad losing signal strength enough that it cannot transmit through the closed door. If a new battery doesn't do the job a new keypad will.
Posted on Sep 12, 2009
With my door closed, i push door button to open and the chain and opener continues inthe closing mode. any help?
Shop for sears craftsman liftmaste... on Google
Garage Door Opener Gear...
$31.45
Sears Parts D... Liftmaster 41C4220A Ge...
$21.75
Preferred Do... Chamberlain/l... Sprocket, Gea...
$17.95
eBay Direct Replacement f...
$20.95
Moving Up G... Liftmaster 41c4220a gea...
$31.67
North Shore... Search Results
    Liftmaster Gear And Sprocket Kit 41c4220a Chamberlain ...
    www.sears.com/search=liftmaster%20gear%20and%20sprocket%20...
    Searsmore info. + -. Chamberlain LiftMaster 41C4220A Gear & Sprocket Assembly Kit. $31.40 ... Chamberlain Sears Craftsman Liftmaster 41A2817 Gear Kit. $27.65 ...
Jan 10, 2016 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 hp opener won't open using the outdoor keypad. It will close when using the outdoor keypad but not open. Wall unit closes and opens it. changed battery in keypad, no difference
If your hand remotes work okay then the keypad has lost signal strength and needs to be replaced. If your hand remotes act the same way then your logic board is bad.
Jun 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Model 139.53684 Security+ Keyless Entry Garage Door Opener... Green light flashing on door control push button. Remotes no longer work. Can open and close garage door from keypad. Why is light...
To answer your question the opener is in vacation mode. Press and hold for 3 seconds the button on your wall control with the lock icon. The green light will stop flashing and you will be back in business.
Dec 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Have to hold down keypad on wall to get door to
You may have a relay faulty or the wiring is connected wrong.
Dec 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door remotes and keypad won't hold the code.
DID YOU BUY THE KEYPAD AND REMOTES WITH THE OPENER. IT SOUNDS LIKE YOU MAY HAVE THE WRONG ONES FOR YOUR OPENER.
CHECK THE FREQ. AND IS IT ROLLING CODE.
Mar 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remotes won't open garage door, keypad will
If you look were the small wires attach to the opener there should be a red program button and instructions on how to program remotes.
Feb 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad garage door opener will not operate
what keypad are you using with new opener? Frequency has changed. can't use old one. you probably never needed to change things; just needed to follow proper coding procedures.
Dec 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
One of the remotes manages both doors instead of just one
don't use that one! Seriously, you need to wipe out all codes and reprogram your keypad and remotes.
Nov 20, 2008 | Sears Craftsman LiftMaster Chamberlain...
Keypad code will close the door but not open it.
check that both codes (in the remote & garage door opener) are the same. Press reset on the opener and reset enter the code.
Nov 05, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
870 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
