Question about Oster 5834 ExpressBake Bread Maker
Is the shaft that the paddle attaches to supposed to easily drop out of the bottom of the bread pan, or is there a gasket of some type that is supposed to hold it in?
  • 433 Answers
It is not supposed to fall out. The sealed bearing is broken causing the shaft to slip out. You have to replace the pan.
Hank
Posted on Sep 14, 2009
Can't remove kneading blade
If you baked bread in it and cannot get the paddle free, put enough water in the pan to cover the paddle and let it set for 5 or 10 min to soak the bread crust that formed between the shaft and the paddle. Then take a hold of the shaft on bottom of pan with hand or pliers to hold it still and try to work the paddle clockwise with other hand until it becomes unwedged from shaft. Sometimes it gets wedged on shaft pretty tight due to the beating against dough ball and cooked bread holds it tightly wedged.
Apr 06, 2014 | Sunbeam 5891 Bread Maker
I just bought a new B6000C bread maker. I have not used it yet. The instructions say "push the paddle down firmly onto the shaft to secure in place". But, my paddles just sit loosely on the...
No, there is nothing wrong with your bread maker. The paddle is supposed to be somewhat loose so you can remove it after baking for cleaning. Don't worry your paddle and breadmaker are fine.
Jul 26, 2011 | Black & Decker B2000 Bread Maker
The spindles that you attach the paddles to is leaking a black lubricant or something like that. I was making a simple sweet dough. By the way, I NEVER bake in the bread maker. I only use it to knead the...
Your machine has a lubricating grease that is under the small gasket or washer at the bottom of the pan under each paddle. After a lot of use the little gasket can fail and the grease can get get past the gasket and into your bread. The best thing to do is either replace your pan with what is called a "pan assembly which will include everything but the paddles. If you decide to do that be sure to keep your paddles. The other choice of course is to replace your machine which might not be a bad idea if your machine has been used a lot because you would have a new pan assembly but older parts may begin to fail such as the drive belt. Bread machines aren't all that expensive anymore so you may want to go ahead and replace especially since you just use your machine for making dough.
Feb 08, 2011 | Zojirushi BBCC-X20 Home Bakery Supreme...
The paddle keeps coming off during mixing and leaving a black stain in the dough
Hi, The sealed bearing located on the bottom of the bread pan has failed. This bearing is sealed with lubricant to allow the paddle shaft to spin easily. The black stain you see is the lubricating grease. You need a new bread pan. Hank
Jan 22, 2011 | Breadman TR2500BC Bread Maker
The rubber (?) gasket between the kneading blade and the bottom of the bread pan has deteriorated and sluffed off into bread. Can I get a replacement?
Hi, That is actually a sealed bearing that the paddle shaft rotates on. It can not be replaced and you will need a new bread pan. Regal does not make bread machines anymore, but you may find one on eBay or Amazon. Hank
Dec 05, 2010 | Regal Ware Kitchen Appliances - Others
Hi, I had all my ingredients in the pan and was bringing it to the machine to begin making bread. When I noticed the liquid was leaking out from the bottom. I had a mess everywhere. Come to find out the...
Hi, The leaking is from the sealed bearing that the paddle shaft rotates on. It wears out over time. It can not be repaired and you will need a new bread pan. Sorry Hank
Nov 23, 2010 | Breadman TR2200C Ultimate Bread Maker
I have a Regal bread maker K6773. At the bottom of the drive shaft in the bread pan is a tan rubber gasket and below that was a black rubber gasket that has completely disintegrated and ended up mixed up...
Hi..That assembly is part of the sealed bearing in the bottom of the pan. That sealed bearing allows the shaft and paddle to turn freely. Unfortunately Regal stopped making bread machines and parts several years ago so the chances of you finding a replacement is rare. Hank
Sep 21, 2010 | Regal Ware Kitchen Appliances - Others
The container that bakes the bread has a tab on the bottom that turns, and is on a shaft that goes thru the bottom, and this shaft is held by a snap-ring. we can't get the tab off,(supposed to come off to...
Thank you for visiting Fixya. The tab you speak of is called the paddle. The paddle sits on a shaft that is pressed into a sealed bearing. This shaft is not supposed to move in the bearing. If the shaft moves the bearing will lose it's seal and lubricating fluid (oil) will leak out. The snap ring, bearing, and shaft are put together before they are installed into the pan. If you can't fit the ring back onto the shaft so the shaft doesn't move, then you should hunt around for a new bread pan. P.S. Putting soapy warm water in the pan and letting it sit for a while will free up the paddle so it lifts off the shaft. Also lubricating the shaft with a squirt of olive oil will help stop the paddle from sticking on the shaft. Good Luck...Hank
Nov 28, 2009 | Zojirushi Kitchen Appliances - Others
The driveshaft falls out of the pan, even with paddle attached
The shaft is pressed into a bearing that is molded and stamped in the bottom of the pan. This bearing is sealed and allows the shaft and paddle to spin freely. The rest of the parts on the other end of the shaft interact with the motor on your machine. They do wear out and can not be repaired because the worn parts are not available individually.
Sorry to say there are no repairable parts, so it's time for a new bread pan. I don't know the brand of your machine so you can google or check ebay.
Hank
Sep 02, 2009 | West Bend 41052 Bread & Dough Maker
I have a problem with my bread sticking to my kneading blades and spoiling the loaf when it comes out of the tin
The blade is supposed to come out of the pan with the bread. Then you can remove the paddle from the loaf.
If the paddle does not come on and off the shaft easily it may be seated too tight on the shaft. Make sure everything is clean and keep taking it on and off the shaft to see if it frees up, or use a little bit of olive oil to lubricate it.
Hank
Aug 16, 2009 | Kitchen Appliances - Others
Oster 5834 ExpressBake Bread Maker Logo
214 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
mike cooper
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
