Someone else posted the same question a while back with no answer.
My power mirrors will not fold in anymore. Both mirrors are still power adjustable, when I hit the button to fold them in, the mirrors turn down and then dont fold in. The passenger one turns down and then back up... the drivers one just turns down and stays that way, which would leave me to believe the problem is with the drivers mirror? The signal light in the passenger mirror work, but not the one in the dirvers mirror. It seems the folding in option and driver miror signal light stopped working at the same time... not sure if its the same problem or just coinsidence?
The power mirrors are controlled by a module (computer) DDM - drivers door module an the PDM - passenger door module .
Folding Mirror System
Folding Mirror System Controls
The folding mirror system requires signals from 2 separate switches. The mirror select switch must be in the neutral/fold position and the mirror direction switch must be activated to the left/extend or right/retract positions. Both switches are integrated into the DDM and provide direct signals.
Folding Mirror System Operation
Upon receipt of the required switch inputs the DDM will supply battery voltage and ground to the mirror fold motor control circuits to perform the requested extend or retract function. The DDM will also send a class 2 message to the PDM indicating the requested function. The PDM will supply battery voltage and ground to the mirror fold motor control circuits to perform the requested extend or retract function.
Power Mirror System
Power Mirror System Components
The power mirror system consists of the following components:
• The driver door module--Class 2 module with integrated switches and requires programming when replaced
• The passenger door module--Class 2 module with integrated switches, requires programming when replaced and also contains the RFA receiver
• The power mirror direction switch--Integrated into DDM and is a 4-position momentary switch that provides a signal input to the DDM for up, down, left/extend and right/retract with a mirror switch activation
• The mirror select switch--Integrated into DDM and is a 3-position switch that allows the operator to select the left or right mirror and also a neutral/fold position
• The left outside power mirror--Contains both the vertical and horizontal mirror motors and is serviced as a complete mirror assembly
• The right outside power mirror--Contains both the vertical and horizontal mirror motors and is serviced as a complete mirror assembly
• The body control module--Class 2 module that requires programming when replaced, serves as the power mode master and is the main message handler
• The DDM 10A fuse--Located in the I/P fuse block and is hot at all times
• The PDM 10A fuse--Located in the I/P fuse block and is hot at all times
• The memory switch, if equipped with memory mirrors--Supplied power by the DDM and provides a voltage signal to the DDM upon a switch activation
• The horizontal and vertical position sensors, if equipped with memory mirrors--Supplied a 5-volt and low reference by the DDM/PDM and provide a variable voltage signal to the DDM/PDM that is proportional to mirror position
• The park neutral position switch, if equipped with memory mirrors--Provides transmission gear selection information to the PCM and is used for memory recall and mirror tilt in reverse functions
• The powertrain control module, if equipped with memory mirrors--Class 2 module that requires programming when replaced and provides Class 2 message indicating transmission gear selection
• The driver information center (DIC), if equipped with memory mirrors--Part of the instrument cluster which is a Class 2 module that requires programming when replaced and is used to personalize the memory recall and mirror tilt in reverse functions
• Fold motor in each of the outside mirrors, if equipped with power fold mirrors--Provides extend and retract movements of the mirror and is serviced as a complete mirror assembly
Each of the outside power mirrors contains 2 reversible motors to provide horizontal and vertical movement of the mirror glass. The vertical motor operates the up and down directions and the horizontal motor operates the left and right directions. If equipped with power folding mirrors, each outside power mirror will contain a reversible fold motor to operate the extend and retract functions. Each of the mirror motors are circuit breaker protected.
DTC B1722
The driver door module (DDM) and passenger door module (PDM) switch the mirror fold motor control circuits to battery voltage and ground in response to mirror extend or retract command.
SOURCE: installing a Nissan Sentra Passenger Side Manual Non Folding Mirror.
had to install a driver side non folding mirror, fairly simply to say the least. There's a cover on the interior of the door, near the window, remove the cover, remove the 3 screws, need i believe a 10mm socket. If a power window, unhook the circuit. Replace new mirror.
SOURCE: Mirrors will not fold in.
It is a stuck motor. Water gives rust inside housing. Remove mirror and clean motor and components. This is a well known error for H2 mirrors.
SOURCE: Problem folding door mirrors 2005 Golf 2.0 GT TDi
Yes the mirrors are hinged so you can flod them against the car to keep from breaking them while being washed in an automated machine.
SOURCE: Hummer H2 Power folding mirror won't fold
The power folding function of your exterior mirrors on your '04 H2 depends on a plastic gear to collapse those mirrors at the touch of a button. That plastic gear strips very easily. The service adviser at our Hummer dealership said that problem was rectified in later model years with a redesign of of the collapsing mechanism of those mirrors.
I don't mind manually folding our mirrors, and I was afraid to ask about the cost of the parts required to solve the issue. The service guy didn't volunteer the cost of the fix. Not typically covered by aftermarket extended service/warranty plans.
SOURCE: Rear view mirrors on my GMC Yukon not folding in
how do i fix the ball joints in the front end of a ford 94 aorstar
