Question about Fuji FinePix S1 Pro Digital Camera
Fee flashes even though apeture ring is set to
I have an Finepix s1 pro and i'm unable to take a picture now because the Fee (error) flashes even though the aperture ring is set to narrowest setting on lense. the shutter still will not release
I have the same prolem. I think it has soming to do with the Meter coupling lever , it protrudes top of the Nlkon F-mount on the front of your camera. it may be need of repair
Posted on Feb 16, 2010
My S1 displays fee and I can't use it. What does it mean and how do I fix it.
You're using a lens with an aperture ring on it, aren't you?
Turn the aperture ring on the lens to its smallest setting (largest f/number) and lock it in place if it has a lock. You can control the aperture from the camera body the same way as on a lens without an aperture ring.
Aug 20, 2013 | Fuji FinePix S1 Pro Digital Camera
Fee message
I am getting a FEE error on a Fuji FinePix S1 Pro Digital, the 300mm lens seems to be connected correctly. please help thank you.
I don't know if you have a manual fir this camera so I'm giving you a "Google" search link for a manual in PDF format. It the fourth one down.
http://www.google.ca/#hl=en&source=hp&biw=1303&bih=818&q=Fuji+S1+Pro+PDF+manual&aq=f&aqi=&aql=&oq=&fp=a5556ef3492e88b9
Okay, I've had several Fuji Pro cameras including the S5 Pro and these cameras had dual memory card slots it's listed in section 6 page 24 of this PDF manual
Okay what can happen and happened to me several times (didn't learn the first time) was that I had the camera set on the Compact Flash card and filled it up but the camera needs to be manual set for the next card it's not automatic. So I'm going to assume that the media card you are trying to write the new picture files to is full.
You can download the pictures and then format the car (in the camera) then continue or switch to the other card in the card slot. This camera used a Smart Media and a Compact Flash Card.
Cheers
Apr 12, 2011 | Fuji FinePix S1 Pro Digital Camera
I have a Nikon 33mmSLR on maunal setting, to control apeture and shutter speed. There is an automatic setting, but I have it on manual and I am still getting the FEE error. If I switch it to lowest apeture...
Ignore the error. Control the aperture by turning the aperture ring on the lens. You will get no help from the camera's exposure meter.
If the shutter cannot be fired this way, please reply to this post and we'll go on from there.
Nov 17, 2010 | Nikon N65 35mm SLR Camera
Fee error, Nikon N60
Are you using a Nikon "d" lens? on my D70 Fee means that the lens apeture is not set to minimum. If you have an apeture ring, set it to minimum.
Oct 15, 2010 | Nikon Cameras
Keep getting FEE error on top LCD screen - not sure how to get rid of it. It won't allow me to take any pictures.
Generally it means that the camera cannot communicate w/ the lens. Make sure that the lens (assuming you are using a lens w/ a manual f/stop ring) is stopped down to it's highest #. often it's a different color than the other #s. If that doesn't work, take off the lens & clean the contacts on the lens & body w/ a dry cloth.
Oct 04, 2009 | Fuji FinePix S1 Pro Digital Camera
Fuji FinePix S1 Pro Digital.
I strongly recommend you use a memory card reader to solve this problem.
The cause is likely a bad USB cable, USB port on the Camera, or low battery.
A USB memory card reader will work around any of those causes.
Jul 20, 2008 | Fuji FinePix S1 Pro Digital Camera
EEE Error
3 reasons u get an "err" msg are
1. lens aperature not at smallest stop (f22 for example) turn aperture ring to smallest aperture setting or largest number
2. No memory card, or card not formatted or the magnetic latch of the memory card is sensitive try closing it firmly , or try changing memory card may it is damaged by force pullout.
3. weak batteries (4- AA and 2- CR123)try changing them.
4. Try changing or taking out lenses.
i hope something work out for u lemme know
Jan 16, 2008 | Fuji FinePix S1 Pro Digital Camera
Fuji Finepix S1 Pro fE E blinking when turned on?
Might Help:
Notes on G-type Nikkor and other CPU Nikkor lens
The G-type Nikkor lens has no aperture ring; aperture should be selected from camera body. Unlike other CPU Nikkor lenses, aperture does not need to be set to minimum (largest f-number). CPU Nikkor lenses other than G-type Nikkor lens have an aperture ring. Set the lens aperture to its minimum and lock. When the lens is not set to its minimum aperture setting and the power switch is turned on, "fEE" blinks in the control panel and viewfinder and the shutter cannot be released.
Nov 09, 2007 | Fuji FinePix S1 Pro Digital Camera
HELP! need to know why my Fuji FinePix S1 pro flashed "f EE" on the LCD screen?
Thia error is caused by the use of a non-AI lens, or that the F-stop is not set to the lowest setting.
If the lens can support light metering on this camera, then the solution is to set the F-stop on the lens to the smallest number (ie, 2.8, or 3 or whatever the smallest number is.)
John C. Vincent
yellowcaseartist.com
Oct 10, 2007 | Fuji FinePix S1 Pro Digital Camera
Fuji FinePix S1 Pro Digital Camera Logo
255 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
