Question about GE Spectra JBP78 Electric Kitchen Range
Ge jbp77 radiant range
After a power outage the oven will no longer turn completely off. Wife was baking cookies in the oven when power went off. The only way to turn oven off is pull breaker. Any ideas would be so great! James
My stove shut off. it want stay on
Ken
Posted on Feb 28, 2010
Whirlpool gold oven
One must preheat the oven to the desired baking temperature. If the oven is turned on and the food immediately put in to bake, it will take longer to bake the first batch than the second and subsequent batches, because the oven need a few minutes to heat up.
In other words, the oven isn't at 350 degrees the instant you turn it on. It takes about 15 minutes for the oven to reach 350 degrees. I hope this helps.
Jan 20, 2014 | Kitchen Ranges
After a power outage / low current power problem this evening, my whirlpool range, Model # SF315PEKW0 started beeping annoyingly, and displayed the following code F1 E1. Also, after, the oven would not...
The "F1-E1" fault code signifies an EEPROM checksum failure within the electronic oven control. Disconnect power to the range for longer than 30 seconds. Re-apply power and observe the display for longer than a minute. If the failure remains, disconnect power and replace the electronic oven control board.
Jul 24, 2011 | Ovens
Wife put the oven on clean cycle last night. This morning the heating element will not turn off, a one inch section glows orange. Turned oven off, put it back on clean, broil and off again, no change.
You probably just need a new bake element. Many ranges supply 120 volts to one side of the bake element at all times, switching the other side of the 240 voltage to it (and completing a circuit) when it needs to heat. If the element shorts to ground, the 120 volts can heat though a section of the element to the ground. OK, so much for the technical stuff. Turn power off to range. Replace bake element. Re-connect power. If it works, great. If it heat without turning oven "on" now, that would indicate that the electrical contacts in the bake relay on the control board have welded themselves together, necessitating replacing the control board. Let's hope you are not unlucky enough to have had that happen. (sometimes that happens as the result of an element failure)
Mar 06, 2011 | GE Profile Spectra JBP95 Electric Kitchen...
Frigidaire model ES510L will not go above 288 degrees on the main oven in baking mode, any ideas?
NO PARTS REQUIRED!!! DON'T PAY FOR A SERVICE CALL!!!
After a power outage, my wife's grandmother said she could no longer set her over to 300, 400, 450, whatever..
I went over to troubleshoot.
I couldn't figure out why everything seemed functional and why I couldn't set the over to higher than 288 (and thought, that's a rather odd number)... until I realized that that 288 degrees C = 550 degrees F which is the max the oven can do.
The power outage reset the computed back to Celsius instead of Farenheit (had to change it back to Farenheit).
Saved them a ton of money... cause this could have been an easy cash grab to some crook out there.
Dec 19, 2010 | Frigidaire PLES389D Electric Kitchen Range
Baking with digital oven
First let me address the temp ... Buy a meat thermometer and test it against the temp set in the oven.  Though that isn't the most accurate, it should prove whether or not it is way way off.
Second.. convection baking takes considerably less time....
Third... elevation plays a key factor on baking but not so much on cooking meat.  Baking above 2500ft elevation takes 20% longer and above.
Mar 08, 2008 | GE Profile JTP18 Electric Single Oven
Oven not baking properly
Check the door gasket and or hinges, it sounds like the heat is escaping and only radiant energy is doing the cooking.
Feb 02, 2008 | Kitchen Ranges
Ge oven problem
door lock is not work check wires motor and switchs.. you may have to replace the door lock
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
GE modelJBP65G V2AD hitchen range
it sounds like your TO8 CONTROL it is you oven controls and clock. let me know if you want to replace it ..
Aug 24, 2007 | GE JBP65 Electric Kitchen Range
GE Spectra JBP78 Electric Kitchen Range Logo
275 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
